Das kommt jetzt jedesmal wenn ich mich als sudo anmelde und hört irgendwie nicht auf was läfut da schief?
P { margin-bottom: 0.21cm; }
kbuildsycoca4 running...
kbuildsycoca4(9280)
KConfigGroup::readXdgListEntry: List entry Keywords in
"plasma-applet-opendesktop-activities.desktop" is not
compliant with XDG standard (missing trailing semicolon).
kbuildsycoca4(9280)
"plasma-applet-opendesktop.desktop" is not compliant with
kbuildsycoca4(9280)
"k3bsetup.desktop" is not compliant with XDG standard
kbuildsycoca4(9280)/kdecore (services)
KServicePrivate::init: The desktop entry file
"/usr/share/applications/YaST2/printer.desktop" has Type=
"Application" but also has a X-KDE-Library key. This works
for now, but makes user-preference handling difficult, so support for
this might be removed at some point. Consider splitting it into two
desktop files.
"/usr/share/applications/YaST2/samba-server.desktop" has
Type= "Application" but also has a X-KDE-Library key. This
works for now, but makes user-preference handling difficult, so
support for this might be removed at some point. Consider splitting
it into two desktop files.
"/usr/share/applications/YaST2/nfs.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/lan.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/iscsi-client.desktop" has
"/usr/share/applications/YaST2/scanner.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/messages.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/sudo.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/add-on.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/host.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/remote.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/proxy.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/kerberos.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/sw_source.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/joystick.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/dsl.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/inetd.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/ldap.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/firewall.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/users.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/timezone.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/vendor.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/backup.desktop" has Type=
desktop files.
"/usr/share/applications/YaST2/sound.desktop" has Type=
desktop files.
