@ tomfa-ng,
prima Idee- hab' ich gleich mal ausprobiert - leider keine Auswirkung
Auch keine Meldung(en)?
@ tomfa-ng,
@tomfa-ng
Sorry, habe ich völlig vergessen da wird doch was sein - oh oh
linux-ddds:~ # yast2 --qt
libGL error: pci id for fd 11: 80ee:beef, driver (null)
OpenGL Warning: glFlushVertexArrayRangeNV not found in mesa table
OpenGL Warning: glVertexArrayRangeNV not found in mesa table
OpenGL Warning: glCombinerInputNV not found in mesa table
OpenGL Warning: glCombinerOutputNV not found in mesa table
OpenGL Warning: glCombinerParameterfNV not found in mesa table
OpenGL Warning: glCombinerParameterfvNV not found in mesa table
OpenGL Warning: glCombinerParameteriNV not found in mesa table
OpenGL Warning: glCombinerParameterivNV not found in mesa table
OpenGL Warning: glFinalCombinerInputNV not found in mesa table
OpenGL Warning: glGetCombinerInputParameterfvNV not found in mesa table
OpenGL Warning: glGetCombinerInputParameterivNV not found in mesa table
OpenGL Warning: glGetCombinerOutputParameterfvNV not found in mesa table
OpenGL Warning: glGetCombinerOutputParameterivNV not found in mesa table
OpenGL Warning: glGetFinalCombinerInputParameterfvNV not found in mesa table
OpenGL Warning: glGetFinalCombinerInputParameterivNV not found in mesa table
OpenGL Warning: glDeleteFencesNV not found in mesa table
OpenGL Warning: glFinishFenceNV not found in mesa table
OpenGL Warning: glGenFencesNV not found in mesa table
OpenGL Warning: glGetFenceivNV not found in mesa table
OpenGL Warning: glIsFenceNV not found in mesa table
OpenGL Warning: glSetFenceNV not found in mesa table
OpenGL Warning: glTestFenceNV not found in mesa table
libGL error: core dri or dri2 extension not found
libGL error: failed to load driver: vboxvideo
OpenGL Warning: XGetVisualInfo returned 0 visuals for 0x25b1670
OpenGL Warning: Retry with 0x8002 returned 0 visuals
OpenGL Warning: glXGetFBConfigAttrib for 0x25b1670, failed to get XVisualInfo
Run command: /sbin/yast2 services-manager &
libGL error: pci id for fd 19: 80ee:beef, driver (null)
Ist das ein irgendein Problem des Grafiktreibers von VirtualBox?
Scheint so, aber mit VirtualBox kenne ich mich nicht aus.
Nur noch mal einige Infos zum Abschluss:
1. Ich habe openSUSE 13.2 jetzt mal probeweise auf ein älteres Notebook (Dell Latitude 6400) installiert. Das geschilderte Problem tritt hier nicht auf.
2. Ich vermute, dass VirtualBox, Version 4.3.10_93012, welche auf dem Host-Rechner installiert ist, das Problem verursacht.
(Die VBOXADDITIONS, Version 4.3.18-1.6, die über die Repros installiert sind arbeiten offensichtlich nicht sauber mit Version 4.3.10 zusammen. Ich konnte das Problem bisher jedoch nicht lösen, da der Bau des Hauptmoduls der VBoxAdditions (Version 4.3.10_93012 ) immer wieder fehlschlägt. Natürlich habe ich zuvor alle VBox-Pakete der höheren Version deinstalliert.)
Das Problem ist zwar nicht gelöst aber ich möchte hier auch keinen nerven mit Spekulationen.
@Sauerland
das Thema ist nicht gelöst, ist eine Kennzeichnung notwendig?
Woher hast Du Virtualbox installiert?
Meine Version stammt aus folgendem Repository :
Die URL zu diesem Repository ist folgende und gilt für alle openSUSE Versionen ab 12.3 :
Vor der Installation aus diesem Repository solltest Du aber alles deinstallieren, was Du an Virtualbox Paketen aus dem OSS Repository installiert hast. Ausserdem benötigst Du zum Bau der Kernelmodule noch die grundlegende und die Kernel Entwicklungsumgebung.
Das Extension Pack kannst Du von hier herunterladen.
Na die Versionen müssen gleich sein.
Binde das Repo von Trekkie00 ein, deinstalliere alles mit vbox im Namen und lasse nur das VirtualBox-4.3 installiert!
Dann noch die Extensions runterladen und installieren, sowie die Gasterweiterungen im Gast.
