ich kann nix dafür. Das macht das System alles alleine - nur SuSE drauf.
ich hab im YaST den Bootloader gefunden und auf 3.16.7.35 umgestellt. Jetzt startet die Compilierung von vmware-player. Leider mit Fehlermeldung im log:
2016-06-18T10:04:58.800+02:00| vthread-4| I125: Invoking modinfo on "vmmon".
2016-06-18T10:04:58.803+02:00| vthread-4| I125: "/sbin/modinfo" exited with status 256.
2016-06-18T10:04:58.803+02:00| vthread-4| I125: Invoking modinfo on "vmnet".
2016-06-18T10:04:58.806+02:00| vthread-4| I125: "/sbin/modinfo" exited with status 256.
2016-06-18T10:04:59.092+02:00| vthread-4| I125: Setting destination path for vmmon to "/lib/modules/3.16.7-35-desktop/misc/vmmon.ko".
2016-06-18T10:04:59.093+02:00| vthread-4| I125: Extracting the vmmon source from "/usr/lib/vmware/modules/source/vmmon.tar".
2016-06-18T10:04:59.129+02:00| vthread-4| I125: Successfully extracted the vmmon source.
2016-06-18T10:04:59.129+02:00| vthread-4| I125: Building module with command "/usr/bin/make -j4 -C /tmp/modconfig-lbUPXr/vmmon-only auto-build HEADER_DIR=/lib/modules/3.16.7-35-desktop/build/include CC=/usr/bin/gcc-4.8 IS_GCC_3=no"
2016-06-18T10:04:59.669+02:00| vthread-4| W115: Failed to build vmmon. Failed to execute the build command.
2016-06-18T10:04:59.673+02:00| vthread-4| I125: Setting destination path for vmnet to "/lib/modules/3.16.7-35-desktop/misc/vmnet.ko".
2016-06-18T10:04:59.674+02:00| vthread-4| I125: Extracting the vmnet source from "/usr/lib/vmware/modules/source/vmnet.tar".
2016-06-18T10:04:59.687+02:00| vthread-4| I125: Successfully extracted the vmnet source.
2016-06-18T10:04:59.687+02:00| vthread-4| I125: Building module with command "/usr/bin/make -j4 -C /tmp/modconfig-lbUPXr/vmnet-only auto-build HEADER_DIR=/lib/modules/3.16.7-35-desktop/build/include CC=/usr/bin/gcc-4.8 IS_GCC_3=no"
2016-06-18T10:05:00.213+02:00| vthread-4| W115: Failed to build vmnet. Failed to execute the build command.
