Konsolen Login
- Kababär
Hinweis: In dem Thema Konsolen Login gibt es 30 Antworten auf 4 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
Alles anzeigendavid@linux-rtfy:~> cat /etc/sysconfig/displaymanager | grep -i displaymanager DISPLAYMANAGER_XSERVER="Xorg" ## Description: settings to generate a proper displaymanager config # all changes in this file require a restart of the displaymanager DISPLAYMANAGER="kdm" DISPLAYMANAGER_REMOTE_ACCESS="no" # that root can never login if DISPLAYMANAGER_SHUTDOWN is "auto" and DISPLAYMANAGER_ROOT_LOGIN_REMOTE="no" # Let the displaymanager start a local Xserver. DISPLAYMANAGER_STARTS_XSERVER="yes" DISPLAYMANAGER_XSERVER_TCP_PORT_6000_OPEN="no" DISPLAYMANAGER_AUTOLOGIN="" # DISPLAYMANAGER_AUTOLOGIN is empty. DISPLAYMANAGER_PASSWORD_LESS_LOGIN="no" DISPLAYMANAGER_AD_INTEGRATION="no" # "none" (nobody can shutdown from displaymanager), "auto" (follow DISPLAYMANAGER_SHUTDOWN="auto"
Alles anzeigendavid@linux-rtfy:~> zypper se -si | grep -Ei 'kdm|sddm|xdm|gdm|lightdm' i+ | gdm | Paket | 3.14.2-16.1 | x86_64 | openSUSE-Leap-42.2-Oss i | gdm-branding-openSUSE | Paket | 42.1-2.1 | noarch | openSUSE-Leap-42.2-Oss i | gdm-lang | Paket | 3.14.2-16.1 | noarch | openSUSE-Leap-42.2-Oss i | gdmflexiserver | Paket | 3.14.2-16.1 | noarch | openSUSE-Leap-42.2-Oss i+ | kcm_sddm | Paket | 5.8.2-1.1 | x86_64 | openSUSE-Leap-42.2-Oss i+ | kcm_sddm-lang | Paket | 5.8.2-1.1 | noarch | openSUSE-Leap-42.2-Oss i+ | libXdmcp6 | Paket | 1.1.2-3.3.1 | x86_64 | openSUSE-Leap-42.2-Update i | libgdm1 | Paket | 3.14.2-16.1 | x86_64 | openSUSE-Leap-42.2-Oss i+ | sddm | Paket | 0.13.0-8.1 | x86_64 | openSUSE-Leap-42.2-Oss i+ | sddm-branding-openSUSE | Paket | 0.13.0-8.1 | x86_64 | openSUSE-Leap-42.2-Oss i+ | sddm-theme-openSUSE | Paket | 42.1.1-12.1 | noarch | openSUSE-Leap-42.2-Update i | typelib-1_0-Gdm-1_0 | Paket | 3.14.2-16.1 | x86_64 | openSUSE-Leap-42.2-Oss i+ | xdm | Paket | 1.1.11-13.1 | x86_64 | openSUSE-Leap-42.2-Update i+ | xdm-xsession | Paket | 1.1.11-13.1 | x86_64 | openSUSE-Leap-42.2-Update i+ | xdmbgrd | Paket | 0.6-219.3 | x86_64 | openSUSE-Leap-42.2-Oss david@linux-rtfy:~>
Codedavid@linux-rtfy:~> /sbin/lspci -nnk | grep -EiA3 'vga|3d|display' 01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Tahiti PRO [Radeon HD 7950/8950 OEM / R9 280] [1002:679a] Subsystem: PC Partner Limited / Sapphire Technology Radeon R9 280 [174b:a003] Kernel driver in use: radeon Kernel modules: radeon
Was ist ein Paste Server? Die Ausgabe lokal auf meinem Rechner ist mMn. viel zu lange, um sie hier zu posten xD -
Alles anzeigendavid@linux-rtfy:~> sudo zypper in kdm root's password: Repository-Daten werden geladen... Installierte Pakete werden gelesen... Paketabhängigkeiten werden aufgelöst... Die folgenden 3 NEUEN Pakete werden installiert: kde4-kgreeter-plugins kdm kdm-branding-openSUSE 3 neue Pakete zu installieren. Gesamtgröße des Downloads: 1,6 MiB. Bereits im Cache gespeichert: 0 B. Nach der Operation werden zusätzlich 3,0 MiB belegt. Fortfahren? [j/n/...? zeigt alle Optionen] (j): j Paket kde4-kgreeter-plugins-4.11.22-3.24.x86_64 abrufen (1/3), 77,6 KiB (108,2 KiB entpackt) Abrufen: kde4-kgreeter-plugins-4.11.22-3.24.x86_64.rpm ...........................................................[fertig (328,0 KiB/s)] Paket kdm-4.11.22-3.24.x86_64 abrufen (2/3), 1,5 MiB ( 2,9 MiB entpackt) Abrufen: kdm-4.11.22-3.24.x86_64.rpm .............................................................................[fertig (964,7 KiB/s)] Paket kdm-branding-openSUSE-42.1-8.1.noarch abrufen (3/3), 58,1 KiB ( 46,4 KiB entpackt) Abrufen: kdm-branding-openSUSE-42.1-8.1.noarch.rpm .............................................................................[fertig] Überprüfung auf Dateikonflikte läuft: ..........................................................................................[fertig] (1/3) Installieren: kde4-kgreeter-plugins-4.11.22-3.24.x86_64 ..................................................................[fertig] (2/3) Installieren: kdm-4.11.22-3.24.x86_64 ....................................................................................[fertig] Zusätzliche rpm-Ausgabe: Information: reading pre-existing kdmrc /usr/share/kde4/config/kdm/kdmrc (config version 2.4) (3/3) Installieren: kdm-branding-openSUSE-42.1-8.1.noarch ......................................................................[fertig] Zusätzliche rpm-Ausgabe: Updating /etc/sysconfig/displaymanager...
Beim Abmelden erscheint weiterhin der graue Screen.
Ich reboote mal. (hatte auch schon gdm und ssdm ausprobiert, nur um zu sehen, ob der Screen verschwindet, aber Pustekuchen)Edit: Wunderbar! Es hat funktioniert, danke!
Schön das es wieder funktioniert.
Kleiner Tip am Rande:
Du solltest Dein Profil anpassen, als Betriebssystem Leap 42.2 eintragen. -
Danke, ist erledigt. Auch den Desktop habe ich angepasst.
Und noch ein Tipp: Löse dich bitte von dem *buntu - Übel "sudo". Unter openSUSE wird "su" zur Erlangung von Root-Rechten benutzt. "sudo" hat hier Einschränkungen und wird im Root nicht genutzt.
Danke für den Tipp, da unterscheidet sich openSUSE wohl von Debian. Bisweilen hat es allerdings immer funktioniert, wenn Root-Rechte benötigt wurden, z.B. bei Updates, De-Installationen, Erstellen von Ordnern im /opt-Verzeichnis, etc.
Aber das ist ein anderes Thema und gehört nicht mehr zu diesem Thread. Mal sehen, was ich im Netz so rausfinde. Danke nochmal für den Tipp
