Testton: Ja Sound: Nein
    ich habe einen Acer 6292 Opensuse 11.3 und Gnome oberflaeche. Musste Suse neu installieren und habe seit dem keinen sound mehr. Der Teston laesst sich abspielen.
    Nach einiger Zeit suchen habe ich mich entschlossen doch mal zu posten.
    [anmerkung]speaker-test -c2 -l5 -twav
    speaker-test 1.0.23
    Playback device is default
    Stream parameters are 48000Hz, S16_LE, 2 channels
    WAV file(s)
    Rate set to 48000Hz (requested 48000Hz)
    Buffer size range from 96 to 1048576
    Period size range from 32 to 349526
    Using max buffer size 1048576
    Periods = 4
    was set period_size = 262144
    was set buffer_size = 1048576
    0 - Front Left
    1 - Front Right
    Time per period = 11.373239
    0 - Front Left
    1 - Front Right
    Time per period = 11.398838
    [/anmerkung]
    [anmerkung]
    hwinfo --sound
    14: PCI 1b.0: 0403 Audio device
    [Created at pci.318]
    Unique ID: u1Nb.0AYnuIDY8L3
    SysFS ID: /devices/pci0000:00/0000:00:1b.0
    SysFS BusID: 0000:00:1b.0
    Hardware Class: sound
    Model: "Intel 82801H (ICH8 Family) HD Audio Controller"
    Device: pci 0x284b "82801H (ICH8 Family) HD Audio Controller"
    SubVendor: pci 0x1025 "Acer Incorporated [ALI]"
    SubDevice: pci 0x011b
    Revision: 0x03
    Driver: "HDA Intel"
    Driver Modules: "snd_hda_intel"
    Memory Range: 0xf0500000-0xf0503fff (rw,non-prefetchable)
    IRQ: 28 (294 events)
    Module Alias: "pci:v00008086d0000284Bsv00001025sd0000011Bbc04sc03i00"
    Driver Info #0:
    Driver Status: snd_hda_intel is active
    Driver Activation Cmd: "modprobe snd_hda_intel"
    Config Status: cfg=yes, avail=yes, need=no, active=unknown
    [/anmerkung]
    [anmerkung]
    rpm -qa |grep alsa
    alsa-utils-1.0.23-1.8.x86_64
    alsa-oss-1.0.17-29.2.x86_64
    alsa-plugins-1.0.23-1.9.x86_64
    alsa-plugins-pulse-32bit-1.0.23-1.9.x86_64
    alsa-1.0.23-2.12.x86_64
    alsa-devel-1.0.23-2.12.x86_64
    alsa-plugins-pulse-1.0.23-1.9.x86_64
    alsa-plugins-32bit-1.0.23-1.9.x86_64
    alsa-firmware-1.0.23-1.2.noarch
    alsa-oss-32bit-1.0.17-29.2.x86_64
    [/anmerkung]
    [anmerkung]
    alsaconf
    sagt:
    No supported PnP or PCI card found
    [/anmerkung]
    [anmerkung]
    /sbin/lspci
    hat
    00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
    gelistet.
    [/anmerkung]
    Danke fuer eure Zeit.
    Für den Inhalt des Beitrages 23459 haftet ausdrücklich der jeweilige Autor: Imohtep
