An der Verkabelung kann es auch nicht liegen da es unter Win 10 kunktioniert
Treiber GeForce GTX 965M installieren
- Linux-Idefix
Hinweis: In dem Thema Treiber GeForce GTX 965M installieren gibt es 49 Antworten auf 5 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
Danke bin ach noch am googeln aber ich bin für jeden tip dankbar
Alles anzeigenxrandr Screen 0: minimum 320 x 200, current 3840 x 2160, maximum 8192 x 8192 eDP-1 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 382mm x 214mm 3840x2160 60.02*+ 50.07 48.04 2048x1536 60.00 1920x1440 60.00 1856x1392 60.01 1792x1344 60.01 1600x1200 60.00 1400x1050 59.98 1280x1024 60.02 1280x960 60.00 1024x768 60.04 60.00 960x720 60.00 928x696 60.05 896x672 60.01 800x600 60.00 60.32 56.25 700x525 59.98 640x512 60.02 640x480 60.00 59.94 512x384 60.00 400x300 60.32 56.34 320x240 60.05 HDMI-1 disconnected (normal left inverted right x axis y axis)
Kann dein Monitor denn 3840x2160?
oho das ein Problem?
Bash
Alles anzeigen#!/bin/bash # Readback-display synchronization method # 0: no sync, 1: D lags behind one frame, 2: fully synced export PRIMUS_SYNC=${PRIMUS_SYNC:-0} # Verbosity level # 0: only errors, 1: warnings (default), 2: profiling export PRIMUS_VERBOSE=${PRIMUS_VERBOSE:-1} # Upload/display method # 0: autodetect, 1: textures, 2: PBO/glDrawPixels (needs Mesa-10.1+) export PRIMUS_UPLOAD=${PRIMUS_UPLOAD:-0} # Approximate sleep ratio in the readback thread, percent export PRIMUS_SLEEP=${PRIMUS_SLEEP:-90} # Secondary display export PRIMUS_DISPLAY=${PRIMUS_DISPLAY:-:8} # "Accelerating" libGL # $LIB will be interpreted by the dynamic linker export PRIMUS_libGLa=${PRIMUS_libGLa:-'/usr/$LIB/nvidia/libGL.so.1'} # "Displaying" libGL export PRIMUS_libGLd=${PRIMUS_libGLd:-'/usr/$LIB/libGL.so.1'} # Directory containing primus libGL PRIMUS_libGL=${PRIMUS_libGL:-'/usr/$LIB/primus'} # On some distributions, e.g. on Ubuntu, libnvidia-tls.so is not available # in default search paths. Add its path manually after the primus library # PRIMUS_libGL=${PRIMUS_libGL}:/usr/lib/nvidia-current:/usr/lib32/nvidia-current # Mesa drivers need a few symbols to be visible # export PRIMUS_LOAD_GLOBAL=${PRIMUS_LOAD_GLOBAL:-'libglapi.so.0'} # Need functions from primus libGL to take precedence export LD_LIBRARY_PATH=${PRIMUS_libGL}${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH} # And go! exec "$@"
Da kann ich leider auch nicht helfen. Vor so einer Hardware hüte ich mich ebenfalls. Aber meine Idee war, wenn der Monitor die Auflösung nicht darstellen kann, zeigt er auch nichts an.
Welches DE nutzt du ?
Kannst du in zb. PLasma5 => Systemeinstellungen => Anzeige und Monitor - den Bildschirm 1 und 2 sehen oder ist dort nur ein Bildschirm zu sehenUnd bitte ergänze dein Profil damit wir sehen mit was du arbeitest...
LG SUSEDJAlex
Danke dür euer bemühen
ich sehe in Systemeinstellungen => Anzeige und Monitor => 1 monitor nur den des Laptopdie Auflösung vom Monitor 1 integriert im Laptop ist ok nur beim Hdmi kommt nichts raus
Keine Ahnung, ob folgendes noch gilt:
Ziehe mal in dem Dialogfeld den sichtbaren Monitor mit der Mouse zur Seite.
Die lagen/liegen gerne übereinander.(Und eingesteckt muss das HDMI Dingens natürlich sein.)
habe gerade noch mal Windows gestartet, dort funktioniert die Verbindung auf Anhieb
es wir nur der integrierte Monitor erkannt
habe aber schon einmal den Monitor am laufen gehabt aber nur mit einer min Auflösung.
Kann sein dass ein Modul fehlt oder ...
Danke für die Anregung
