USB Probleme Tastatur und Maus durch letzten Kernelupdate
  • USB Probleme Tastatur und Maus durch letzten Kernelupdate
    Falls jemand Probleme in den letzten Tagen hatte mit einem Kernelupdate, das Störungen mit USB Maus und/oder Tastatur verursacht hatte: Mit dem heutigen Kernelupdate ist das gefixt.
    Ich gebe hier mal die Mail aus der Mailingliste
    opensuse-security-announce@opensuse.org wieder:
    SUSE Security Announcement
    Package: kernel
    Announcement ID: SUSE-SA:2010:041
    Date: Fri, 17 Sep 2010 14:00:00 +0000
    Affected Products: openSUSE 11.3
    Vulnerability Type: local privilege escalation
    CVSS v2 Base Score: 7.2 (AV:L/AC:L/Au:N/C:C/I:C/A:C)
    SUSE Default Package: yes
    Cross-References: CVE-2010-2803, CVE-2010-2942, CVE-2010-2954
    CVE-2010-2959, CVE-2010-3078
    Content of This Advisory:
    1) Security Vulnerability Resolved:
    Linux kernel update
    Problem Description
    2) Solution or Work-Around
    3) Special Instructions and Notes
    4) Package Location and Checksums
    5) Pending Vulnerabilities, Solutions, and Work-Arounds:
    - Two new local privilege escalations in the Linux kernels
    6) Authenticity Verification and Additional Information
    ______________________________________________________________________________
    1) Problem Description and Brief Discussion
    The openSUSE 11.3 kernel was updated to version 2.6.34.7. The update fixes
    lots of bugs and security issues.
    A major regression in handling some USB Input devices (Mice and Keyboard)
    introduced by the previous update was fixed.
    We also fixed a lot of bugs in the ATH5K wireless driver.
    Following security issues were fixed:
    CVE-2010-3078: A XFS stack memory information disclosure was fixed.
    CVE-2010-2954: A NULL pointer dereference in the IRDA stack was fixed,
    which could lead to kernel crashes.
    CVE-2010-2959: A local privilege escalation in the CAN bus protocol
    module can_bcm was fixed.
    CVE-2010-2942: Several memory leaks in the net scheduling code
    were fixed.
    CVE-2010-2803: Fixed kernel memory information leaks from DRM ioctls.
    There is no known workaround, please install the update packages.
    Please reboot the machine after installing the update.
    The preferred method for installing security updates is to use the YaST
    Online Update (YOU) tool. YOU detects which updates are required and
    automatically performs the necessary steps to verify and install them.
    Alternatively, download the update packages for your distribution manually
    and verify their integrity by the methods listed in Section 6 of this
    announcement. Then install the packages using the command
    rpm -Fhv <file.rpm>
    to apply the update, replacing <file.rpm> with the filename of the
    downloaded RPM package.
    Für den Inhalt des Beitrages 24138 haftet ausdrücklich der jeweilige Autor: robbie
