Leap 15 wieder mal Netzwerkprobleme
Hinweis: In dem Thema Leap 15 wieder mal Netzwerkprobleme gibt es 20 Antworten auf 3 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
  • die Ausgabe von "testparm":
    Load smb config files from /etc/samba/smb.conf
    rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
    Can't find include file /etc/samba/dhcp.conf
    WARNING: The "idmap gid" option is deprecated
    WARNING: The "idmap uid" option is deprecated
    Processing section "[homes]"
    Processing section "[profiles]"
    Processing section "[users]"
    Processing section "[groups]"
    Processing section "[printers]"
    Processing section "[print$]"
    Processing section "[netlogon]"
    Loaded services file OK.
    Server role: ROLE_DOMAIN_PDC
    Press enter to see a dump of your service definitions
    # Global parameters
    [global]
    add machine script = /usr/sbin/useradd -c Machine -d /var/lib/nobody -s /bin/false %m$
    domain logons = Yes
    domain master = Yes
    idmap gid = 10000-20000
    idmap uid = 10000-20000
    logon drive = P:
    logon home = \\%L\%U\.9xprofile
    logon path = \\%L\profiles\.msprofile
    map to guest = Bad User
    os level = 65
    preferred master = Yes
    printcap name = cups
    security = USER
    usershare max shares = 100
    wins support = Yes
    workgroup = RS-PRIVAT
    idmap config * : range = 10000-20000
    idmap config * : backend = tdb
    cups options = raw
    include = /etc/samba/dhcp.conf
    [homes]
    browseable = No
    comment = Home Directories
    inherit acls = Yes
    read only = No
    valid users = %S %D%w%S
    [profiles]
    comment = Network Profiles Service
    create mask = 0600
    directory mask = 0700
    path = %H
    read only = No
    store dos attributes = Yes
    [users]
    comment = All users
    inherit acls = Yes
    path = /home
    read only = No
    veto files = /aquota.user/groups/shares/
    [groups]
    comment = All groups
    inherit acls = Yes
    path = /home/groups
    read only = No
    [printers]
    browseable = No
    comment = All Printers
    create mask = 0600
    path = /var/tmp
    printable = Yes
    [print$]
    comment = Printer Drivers
    create mask = 0664
    directory mask = 0775
    force group = ntadmin
    path = /var/lib/samba/drivers
    write list = @ntadmin root
    [netlogon]
    comment = Network Logon Service
    path = /var/lib/samba/netlogon
    write list = root
    und die von "/etc/samba/smb.conf":
    # smb.conf is the main Samba configuration file. You find a full commented
    # version at /usr/share/doc/packages/samba/examples/smb.conf.SUSE if the
    # samba-doc package is installed.
    [global]
    passdb backend = tdbsam
    printing = cups
    printcap cache time = 750
    cups options = raw
    logon drive = P:
    usershare allow guests = No
    security = user
    domain logons = Yes
    domain master = Yes
    local master = Yes
    os level = 65
    wins support = Yes
    [homes]
    valid users = %S, %D%w%S
    browseable = No
    read only = No
    inherit acls = Yes
    [profiles]
    path = %H
    read only = No
    create mask = 0600
    [users]
    comment = All users
    path = /home
    read only = No
    inherit acls = Yes
    [groups]
    path = /home/groups
    read only = No
    inherit acls = Yes
    [printers]
    path = /var/tmp
    printable = Yes
    create mask = 0600
    browseable = No
    [print$]
    create mask = 0664
    [netlogon]
    write list = root
    Für den Inhalt des Beitrages 126766 haftet ausdrücklich der jeweilige Autor: Ralf69
  • Tamerlain schrieb:
    Verstehe nicht wieso man das grottige samba nutzt.
    Was du verstehst oder nicht interessiert den TE bei der Lösung seines Problemes wohl eher nur sekundär. Halte dich also bitte etwas mit deiner Ausdrucksweise zurück. Wenn du zur Lösung nichts beizutragen hast musst du auch nichts schreiben.
    Für den Inhalt des Beitrages 126768 haftet ausdrücklich der jeweilige Autor: Alero
    Danke Alero für Deinen Beistand. Ich nutze schon seit Jahren Samba auf Linux u. Androiden. zumal sich das auch mit Windows "versteht".
    Werde mich später nochmal mit dieser Materie beschäftigen. Muß erstmal noch was anderes erledigen. Und dabei vielleicht den Kopf für neue Ideen frei bekommen.
    Danke erstmal an alle für Eure Hilfe.
    Ach eine Idee hätte ich da noch: Auf meinem 13.2 OpenSUSE läuft ja alles, kann ich da nicht einfach die "/etc/samba/smb.conf" von diesen Rechner auf mein "LEAP 15" kopieren?
    Ralf
    Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von Ralf69 ()
    Für den Inhalt des Beitrages 126775 haftet ausdrücklich der jeweilige Autor: Ralf69
  • Hallo Ralf,
    brauche noch etwas Zeit für die Durchsicht deiner geposteten Infos.
    Werde gerade "genötigt", zu arbeiten.
    Hat es evtl. damit zu tun, weil ich auf der Arbeit bin?
    Hmmm (-:
    Bis nachher...
    Zitat Albert Einstein:
    Für den Inhalt des Beitrages 126781 haftet ausdrücklich der jeweilige Autor: sterun
  • @Ralf69
    Bitte benutze für Konsolenausgaben Code-Tags.
    Siehe die Links hier unter diesem Text in meiner Signatur.
    Und bitte immer die Konsolenausgabe eines Befehls incl. der kompletten Eingabezeile.
    Code-Tags <<<Klick mich
    zypper <<<Klick mich
    Für den Inhalt des Beitrages 126782 haftet ausdrücklich der jeweilige Autor: Sauerland
  • Sauerland schrieb:
    @Ralf69
    Tut mir leid, ich muß mich da mal mit beschäftigen.
    Gruß Ralf
    Für den Inhalt des Beitrages 126785 haftet ausdrücklich der jeweilige Autor: Ralf69
  • Damit eine Namesauflösung der Workgroups funktioniert, muss das entsprechende Microsoftprotokoll laufen.
    Da du mit IPs die Verbindungen machen kannst, liegt die Vermutung nahe, dass genau dieses Protolkoll nicht läuft.
    Ich verwende sowas nicht. Ich bin radikal windowsfreie Zone (und alle meine Netzwerke auch)
    Deshalb weiß ich nicht genau, wie das Ding heißt. Aber winbind sollte zumindest ein Suchbegriff sein, der dich da weiterbringen kann.
    Für den Inhalt des Beitrages 126788 haftet ausdrücklich der jeweilige Autor: Berichtigung
  • Über "winbind" bin ich heut schon öfter gestolpert, weiß aber nicht mehr wo.
    Aber nochmal auf mein Post 13 zurück zu kommen, könnte ich nicht einfach die Datei "smb.conf" von linux 13.2 zu Linux 15 kopieren? Oder gibt es da Versionsprobleme?
    Werd mich morgen mal damit beschäftigen. Wenn ich´s versaue, muß ich eben nochmal neu installieren...
    Ralf
    Für den Inhalt des Beitrages 126793 haftet ausdrücklich der jeweilige Autor: Ralf69
    Durchaus möglich. Optionen und Parameter können wegfallen oder dazukommen. Kann gehen, muss aber nicht.
    Genaueres kann ich auch nicht sagen, denn ich habe wie Berichtigung auch eine windowsfreie Radikalenzone. Oder so.
    Nur mal so nebenbei: Du schreibst von linux 13.2 bzw. linux 15.0. Diese Zahlen sind Versionsnummern von OpenSuse.
    Also korrekterweise: OpenSuse 13.2 oder OpenSuse Leap 15.0. ;)
    Für den Inhalt des Beitrages 126795 haftet ausdrücklich der jeweilige Autor: ThomasS
  • Hallo Ralf
    Ein Versuch...
    Öffne die "/etc/samba/smb.conf"
    Unter "wins support = Yes"...
    ...fügst du folgende Zeile ein:
    name resolve order = lmhosts hosts bcast wins
    Dann öffnest du die "/etc/samba/lmhosts"
    Dort trägst du die IP Adressen und die dazu gehörigen Hostnamen deiner Rechner ein.
    Wahrscheinlich würde es auch gehen, wenn du die "/etc/hosts" editierst.
    Du musst halt nur in der smb.conf definieren, wo und in welcher Reihenfolge gesucht wird.
    Danach sollten alle Rechner auch namentlich erreichbar sein.
    PS:
    Sollten deine Systeme eine neue IP erhalten (Lease Time), müsste die lmhosts angepasst werden.
    Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von sterun ()
    Für den Inhalt des Beitrages 126796 haftet ausdrücklich der jeweilige Autor: sterun
