Bin jetzt wieder in Linux. Hat diesmal den Fehler "firmware file rtl_bt/rtl8821c_fw.bin not found" nicht gebracht - beim ganz normalen starten mit Kernel 4.12.14-lp151.28.32-default. Das hat heute vormittag 6 mal nicht geklappt !!?? Habe also Deinen Vorschlag also nicht gebraucht.
Die Ausgabe, beim ersten Fehlschlag mit Kernel 4.12.14-lp151.28.32-default, von
journactl -xb | grep -a20 rtl > rtl8821c_fw.bin_failed ist:
Nov 17 12:17:50 corrimal kernel: usbcore: registered new interface driver uas
Nov 17 12:17:50 corrimal kernel: usb 1-5: new high-speed USB device number 4 using xhci_hcd
Nov 17 12:17:50 corrimal kernel: usb 1-5: New USB device found, idVendor=04f2, idProduct=b65d
Nov 17 12:17:50 corrimal kernel: usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Nov 17 12:17:50 corrimal kernel: usb 1-5: Product: HP TrueVision HD Camera
Nov 17 12:17:50 corrimal kernel: usb 1-5: Manufacturer: Chicony Electronics Co.,Ltd.
Nov 17 12:17:50 corrimal kernel: usb 1-5: SerialNumber: 0001
Nov 17 12:17:50 corrimal kernel: usb 1-6: new full-speed USB device number 5 using xhci_hcd
Nov 17 12:17:51 corrimal kernel: usb 1-6: New USB device found, idVendor=0bda, idProduct=b00a
Nov 17 12:17:51 corrimal kernel: usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 17 12:17:51 corrimal kernel: usb 1-6: Product: Bluetooth Radio
Nov 17 12:17:51 corrimal kernel: usb 1-6: Manufacturer: Realtek
Nov 17 12:17:51 corrimal kernel: usb 1-6: SerialNumber: 00e04c000001
Nov 17 12:17:51 corrimal kernel: Bluetooth: Core ver 2.22
Nov 17 12:17:51 corrimal kernel: NET: Registered protocol family 31
Nov 17 12:17:51 corrimal kernel: Bluetooth: HCI device and connection manager initialized
Nov 17 12:17:51 corrimal kernel: Bluetooth: HCI socket layer initialized
Nov 17 12:17:51 corrimal kernel: Bluetooth: L2CAP socket layer initialized
Nov 17 12:17:51 corrimal kernel: Bluetooth: SCO socket layer initialized
Nov 17 12:17:51 corrimal kernel: usbcore: registered new interface driver btusb
Nov 17 12:17:51 corrimal kernel: Bluetooth: hci0: RTL: rtl: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
Nov 17 12:17:51 corrimal kernel: Bluetooth: hci0: RTL: rom_version status=0 version=1
Nov 17 12:17:51 corrimal kernel: Bluetooth: hci0: RTL: rtl: loading rtl_bt/rtl8821c_fw.bin
Nov 17 12:17:51 corrimal kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8821c_fw.bin failed with error -2
Nov 17 12:17:51 corrimal kernel: Bluetooth: hci0: RTL: firmware file rtl_bt/rtl8821c_fw.bin not found
Nov 17 12:17:51 corrimal systemd[1]: Found device TOSHIBA_MQ04ABF100 7.
-- Subject: Unit dev-disk-by\x2did-ata\x2dTOSHIBA_MQ04ABF100_98PKP2Q8T\x2dpart7.device has finished start-up
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit dev-disk-by\x2did-ata\x2dTOSHIBA_MQ04ABF100_98PKP2Q8T\x2dpart7.device has finished starting up.
-- The start-up result is done.
Nov 17 12:17:51 corrimal systemd[1]: Starting Resume from hibernation using device /dev/disk/by-id/ata-TOSHIBA_MQ04ABF100_98PKP2Q8T-part7...
-- Subject: Unit systemd-hibernate-resume@dev-disk-by\x2did-ata\x2dTOSHIBA_MQ04ABF100_98PKP2Q8T\x2dpart7.service has begun start-up
-- Unit systemd-hibernate-resume@dev-disk-by\x2did-ata\x2dTOSHIBA_MQ04ABF100_98PKP2Q8T\x2dpart7.service has begun starting up.
Nov 17 12:17:51 corrimal kernel: PM: Starting manual resume from disk
Nov 17 12:17:51 corrimal kernel: PM: Hibernation image partition 8:7 present
Nov 17 12:17:51 corrimal kernel: PM: Looking for hibernation image.
Nov 17 12:17:51 corrimal kernel: PM: Image not found (code -22)
Nov 17 12:17:51 corrimal kernel: PM: Hibernation image not present or could not be loaded.
Nov 17 12:17:51 corrimal systemd-hibernate-resume[324]: Could not resume from '/dev/disk/by-id/ata-TOSHIBA_MQ04ABF100_98PKP2Q8T-part7' (8:7).
