Kein WLAN in opensuse 12.1
Hinweis: In dem Thema Kein WLAN in opensuse 12.1 gibt es 20 Antworten auf 3 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
  • 67: USB 00.0: 0282 WLAN controller
    [Created at usb.122]
    Unique ID: 8DDa.g_9cFk0xIL3
    Parent ID: MtLc.4uPzupm_EOA
    SysFS ID: /devices/pci0000:00/0000:00:1d.7/usb1/1-6/1-6.1/1-6.1:1.0
    SysFS BusID: 1-6.1:1.0
    Hardware Class: network
    Model: "Ralink 802.11g WiFi"
    Hotplug: USB
    Vendor: usb 0x148f "Ralink Technology, Corp."
    Device: usb 0x2570 "802.11g WiFi"
    Revision: "0.01"
    Driver: "rt2500usb"
    Driver Modules: "rt2500usb"
    Device File: wlan0
    Features: WLAN
    Speed: 480 Mbps
    HW Address: 00:11:09:e1:3c:9c
    WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
    WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472 2.484
    WLAN encryption modes: WEP40 WEP104 TKIP CCMP
    WLAN authentication modes: open sharedkey wpa-psk wpa-eap
    Module Alias: "usb:v148Fp2570d0001dc00dsc00dp00icFFiscFFipFF"
    Driver Info #0:
    Driver Status: rt2500usb is active
    Driver Activation Cmd: "modprobe rt2500usb"
    Attached to: #64 (Hub)
    33: PCI 306.0: 0200 Ethernet controller
    [Created at pci.319]
    Unique ID: rBUF.IlyQZOoXZS0
    Parent ID: 6NW+.oj0je2xokp8
    SysFS ID: /devices/pci0000:00/0000:00:1e.0/0000:03:06.0
    SysFS BusID: 0000:03:06.0
    Model: "VIA VT6105/VT6106S [Rhine-III]"
    Vendor: pci 0x1106 "VIA Technologies, Inc."
    Device: pci 0x3106 "VT6105/VT6106S [Rhine-III]"
    SubVendor: pci 0x1462 "Micro-Star International Co., Ltd."
    SubDevice: pci 0x091c
    Revision: 0x8b
    Driver: "via-rhine"
    Driver Modules: "via_rhine"
    Device File: eth0
    I/O Ports: 0xd300-0xd3ff (rw)
    Memory Range: 0xd8004000-0xd80040ff (rw,non-prefetchable)
    IRQ: 18 (15673 events)
    HW Address: 00:11:09:f1:da:db
    Link detected: yes
    Module Alias: "pci:v00001106d00003106sv00001462sd0000091Cbc02sc00i00"
    Driver Info #0:
    Driver Status: via_rhine is active
    Driver Activation Cmd: "modprobe via_rhine"
    Attached to: #22 (PCI bridge)
    Für den Inhalt des Beitrages 37904 haftet ausdrücklich der jeweilige Autor: Oliver59
    bash: ./collectNWData.sh: Datei oder Verzeichnis nicht gefunden
    Ich würde ja mal in das entsprechende Verzeichnis wechseln, oder den passenden Pfad mit angeben.
    ls Downloads/
    oder
    ls ~/Downloads/
    , so als Verdacht, ergibt was?
    Für den Inhalt des Beitrages 37905 haftet ausdrücklich der jeweilige Autor: tomfa-ng
  • Du Tim,
    zum besseren Verständnis,
    mit der Signatur meinst Du sicherlich
    die gezeigte Zeile unter dem Quellcode, ist das richtig.
    Verstehe ich es richtig, das ich als
    root bin, wenn ich vor dem Befehl ein Flash mache, also so /
    Tim ich bin gerade am überlegen,
    bevor ich noch lange herum bastele und komme vielleicht doch nicht
    klar damit, wäre es möglich, das ich bei Dir mal vorbei kommen
    könnte, denn ich lese, Du wohnst in Kaiserslautern, das sind etwa 70
    km. Die Zeit wäre vielleicht nützlicher investiert, als noch
    Stunden oder Tage herum zu basteln und es vielleicht dann auf zu
    geben. Ist gerade meine Überlegung.
    Aber nur, wenn das Deinerseits möglich
    wäre. Zeitlich könnte ich mich an Dir orientieren.
    Gruß Oliver
    Für den Inhalt des Beitrages 37912 haftet ausdrücklich der jeweilige Autor: Oliver59
  • Habe es irgendwie geschafft, das folgende Script aus zu führen.
    collectNWData.sh
    Wie weiß ich aber nicht.
    Wenn ich mir das so ansehe, bin ich ja mitten in der Programmierung. Davon habe ich aber leider keine Ahnung. Das sind ja etliche Seiten, die ich gar nicht verstehe.
    Und das alles nur um WLAN zu bekommen, das krieg ich nicht hin, zumal das in keiner Relation steht, mit dem zeitlichen Aufwand. Da müßte ich noch ein halber Programmierer werden. Nein, in diesem Leben nicht mehr.
    Für den Inhalt des Beitrages 37922 haftet ausdrücklich der jeweilige Autor: Oliver59
  • Oliver setze Dich doch einfach mal mit der Linux User Group hier bei uns in Kaiserslautern in Verbindung.
    Die treffen sich jeden 1. und 3. Mittwoch im Hofbräuhaus in Kaiserslautern. Die haben dort auch WLAN Anbindung. Die helfen Dir bestimmt weiter. Das nächste Treffen ist am 18.01.2012.
    Homepage mit Kontaktdaten :
    http://www.lug-kl.de/
    collectNWData.sh
    Du hast es per Doppelklick geöffnet und siehst jetzt den Quelltext.
    ESSid im Router auf sichtbar stellen, nicht verstecken.
    Kabel abziehen
    Öffne den Dateimanager dolphin.
    Wechsle in das Verzeichnis, in dem Du die collectNWData gespeichert hast.
    Rechtsklick auf die Datei------Eigenschaften----Berechtigungen----ausführbar anklicken---ok
    Jetzt im Dolphin auf Extras----Terminal öffnen.
    In dem jetzt geöffneten Terminal gibst Du einfach:
    ./collectNWData.sh
    ein
    beantworte die Fragen als root starten mit ja root-Passwort eingeben
    Posten in einem Forum mit nein
    --- (2) Kabellose Verbindung (WLAN)
    --- (2) WLAN HW router <---> LinuxClient
    Essid ist der Netzwerkname Deines Funknetzes.
    Es entsteht in dem collectNWData.sh-Verzeichnis eine collectNWData.txt, die Du hier als Anhang postest.
    Für den Inhalt des Beitrages 37924 haftet ausdrücklich der jeweilige Autor: Sauerland
  • das will ich dann mal tun.
    Für mich wäre es natürlich einfacher, wenn hier in meiner Nähe Bad Kreuznach Linux User wären, oder Linux Treffen.
    Nun um mir einmal zeigen zu lassen, wie ich mit WLAN ins Netz komme, wäre ich auch mal nach Kaiserslautern gefahren.
    Ja da habe ich den Namen verwechselt mit Tim. Entschuldigung. Es ist mir alles zuviel heute Abend. Werfe schon alles durcheinander.
    Zunächst mal ganz herzlichen Dank für Eure Hinweise heute Abend. Werde mich morgen nochmal versuchen ein Stück weiter zu kommen, und nochmal alles durch zu lesen. Jetzt muß ich erst mal stoppen hier, denn meine Augen machen nicht mehr mit.
    Für den Inhalt des Beitrages 37927 haftet ausdrücklich der jeweilige Autor: Oliver59
