Probleme mit Asus N13 unter openSuse 12.3
Hinweis: In dem Thema Probleme mit Asus N13 unter openSuse 12.3 gibt es 42 Antworten auf 5 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
  • Hier ein Auszug aus /var/log/messages nachdem die verbindung weg war, das könnte was bringen:
    Quellcode
    1. 2013-06-09T12:37:15.138057+02:00 *USERNAME* cupsd[1427]: No limit for Validate-Job defined in policy allowallforanybody and no suitable template found.
    2. 2013-06-09T12:37:15.138541+02:00 *USERNAME* cupsd[1427]: No limit for Cancel-Jobs defined in policy allowallforanybody and no suitable template found.
    3. 2013-06-09T12:37:15.138954+02:00 *USERNAME* cupsd[1427]: No limit for Cancel-My-Jobs defined in policy allowallforanybody and no suitable template found.
    4. 2013-06-09T12:37:15.139367+02:00 *USERNAME* cupsd[1427]: No limit for Close-Job defined in policy allowallforanybody and no suitable template found.
    5. 2013-06-09T12:37:15.139657+02:00 *USERNAME* cupsd[1427]: No limit for CUPS-Get-Document defined in policy allowallforanybody and no suitable template found.
    6. 2013-06-09T12:37:15.139878+02:00 *USERNAME* cupsd[1427]: No JobPrivateAccess defined in policy allowallforanybody - using defaults.
    7. 2013-06-09T12:37:15.140402+02:00 *USERNAME* cupsd[1427]: No JobPrivateValues defined in policy allowallforanybody - using defaults.
    8. 2013-06-09T12:37:15.140837+02:00 *USERNAME* cupsd[1427]: No SubscriptionPrivateAccess defined in policy allowallforanybody - using defaults.
    9. 2013-06-09T12:37:15.141348+02:00 *USERNAME* cupsd[1427]: No SubscriptionPrivateValues defined in policy allowallforanybody - using defaults.
    10. 2013-06-09T12:37:46.668645+02:00 *USERNAME* systemd[1]: Mounting FUSE Control File System...
    11. 2013-06-09T12:37:46.668949+02:00 *USERNAME* kernel: [ 48.214519] fuse init (API version 7.20)
    12. 2013-06-09T12:37:46.676200+02:00 *USERNAME* systemd[1]: Mounted FUSE Control File System.
    und jetzt kommts:
    Quellcode
    1. 2013-06-09T12:38:01.197959+02:00 *USERNAME* kernel: [ 62.735335] wlan1: deauthenticated from *MAC-ADRESSE* (Reason: 7)
    noch mehr:
    Quellcode
    1. 2013-06-09T12:38:01.227949+02:00 *USERNAME* kernel: [ 62.764840] cfg80211: Calling CRDA to update world regulatory domain
    2. 2013-06-09T12:38:01.228951+02:00 *USERNAME* kernel: [ 62.766261] cfg80211: World regulatory domain updated:
    3. 2013-06-09T12:38:01.228955+02:00
    4. *USERNAME* kernel: [ 62.766263] cfg80211: (start_freq - end_freq @
    5. bandwidth), (max_antenna_gain, max_eirp)
    6. 2013-06-09T12:38:01.228956+02:00
    7. *USERNAME* kernel: [ 62.766264] cfg80211: (2402000 KHz - 2472000
    8. KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    9. 2013-06-09T12:38:01.228956+02:00
    10. *USERNAME* kernel: [ 62.766265] cfg80211: (2457000 KHz - 2482000
    11. KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    12. 2013-06-09T12:38:01.228957+02:00
    13. *USERNAME* kernel: [ 62.766266] cfg80211: (2474000 KHz - 2494000
    14. KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    15. 2013-06-09T12:38:01.228958+02:00
    16. *USERNAME* kernel: [ 62.766266] cfg80211: (5170000 KHz - 5250000
    17. KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    18. 2013-06-09T12:38:01.228958+02:00
    19. *USERNAME* kernel: [ 62.766267] cfg80211: (5735000 KHz - 5835000
    20. KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    21. 2013-06-09T12:38:16.564229+02:00
    22. *USERNAME* dbus-daemon[634]: dbus[634]: [system] Activating service
    23. name='org.freedesktop.nm_dispatcher' (using servicehelper)
    24. 2013-06-09T12:38:16.564635+02:00
    25. *USERNAME* dbus[634]: [system] Activating service
    26. name='org.freedesktop.nm_dispatcher' (using servicehelper)
    27. 2013-06-09T12:38:16.568692+02:00
    28. *USERNAME* dbus-daemon[634]: dbus[634]: [system] Successfully activated
    29. service 'org.freedesktop.nm_dispatcher'
    30. 2013-06-09T12:38:16.569148+02:00 *USERNAME* dbus[634]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
    auch noch interessant evtl.
    Quellcode
    1. 2013-06-09T12:38:16.765303+02:00 *USERNAME* avahi-daemon[585]: Withdrawing address record for 192.168.2.102 on wlan1.
    2. 2013-06-09T12:38:16.765712+02:00
    3. *USERNAME* avahi-daemon[585]: Leaving mDNS multicast group on interface
    4. wlan1.IPv4 with address 192.168.2.102.
    5. 2013-06-09T12:38:16.766001+02:00 *USERNAME* avahi-daemon[585]: Interface wlan1.IPv4 no longer relevant for mDNS.
    Für den Inhalt des Beitrages 56783 haftet ausdrücklich der jeweilige Autor: peaceFul
