Moin zusammen,
nachdem mein NAS an der Fritzbox jetzt soweit läuft, kam ein neues Problem auf.
Der Zielordner kann beim Systemstart nicht gemounted werden.
Dazu meine boot.log:
Trying manual resume from /dev/disk/by-id/ata-SAMSUNG_HM060HI_S0BNJ10L903097-part1
Invoking userspace resume from /dev/disk/by-id/ata-SAMSUNG_HM060HI_S0BNJ10L903097-part1
resume: libgcrypt version: 1.5.3
Invoking in-kernel resume from /dev/disk/by-id/ata-SAMSUNG_HM060HI_S0BNJ10L903097-part1
Waiting for device /dev/root to appear: ok
fsck from util-linux 2.21.2
[/sbin/fsck.ext4 (1) -- /] fsck.ext4 -a /dev/sda2
/dev/sda2: clean, 245752/655360 files, 1969999/2620672 blocks
fsck succeeded. Mounting root device read-write.
Mounting root /dev/root
mount -o rw,acl,user_xattr -t ext4 /dev/root /root
Welcome to [0;32mopenSUSE 12.3 (Dartmouth) (i586)[0m!
Starting Collect Read-Ahead Data...
Starting Replay Read-Ahead Data...
[[1;32m OK [0m] Reached target System Time Synchronized.
[[1;32m OK [0m] Listening on Syslog Socket.
[[1;32m OK [0m] Listening on /dev/initctl Compatibility Named Pipe.
[[1;32m OK [0m] Listening on Delayed Shutdown Socket.
[[1;32m OK [0m] Reached target Encrypted Volumes.
[[1;32m OK [0m] Set up automount Arbitrary Executable File Formats File System Automount Point.
[[1;32m OK [0m] Listening on udev Kernel Socket.
[[1;32m OK [0m] Listening on udev Control Socket.
Expecting device dev-disk-by\x2did-ata\x2dSAMSUNG_HM060HI_S0BNJ10L903097\x2dpart1.device...
Expecting device dev-disk-by\x2did-ata\x2dSAMSUNG_HM060HI_S0BNJ10L903097\x2dpart3.device...
[[1;32m OK [0m] Listening on Journal Socket.
Mounting POSIX Message Queue File System...
Mounting Huge Pages File System...
Starting Create dynamic rule for /dev/root link...
Starting Journal Service...
[[1;32m OK [0m] Started Journal Service.
Starting LSB: Set default boot entry if called...
[[1;32m OK [0m] Started Collect Read-Ahead Data.
[[1;32m OK [0m] Started Replay Read-Ahead Data.
Starting Setup Virtual Console...
Starting Load Kernel Modules...
Starting Remount Root and Kernel File Systems...
[[1;32m OK [0m] Started Load Kernel Modules.
Starting Apply Kernel Variables...
[[1;32m OK [0m] Started Apply Kernel Variables.
[[1;32m OK [0m] Mounted Huge Pages File System.
[[1;32m OK [0m] Mounted POSIX Message Queue File System.
[[1;32m OK [0m] Started Remount Root and Kernel File Systems.
Starting Load Random Seed...
[[1;32m OK [0m] Started Load Random Seed.
[[1;32m OK [0m] Started Create dynamic rule for /dev/root link.
Starting udev Kernel Device Manager...
[[1;32m OK [0m] Started LSB: Set default boot entry if called.
[[1;32m OK [0m] Started udev Kernel Device Manager.
[[1;32m OK [0m] Reached target Local File Systems (Pre).
Mounting Lock Directory...
Mounting /sys/kernel/debug...
Mounting Runtime Directory...
[[1;32m OK [0m] Mounted Lock Directory.
[[1;32m OK [0m] Mounted /sys/kernel/debug.
[[1;32m OK [0m] Mounted Runtime Directory.
%G[[1;32m OK [0m] Started Setup Virtual Console.
Starting udev Coldplug all Devices...
[[1;32m OK [0m] Started udev Coldplug all Devices.
Starting Show Plymouth Boot Screen...
[[1;32m OK [0m] Started Show Plymouth Boot Screen.
[[1;32m OK [0m] Reached target Sound Card.
[[1;32m OK [0m] Found device SAMSUNG_HM060HI.
Starting File System Check on /dev/disk/by-id/ata-SAMSUNG_HM060HI_S0BNJ10L903097-part3...
Activating swap /dev/disk/by-id/ata-SAMSUNG_HM060HI_S0BNJ10L903097-part1...
[[1;32m OK [0m] Activated swap /dev/disk/by-id/ata-SAMSUNG_HM060HI_S0BNJ10L903097-part1.
[[1;32m OK [0m] Reached target Swap.
systemd-fsck[471]: /dev/sda3: sauber, 37642/2256576 Dateien, 539348/9014272 Blöcke
[[1;32m OK [0m] Started File System Check on /dev/disk/by-id/ata-SAMSUNG_HM060HI_S0BNJ10L903097-part3.
Mounting /home...
[[1;32m OK [0m] Mounted /home.
[[1;32m OK [0m] Reached target Local File Systems.
Starting Tell Plymouth To Write Out Runtime Data...
Starting Recreate Volatile Files and Directories...
[[1;32m OK [0m] Started Recreate Volatile Files and Directories.
[[1;32m OK [0m] Started Tell Plymouth To Write Out Runtime Data.
[[1;32m OK [0m] Reached target System Initialization.
[[1;32m OK [0m] Listening on CUPS Printing Service Sockets.
[[1;32m OK [0m] Listening on RPCbind Server Activation Socket.
[[1;32m OK [0m] Reached target RPC Port Mapper.
[[1;32m OK [0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Starting Restore Sound Card State...
[[1;32m OK [0m] Listening on D-Bus System Message Bus Socket.
[[1;32m OK [0m] Reached target Sockets.
[[1;32m OK [0m] Reached target Basic System.
Starting Bluetooth service...
Starting LSB: Framebuffer setup...
Starting Avahi mDNS/DNS-SD Stack...
Starting System Logging Service...
Starting Network Manager Script Dispatcher Service...
Starting Haveged Entropy Gathering Daemon...
[[1;32m OK [0m] Started Haveged Entropy Gathering Daemon.
Starting Login Service...
Starting RPC Bind...
[[1;32m OK [0m] Started RPC Bind.
Starting SuSEfirewall2 phase 1...
[[1;32m OK [0m] Started SuSEfirewall2 phase 1.
[[1;32m OK [0m] Started Restore Sound Card State.
[[1;32m OK [0m] Started LSB: Framebuffer setup.
[[1;32m OK [0m] Started System Logging Service.
[[1;32m OK [0m] Reached target Syslog.
Starting D-Bus System Message Bus...
[[1;32m OK [0m] Started D-Bus System Message Bus.
Starting Name Service Cache Daemon...
[[1;32m OK [0m] Started Name Service Cache Daemon.
Starting Network Manager...
[[1;32m OK [0m] Started Avahi mDNS/DNS-SD Stack.
[[1;32m OK [0m] Started Bluetooth service.
[[1;32m OK [0m] Started Network Manager Script Dispatcher Service.
[[1;32m OK [0m] Reached target Bluetooth.
[[1;32m OK [0m] Started Login Service.
Starting Authorization Manager...
[[1;32m OK [0m] Started Authorization Manager.
[[1;32m OK [0m] Started Network Manager.
Starting Network Manager Wait Online...
[[1;32m OK [0m] Started Network Manager Wait Online.
[[1;32m OK [0m] Reached target Network.
Starting Command Scheduler...
[[1;32m OK [0m] Started Command Scheduler.
Starting LSB: NFS client services...
Starting LSB: Samba NetBIOS naming service over IP...
[[1;32m OK [0m] Reached target Host and Network Name Lookups.
[[1;32m OK [0m] Started LSB: Samba NetBIOS naming service over IP.
[[1;32m OK [0m] Started LSB: NFS client services.
[[1;32m OK [0m] Reached target Remote File Systems (Pre).
Mounting /home/eike/fritznas...
Starting SuSEfirewall2 phase 2...
[[1;32m OK [0m] Started SuSEfirewall2 phase 2.
[color=#ff0000][[1;31mFAILED[0m] Failed to mount /home/eike/fritznas.
See 'systemctl status home-eike-fritznas.mount' for details.[/color]
[[1;33mDEPEND[0m] Dependency failed for Remote File Systems.
[[1;33mDEPEND[0m] Dependency failed for Postfix Mail Transport Agent.
Starting LSB: Samba SMB/CIFS file and print server...
Starting LSB: Starts the xinet daemon. Be aware that xinetd doesn't start if no service is configured to run und...twork Services (xinetd) section....
Starting Trigger Flushing of Journal to Persistent Storage...
[[1;32m OK [0m] Started Trigger Flushing of Journal to Persistent Storage.
Starting Permit User Sessions...
[[1;32m OK [0m] Started Permit User Sessions.
Starting LSB: X Display Manager...
Starting Getty on tty1...
[[1;32m OK [0m] Started Getty on tty1.
[[1;32m OK [0m] Reached target Login Prompts.
[[1;32m OK [0m] Started LSB: X Display Manager.
Zum Hinweis in der 2. Zeile See 'systemctl status home-eike-fritznas.mount' for details. spuckt er folgendes aus:
linux-266h:~ # systemctl status home-eike-fritznas.mount
home-eike-fritznas.mount - /home/eike/fritznas
Loaded: loaded (/etc/fstab)
Active: failed (Result: exit-code) since Sat, 2013-10-05 09:13:25 CEST; 5min ago
Where: /home/eike/fritznas
What: //192.168.178.2/ExcelSto-rTechnologyJ81-01
Process: 629 ExecMount=/bin/mount //192.168.178.2/ExcelSto-rTechnologyJ81-01 /home/eike/fritznas -t cifs -o auto,rw,users,credentials=/etc/samba/auth.192.168.178.2.ftpuser (code=exited, status=32)
CGroup: name=systemd:/system/home-eike-fritznas.mount
Oct 05 09:13:25 linux-266h.site mount[629]: mount error(101): Network is unreachable
Oct 05 09:13:25 linux-266h.site mount[629]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Oct 05 09:13:25 linux-266h.site systemd[1]: Failed to mount /home/eike/fritznas.
Oct 05 09:13:25 linux-266h.site systemd[1]: Unit home-eike-fritznas.mount entered failed state
Allerdings läßt sich das Problem zu Fuß per mount -a lösen. Das möchte ich mir aber auf die Dauer ersparen, zumal auch mein Weibchen an meinen Läppi geht und sie so garnicht mit Linux kann. Da will ich ihr das ganze ersparen.
DAS Feuerchen
Code-Ausgaben geändert.
