Ok ich konnte alles einstellen und mein Router find ich auch , aber das verbindet nicht.. auch nach restart nicht.
Die Befehle brauchten:
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11bg ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo Interface doesn't support scanning.
eth0 Interface doesn't support scanning.
wmaster0 Interface doesn't support scanning.
wlan0 Scan completed :
Cell 01 - Address: 00:1F:9F:E9:04:0F
Channel:1
Frequency:2.412 GHz (Channel 1)
Quality=53/70 Signal level=-57 dBm
Encryption key:on
ESSID:"ThomsonD"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=00000009e753c184
Extra: Last beacon: 1706ms ago
IE: Unknown: 000D54686F6D736F6E313539414437
IE: Unknown: 010882848B962430486C
IE: Unknown: 030101
IE: Unknown: 2A0100
IE: Unknown: 2F0100
IE: Unknown: 32040C121860
IE: Unknown: DD870050F204104A0001101044000102103B000103104700102B389A62B76F50F5855B806536E463351021000754484F4D534F4E1023000A54686F6D736F6E20544710240006353835207637104200093038343953464B34341054000800060050F20400011011001054686F6D736F6E20544735383520763710080002008810570001001041000100
IE: Unknown: DD060010180200F0
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (1) : TKIP
Authentication Suites (1) : PSK
Kernel IP Routentabelle
Ziel Router Genmask Flags Metric Ref Use Iface
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
### /etc/resolv.conf file autogenerated by netconfig!
# Before you change this file manually, consider to define the
# static DNS configuration using the following variables in the
# /etc/sysconfig/network/config file:
# NETCONFIG_DNS_STATIC_SEARCHLIST
# NETCONFIG_DNS_STATIC_SERVERS
# NETCONFIG_DNS_FORWARDER
# or disable DNS configuration updates via netconfig by setting:
# NETCONFIG_DNS_POLICY=''
# See also the netconfig(8) manual page and other documentation.
# Note: Manual change of this file disables netconfig too, but
# may get lost when this file contains comments or empty lines
# only, the netconfig settings are same with settings in this
# file and in case of a "netconfig update -f" call.
### Please remove (at least) this line when you modify the file!
