leider bekomme ich Zoneminder 1.27 unter Linux 13.1 oder 12.3 nicht zum laufen, ich kann den Apache2 Server starten, wenn zoneminder noch nicht installiert wurde danach geht nichts.
mws200:/home/otto # systemctl start mysql.service
mws200:/home/otto # systemctl start apache2.service
Job for apache2.service failed. See 'systemctl status apache2.service' and 'journalctl -xn' for details.
mws200:/home/otto # systemctl status apache2.service
apache2.service - The Apache Webserver
Loaded: loaded (/usr/lib/systemd/system/apache2.service; enabled)
Active: failed (Result: exit-code) since So 2014-06-22 16:52:49 CEST; 1min 24s ago
Process: 12135 ExecStop=/usr/sbin/start_apache2 -D SYSTEMD -DFOREGROUND -k graceful-stop (code=exited, status=1/FAILURE)
Process: 12117 ExecStart=/usr/sbin/start_apache2 -D SYSTEMD -DFOREGROUND -k start (code=exited, status=1/FAILURE)
Main PID: 12117 (code=exited, status=1/FAILURE)
Jun 22 16:52:48 mws200 start_apache2[12117]: [Sun Jun 22 16:52:48.850397 201....
Jun 22 16:52:48 mws200 start_apache2[12117]: AH00526: Syntax error on line 3...:
Jun 22 16:52:48 mws200 start_apache2[12117]: Invalid command 'php_admin_flag...n
Jun 22 16:52:48 mws200 systemd[1]: apache2.service: main process exited, co...RE
Jun 22 16:52:49 mws200 start_apache2[12135]: [Sun Jun 22 16:52:49.133429 201....
Jun 22 16:52:49 mws200 start_apache2[12135]: AH00526: Syntax error on line 3...:
Jun 22 16:52:49 mws200 start_apache2[12135]: Invalid command 'php_admin_flag...n
Jun 22 16:52:49 mws200 systemd[1]: apache2.service: control process exited,...=1
Jun 22 16:52:49 mws200 systemd[1]: Failed to start The Apache Webserver.
Jun 22 16:52:49 mws200 systemd[1]: Unit apache2.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
mws200:/home/otto # journalctl -xn
-- Logs begin at So 2014-06-22 15:29:11 CEST, end at So 2014-06-22 16:54:01 CEST
Jun 22 16:52:49 mws200 start_apache2[12135]: AH00526: Syntax error on line 3 of
Jun 22 16:52:49 mws200 start_apache2[12135]: Invalid command 'php_admin_flag', p
Jun 22 16:52:49 mws200 systemd[1]: apache2.service: control process exited, code
-- Subject: Unit apache2.service has failed
-- Defined-By: systemd
-- Unit apache2.service has failed.
-- The result is failed.
Jun 22 16:54:01 mws200 /usr/sbin/cron[12231]: pam_unix(crond:session): session o
Jun 22 16:54:01 mws200 systemd[1]: Starting Session 96 of user root.
-- Subject: Unit session-96.scope has begun with start-up
-- Unit session-96.scope has begun starting up.
Jun 22 16:54:01 mws200 systemd[1]: Started Session 96 of user root.
-- Subject: Unit session-96.scope has finished start-up
-- Unit session-96.scope has finished starting up.
-- The start-up result is done.
Jun 22 16:54:01 mws200 /USR/SBIN/CRON[12232]: (root) CMD (/usr/local/bin/checkSM
Jun 22 16:54:01 mws200 /USR/SBIN/CRON[12231]: pam_unix(crond:session): session c
lines 1-31/31 (END)
