Das ist der abschnitt zwischen skype ausführen und neustart
p, li { white-space: pre-wrap; } Jan 17 19:09:22 linux-p49z ifdown: wlan0 name: RTL8187_Wireless_LAN_Adapter
Jan 17 19:09:23 linux-p49z ifup: wlan0 name: RTL8187_Wireless_LAN_Adapter
Jan 17 19:09:23 linux-p49z SuSEfirewall2: /var/lock/SuSEfirewall2.booting exists which means system boot in progress, exit.
Jan 17 19:09:23 linux-p49z dhcpcd[2837]: wlan0: setting hostname to `linux-p49z'
Jan 17 19:09:23 linux-p49z dhcpcd[2837]: wlan0: exiting
Jan 17 19:09:23 linux-p49z ifup-dhcp:
Jan 17 19:09:23 linux-p49z ifup-dhcp: wlan0 IP address: 192.168.178.42/24
Jan 17 19:09:23 linux-p49z SuSEfirewall2: Setting up rules from /etc/sysconfig/SuSEfirewall2 ...
Jan 17 19:09:23 linux-p49z SuSEfirewall2: using default zone 'ext' for interface eth0
Jan 17 19:09:23 linux-p49z SuSEfirewall2: using default zone 'ext' for interface wlan0
Jan 17 19:09:23 linux-p49z SuSEfirewall2: using default zone 'ext' for interface wmaster0
Jan 17 19:09:24 linux-p49z SuSEfirewall2: batch committing...
Jan 17 19:09:24 linux-p49z SuSEfirewall2: Firewall rules successfully set
Jan 17 19:09:24 linux-p49z kernel: [ 32.520446] bootsplash: status on console 0 changed to on
Jan 17 19:09:29 linux-p49z kernel: [ 38.360280] wlan0: no IPv6 routers present
Jan 17 19:10:02 linux-p49z kernel: [ 71.149341] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1295: 2:2:1: cannot get freq at ep 0x84
Jan 17 19:10:02 linux-p49z kernel: [ 71.334055] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1295: 2:2:1: cannot get freq at ep 0x84
Jan 17 19:10:02 linux-p49z kernel: [ 71.335045] ehci_hcd 0000:00:12.2: force halt; handhake f78e8024 00004000 00000000 -> -110
Jan 17 19:10:02 linux-p49z kernel: [ 71.335045] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:882: cannot submit datapipe for urb 1, error -108: device disabled
Jan 17 19:10:03 linux-p49z kernel: [ 71.410244] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410262] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410266] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410269] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410274] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410279] hub 1-0:1.0: Cannot enable port 4. Maybe the USB cable is bad?
Jan 17 19:10:03 linux-p49z kernel: [ 71.410285] hub 1-0:1.0: cannot disable port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410291] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410296] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410302] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410307] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410312] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410318] hub 1-0:1.0: Cannot enable port 4. Maybe the USB cable is bad?
Jan 17 19:10:03 linux-p49z kernel: [ 71.410324] hub 1-0:1.0: cannot disable port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410330] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410335] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410340] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410353] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410362] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410371] hub 1-0:1.0: Cannot enable port 4. Maybe the USB cable is bad?
Jan 17 19:10:03 linux-p49z kernel: [ 71.410380] hub 1-0:1.0: cannot disable port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410387] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410394] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410401] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410411] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410420] hub 1-0:1.0: cannot reset port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410428] hub 1-0:1.0: Cannot enable port 4. Maybe the USB cable is bad?
Jan 17 19:10:03 linux-p49z kernel: [ 71.410438] hub 1-0:1.0: cannot disable port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410447] hub 1-0:1.0: cannot disable port 4 (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 71.410493] hub 1-0:1.0: hub_port_status failed (err = -108)
Jan 17 19:10:03 linux-p49z kernel: [ 72.338165] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:934: timeout: still 1 active urbs..
Jan 17 19:10:03 linux-p49z kernel: [ 72.398646] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.458377] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.505331] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.552267] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.600307] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.647289] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.694314] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.741266] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.789280] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.837564] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.884290] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.931924] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 72.981361] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 73.029307] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:04 linux-p49z kernel: [ 73.076268] ALSA /usr/src/packages/BUILD/kernel-desktop-2.6.31.8/linux-2.6.31/sound/usb/usbaudio.c:1346: 2:2:1: usb_set_interface failed
Jan 17 19:10:08 linux-p49z kernel: [ 76.746169] wlan0: no probe response from AP 00:04:0e:88:83:23 - disassociating
Jan 17 19:12:08 linux-p49z shutdown[6412]: shutting down for system reboot
