Habe jetzt die HDD mit 1 TB neu mit ext4 formatiert und alle Daten zurückgespielt. War vorher XFS, bis sie nicht mehr gemounted werden konnte.
Statusbericht der Platte:
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.15.8-1-default] (SUSE RPM)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Samsung SpinPoint M8 (AF)
Device Model: ST1000LM024 HN-M101MBB
Serial Number: S30YJ9GG927123
LU WWN Device Id: 5 0004cf 210b85106
Firmware Version: 2BA30001
User Capacity: 1.000.204.886.016 bytes [1,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database 7.5/5706
ATA Version is: ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Aug 5 16:55:18 2025 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: (12720) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 212) minutes.
SCT capabilities: (0x003f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 4170
2 Throughput_Performance 0x0026 053 053 000 Old_age Always - 12182
3 Spin_Up_Time 0x0023 092 081 025 Pre-fail Always - 2477
4 Start_Stop_Count 0x0032 097 097 000 Old_age Always - 3044
5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0
8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 13666
10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 354
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 3023
191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 115
192 Power-Off_Retract_Count 0x0022 100 100 000 Old_age Always - 146
194 Temperature_Celsius 0x0002 064 054 000 Old_age Always - 34 (Min/Max 15/46)
195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 2
198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0036 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 14140
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 354
225 Load_Cycle_Count 0x0032 082 082 000 Old_age Always - 191840
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed: read failure 90% 13666 976966520
# 2 Short offline Completed without error 00% 13658 -
# 3 Extended offline Aborted by host 70% 13656 -
# 4 Short offline Completed without error 00% 13650 -
# 5 Short offline Completed without error 00% 13640 -
# 6 Short offline Completed without error 00% 13634 -
# 7 Short offline Completed without error 00% 13627 -
# 8 Short offline Completed without error 00% 13621 -
# 9 Short offline Completed without error 00% 13610 -
#10 Short offline Completed without error 00% 13606 -
#11 Short offline Completed without error 00% 13604 -
#12 Short offline Completed without error 00% 13603 -
#13 Short offline Completed without error 00% 13596 -
#14 Short offline Completed without error 00% 13588 -
#15 Short offline Completed without error 00% 13580 -
#16 Short offline Completed without error 00% 13574 -
#17 Short offline Completed without error 00% 13571 -
#18 Short offline Completed without error 00% 13562 -
#19 Short offline Completed without error 00% 13555 -
#20 Short offline Completed without error 00% 13548 -
#21 Short offline Completed without error 00% 13544 -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Completed_read_failure [90% left] (0-65535)
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
Könnte die Platte doch so weiterverwendet werden?
