:smilie_pc_027:Hi openSUSE Forum =)
Folgendes Problem: Ich hab kürzlich openSUSE 11.1 auf meinem PC installiert und hab ums verrecken das WLAN nich zum laufen gebracht. Daraufhin hab ich mal recherchiert und bin auf das Script collectNWData gestoßen.
Meine Netzwerkkarte trägt den Namen
BCM4318 [Airforce One 54g] 802.11g
Die Ausgabe des Scripts sieht so aus:
collectNWData.sh V0.6.1.15 (Rev: 1.165, Build: 2009/09/02 18:39:22)
--- Which type of your network connection should be tested?
--- (2) Wireless connection (WLAN)
--- What's the type of networktopology?
--- (2) WLAN HW router <---> LinuxClient
--- On which host is the script executed?
--- (1) LinuxClient
!!! CND0120E: Network card wlan0 has no IP address
!!! CND0380E: No WLANs detected on interface wlan0. Hardware and/or driver not configured properly
!!! CND0190W: There seems to be a problem with the WLAN firmware
!!! CND0230W: IPV6 enabled
!!! CND0240E: knetworkmanager for network configuration enabled but network card configuration for eth0 detected
--- Go to [URL]http://www.linux-tips-and-tricks.de/CND#English[/URL] to get more detailed instructions about the error/warning messages and how to fix the problems
--- If you still don't have success then post the contents of file collectNWData.txt in the net (see [URL]http://www.linux-tips-and-tricks.de/CND_UPL#English[/URL] for links) and then the nopaste link on your favorite Linux forum.
*** uname -a
Linux linux 2.6.27.7-9-default #1 SMP 2008-12-04 18:10:04 +0100 i686 i686 i386 GNU/Linux
*** cat /etc/*-release
openSUSE 11.1 (i586)
VERSION = 11.1
*** cat /etc/resolv | grep -vi "search"
*** cat /etc/hosts
127.0.0.1 localhost
127.0.0.2 linux.site linux
*** cat /etc/HOSTNAME
linux.site
*** route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
*** ifconfig
eth0 Link encap:Ethernet HWaddr ##:##:##:##:##:#1
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Memory:fdfc0000-fdfe0000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:72 errors:0 dropped:0 overruns:0 frame:0
TX packets:72 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:4760 (4.6 Kb) TX bytes:4760 (4.6 Kb)
*** ping tests
connect: Network is unreachable
Ping of 195.135.220.3 failed
ping: unknown host [URL='http://www.suse.de']www.suse.de[/URL]
Ping of [URL='http://www.suse.de']www.suse.de[/URL] failed
*** dhcpcd-test
wlan0: No DHCP server detected
*** lspci
00:19.0 Ethernet controller [0200]: Intel Corporation 82562V-2 10/100 Network Connection [8086:10c0] (rev 02)
02:00.0 Network controller [0280]: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller [14e4:4318] (rev 02)
*** lsusb
Bus 008 Device 004: ID 0781:5406 SanDisk Corp. Cruzer Micro 1/2/4GB Flash Drive
Bus 008 Device 003: ID 0644:0200 TEAC Corp.
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 002: ID 1058:1100 Western Digital Technologies, Inc.
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 003: ID 046d:c525 Logitech, Inc.
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 004: ID 413c:2105 Dell Computer Corp.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
*** hwinfo --netcard; # (filtered)
11: PCI 19.0: 0200 Ethernet controller
Model: "Intel 82562V-2 10/100 Network Connection"
Device: pci 0x10c0 "82562V-2 10/100 Network Connection"
SubVendor: pci 0x1028 "Dell"
SubDevice: pci 0x020d
Driver: "e1000e"
Driver Modules: "e1000e"
Device File: eth0
Link detected: no
Driver Status: e1000e is active
Driver Activation Cmd: "modprobe e1000e"
28: PCI 200.0: 0282 WLAN controller
Model: "ASUSTeK WL-138G V2 802.11g WLAN PCI Card"
Vendor: pci 0x14e4 "Broadcom"
Device: pci 0x4318 "BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller"
SubVendor: pci 0x1043 "ASUSTeK Computer Inc."
SubDevice: pci 0x100f "WL-138G V2 802.11g WLAN PCI Card"
Driver: "b43-pci-bridge"
Driver Modules: "ssb"
Device File: wlan0
Driver Status: ssb is active
Driver Activation Cmd: "modprobe ssb"
*** lsmod
| acpi_cpufreq | af_packet | agpgart | ahci |
| arc4 | ata_piix | aufs | b43 |
| binfmt_misc | brd | BusLogic | button |
| cdrom | cfg80211 | cpufreq_conservative | cpufreq_powersave |
| cpufreq_userspace | crc_t10dif | crypto_blkcipher | dcdbas |
| dm_mod | dock | e1000e | ecb |
| edd | ehci_hcd | fan | fat |
| ff_memless | floppy | fuse | hid |
| hwmon | i2c_core | i2c_i801 | ide_cd_mod |
| ide_core | ide_disk | input_polldev | intel_agp |
| ipv6 | iTCO_vendor_support | iTCO_wdt | joydev |
| led_class | libata | loop | mac80211 |
| nls_cp437 | nls_iso8859_1 | nls_utf8 | parport |
| parport_pc | pcmcia | pcmcia_core | pcspkr |
| processor | rfkill | rfkill_input | rtc_cmos |
| rtc_core | rtc_lib | scsi_mod | sd_mod |
| serio_raw | sg | snd | snd_hda_intel |
| snd_hwdep | snd_mixer_oss | snd_page_alloc | snd_pcm |
| snd_pcm_oss | snd_seq | snd_seq_device | snd_timer |
| soundcore | speedstep_lib | squashfs | sr_mod |
| ssb | st | thermal | thermal_sys |
| uhci_hcd | usbcore | usbhid | usb_storage |
| vfat |
