folgendes Problem:
Nach Online Update von der letzten 42er Version via Leap15.0 auf Leap15.1 ist mein Bluetooth weg. kde meldet "Kein Adapter verfügbar".
System: Leap15.1, Broadcom-Chip.
Auf Basis von Kein Bluetooth bei 15 habe ich inzwischen von github das richtige hcd und einen Fehler weniger. Aber nun komme ich nicht weiter ![]()
Aus den Log-Files:
journalctl -b | grep -Ei 'blue|firm'
Aug 07 22:24:31 localhost kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
Aug 07 22:24:31 localhost kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Aug 07 22:24:31 localhost kernel: pnp 00:01: [Firmware Bug]: PNP resource [mem 0xfed10000-0xfed13fff] covers only part of 0000:00:00.0 Intel MCH; extending to [mem 0xfed10000-0xfed17fff]
Aug 07 22:24:31 localhost kernel: psmouse serio2: trackpoint: IBM TrackPoint firmware: 0x0e, buttons: 3/3
Aug 07 22:24:42 localhost kernel: thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
Aug 07 22:24:43 localhost kernel: Bluetooth: Core ver 2.22
Aug 07 22:24:43 localhost kernel: Bluetooth: HCI device and connection manager initialized
Aug 07 22:24:43 localhost kernel: Bluetooth: HCI socket layer initialized
Aug 07 22:24:43 localhost kernel: Bluetooth: L2CAP socket layer initialized
Aug 07 22:24:43 localhost kernel: Bluetooth: SCO socket layer initialized
Aug 07 22:24:43 localhost kernel: iwlwifi 0000:03:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
Aug 07 22:24:43 localhost kernel: Bluetooth: hci0: BCM: chip id 63
Aug 07 22:24:43 localhost kernel: Bluetooth: hci0: BCM20702A
Aug 07 22:24:43 localhost kernel: Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
Aug 07 22:24:44 localhost kernel: Bluetooth: hci0: BCM20702A1 (001.002.014) build 1757
Aug 07 22:24:44 localhost kernel: Bluetooth: hci0: Broadcom Bluetooth Device
Aug 07 22:25:03 localhost kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 07 22:25:03 localhost kernel: Bluetooth: BNEP filters: protocol multicast
Aug 07 22:25:03 localhost kernel: Bluetooth: BNEP socket layer initialized
Aug 07 22:25:02 localhost bluetoothd[947]: Bluetooth daemon 5.48
Aug 07 22:25:02 localhost bluetoothd[947]: Starting SDP server
Aug 07 22:25:02 localhost dbus-daemon[844]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.4' (uid=0 pid=947 comm="/usr/lib/bluetooth/bluetoothd ")
Aug 07 22:25:02 localhost bluetoothd[947]: Bluetooth management interface 1.14 initialized
Aug 07 22:25:01 localhost systemd[1]: Starting Bluetooth service...
Aug 07 22:25:02 localhost systemd[1]: Started Bluetooth service.
Aug 07 22:25:02 localhost systemd[1]: Reached target Bluetooth.
Aug 07 22:25:06 localhost NetworkManager[1082]: <info> [1565209506.4352] manager[0x563708f62070]: monitoring kernel firmware directory '/lib/firmware'.
Aug 07 22:25:07 localhost NetworkManager[1082]: <info> [1565209507.6364] Loaded device plugin: NMBluezManager (/usr/lib64/NetworkManager/libnm-device-plugin-bluetooth.so)
Aug 07 22:25:08 localhost NetworkManager[1082]: <info> [1565209508.9607] bluez: use BlueZ version 5
Aug 07 22:25:35 localhost.localdomain dbus-daemon[1607]: [session uid=1000 pid=1607] Activating service name='org.bluez.obex' requested by ':1.5' (uid=1000 pid=1693 comm="kded5 [kdeinit5] ")
Aug 07 22:25:35 localhost.localdomain dbus-daemon[1607]: [session uid=1000 pid=1607] Successfully activated service 'org.bluez.obex'
Aug 07 22:25:35 localhost.localdomain kdeinit5[1693]: bluedevil: Created
Aug 07 22:25:35 localhost.localdomain kdeinit5[1693]: bluedevil: ObexManager operational changed false
Aug 07 22:25:35 localhost.localdomain kdeinit5[1693]: org.kde.bluez: GetManagerJob Error: "Cannot find org.bluez.Media1 object!"
Aug 07 22:25:35 localhost.localdomain kdeinit5[1693]: bluedevil: Error initializing manager: "Cannot find org.bluez.Media1 object!"
Aug 07 22:25:36 localhost.localdomain kdeinit5[1693]: bluedevil: ObexManager operational changed true
Aug 07 22:25:36 localhost.localdomain kdeinit5[1693]: bluedevil: ObexAgent registered
Aug 07 22:25:50 localhost.localdomain plasmashell[1741]: Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/code/logic.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js")
Aug 07 22:25:50 localhost.localdomain plasmashell[1741]: org.kde.plasmaquick: New Applet "Bluetooth" with a weight of 42
Aug 07 22:25:51 localhost.localdomain plasmashell[1741]: org.kde.bluez: GetManagerJob Error: "Cannot find org.bluez.Media1 object!"
Aug 07 22:25:54 localhost.localdomain plasmashell[1741]: org.kde.plasmaquick: Delayed preload of "Bluetooth" after 3.626 seconds
Aug 07 22:25:54 localhost.localdomain plasmashell[1741]: org.kde.plasmaquick: Applet "Bluetooth" loaded after 81 msec
Für jeden HInweis sehr, sehr dankbar!
Viele Grüße
Alex
