Installiere mal: libqt5-qtwayland und libQt5Gui5 noch einmal.
Danach noch einmal den wget Befehl.
Zumindest libQt5Gui5 habe ich schon mindestens 5x neu installiert.
Jetzt beide nochmal.
Leider mit dem gleichen Ergebnis.
Neustart hatte ich aber nicht.
Hatte ich fast übersehen:
rechner:~ # wget -v 'https://github.com/sysrqb/torbrowser-launcher/raw/develop/share/torbrowser-launcher/tor-browser-developers.asc' ; sudo cp -v ~/tor-browser-developers.asc /usr/share/torbrowser-launcher/ ; torbrowser-launcher ; echo "DONE"
--2020-09-07 20:05:42-- https://github.com/sysrqb/torbrowser-launcher/raw/develop/share/torbrowser-launcher/tor-browser-developers.asc
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://raw.githubusercontent.com/sysrqb/torbrowser-launcher/develop/share/torbrowser-launcher/tor-browser-developers.asc [following]
--2020-09-07 20:05:42-- https://raw.githubusercontent.com/sysrqb/torbrowser-launcher/develop/share/torbrowser-launcher/tor-browser-developers.asc
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.112.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.112.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3470642 (3.3M) [application/octet-stream]
Saving to: ‘tor-browser-developers.asc’
tor-browser-developers.asc 100%[======================================================================>] 3.31M 3.93MB/s in 0.8s
2020-09-07 20:05:44 (3.93 MB/s) - ‘tor-browser-developers.asc’ saved [3470642/3470642]
'/root/tor-browser-developers.asc' -> '/usr/share/torbrowser-launcher/tor-browser-developers.asc'
Tor Browser Launcher
By Micah Lee, licensed under MIT
version 0.3.2
https://github.com/micahflee/torbrowser-launcher
Creating GnuPG homedir /root/.local/share/torbrowser/gnupg_homedir
qt.qpa.plugin: Could not find the Qt platform plugin "xcb" in ""
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Aborted (core dumped)
DONE
rechner:~ #
Leider wie gehabt.
Führ das Script mal als User aus.
selbes Ergebnis
user@rechner:~> ls -al /usr/lib64/qt5/plugins/platforms/
insgesamt 1896
drwxr-xr-x 1 root root 414 7. Sep 19:56 .
drwxr-xr-x 1 root root 11252 16. Mai 21:16 ..
-rwxr-xr-x 1 root root 461720 30. Mai 10:07 KWinQpaPlugin.so
-rwxr-xr-x 1 root root 10584 27. Aug 23:14 libqeglfs.so
-rwxr-xr-x 1 root root 486808 27. Aug 23:14 libqlinuxfb.so
-rwxr-xr-x 1 root root 177128 27. Aug 23:14 libqminimalegl.so
-rwxr-xr-x 1 root root 139512 27. Aug 23:14 libqminimal.so
-rwxr-xr-x 1 root root 177144 27. Aug 23:14 libqoffscreen.so
-rwxr-xr-x 1 root root 247440 27. Aug 23:14 libqvnc.so
-rwxr-xr-x 1 root root 73272 16. Mai 21:16 libqwayland-egl.so
-rwxr-xr-x 1 root root 10592 16. Mai 21:16 libqwayland-generic.so
-rwxr-xr-x 1 root root 73216 16. Mai 21:16 libqwayland-xcomposite-egl.so
-rwxr-xr-x 1 root root 52352 16. Mai 21:16 libqwayland-xcomposite-glx.so
-rwxr-xr-x 1 root root 10592 27. Aug 23:14 libqxcb.so
user@rechner:~>
Versuch mal als User, ich hoffe mal der browser ist bei dir auch dort installiert........
XXX ist durch deinen Usernamen zu ersetzen (2mal).
Ist 1 langer Befehl.
Was ergibt ldd /usr/lib/qt/plugins/platforms/libqxcb.so?
Ergebnis:
dummy: /home/user/.local/share/torbrowser/tbb/x86_64/tor-browser_de/Browser/start-tor-browser: Datei oder Verzeichnis nicht gefunden
dummy: ./Browser/start-tor-browser: Datei oder Verzeichnis nicht gefunden
Aber, ich habe "de" mal durch tor-browser_en-US ersetzt. Bei mir scheint nur die amerikanische Version installiert zu sein. Also:
sh -c '"/home/user/.local/share/torbrowser/tbb/x86_64/tor-browser_en-US/Browser/start-tor-browser" --detach || ([ ! -x "/home/user/.local/share/torbrowser/tbb/x86_64/tor-browser_de/Browser/start-tor-browser" ] && "$(dirname "$*")"/Browser/start-tor-browser --detach)' dummy %k
Nun startet der Torbrowser ohne zusätzliche Meldung!
Aber halt nur, wenn ich den langen Befehl eingebe........
und auch nur der Torbrowser.
Der Torbrowser ist ja nur eine Anwendung die hakt. Ihn hatte ich als Beispiel neben Vorta.
Der Workaround mit der langen Befehlszeile kann also noch nicht die Lösung sein.
user@rechner:~> ldd /usr/lib/qt/plugins/platforms/libqxcb.so
ldd: /usr/lib/qt/plugins/platforms/libqxcb.so: Datei oder Verzeichnis nicht gefunden
user@rechner:~>
Vielleicht noch:
user@rechner:~> ldd /usr/lib64/qt5/plugins/platforms/libqxcb.so
linux-vdso.so.1 (0x00007fff725ec000)
libQt5XcbQpa.so.5 => /usr/lib64/libQt5XcbQpa.so.5 (0x00007f06efdc3000)
libQt5Gui.so.5 => /usr/lib64/libQt5Gui.so.5 (0x00007f06ef5bf000)
libQt5Core.so.5 => /usr/lib64/libQt5Core.so.5 (0x00007f06eee7a000)
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007f06eea99000)
libc.so.6 => /lib64/libc.so.6 (0x00007f06ee6de000)
libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1 (0x00007f06ee499000)
libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00007f06ee1df000)
libQt5DBus.so.5 => /usr/lib64/libQt5DBus.so.5 (0x00007f06edf4f000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f06edd30000)
libX11-xcb.so.1 => /usr/lib64/libX11-xcb.so.1 (0x00007f06edb2e000)
libxcb-xinput.so.0 => /usr/lib64/libxcb-xinput.so.0 (0x00007f06ed90b000)
libxcb-icccm.so.4 => /usr/lib64/libxcb-icccm.so.4 (0x00007f06ed706000)
libxcb-image.so.0 => /usr/lib64/libxcb-image.so.0 (0x00007f06ed501000)
libxcb-shm.so.0 => /usr/lib64/libxcb-shm.so.0 (0x00007f06ed2fd000)
libxcb-keysyms.so.1 => /usr/lib64/libxcb-keysyms.so.1 (0x00007f06ed0fa000)
libxcb-randr.so.0 => /usr/lib64/libxcb-randr.so.0 (0x00007f06ecee9000)
libxcb-render-util.so.0 => /usr/lib64/libxcb-render-util.so.0 (0x00007f06ecce5000)
libxcb-render.so.0 => /usr/lib64/libxcb-render.so.0 (0x00007f06ecad7000)
libxcb-shape.so.0 => /usr/lib64/libxcb-shape.so.0 (0x00007f06ec8d3000)
libxcb-sync.so.1 => /usr/lib64/libxcb-sync.so.1 (0x00007f06ec6cc000)
libxcb-xfixes.so.0 => /usr/lib64/libxcb-xfixes.so.0 (0x00007f06ec4c4000)
libxcb-xinerama.so.0 => /usr/lib64/libxcb-xinerama.so.0 (0x00007f06ec2c1000)
libxcb-xkb.so.1 => /usr/lib64/libxcb-xkb.so.1 (0x00007f06ec0a4000)
libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x00007f06ebe7b000)
libXrender.so.1 => /usr/lib64/libXrender.so.1 (0x00007f06ebc71000)
libX11.so.6 => /usr/lib64/libX11.so.6 (0x00007f06eb930000)
libm.so.6 => /lib64/libm.so.6 (0x00007f06eb5f8000)
libSM.so.6 => /usr/lib64/libSM.so.6 (0x00007f06eb3f0000)
libICE.so.6 => /usr/lib64/libICE.so.6 (0x00007f06eb1d3000)
libxkbcommon-x11.so.0 => /usr/lib64/libxkbcommon-x11.so.0 (0x00007f06eafcb000)
libxkbcommon.so.0 => /usr/lib64/libxkbcommon.so.0 (0x00007f06ead8b000)
libglib-2.0.so.0 => /usr/lib64/libglib-2.0.so.0 (0x00007f06eaa67000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f06ea84f000)
libGL.so.1 => /usr/lib64/libGL.so.1 (0x00007f06ea5b7000)
libpng16.so.16 => /usr/lib64/libpng16.so.16 (0x00007f06ea374000)
libz.so.1 => /lib64/libz.so.1 (0x00007f06ea15d000)
libharfbuzz.so.0 => /usr/lib64/libharfbuzz.so.0 (0x00007f06e9e54000)
libsystemd.so.0 => /usr/lib64/libsystemd.so.0 (0x00007f06e9bbe000)
libicui18n.so.suse65.1 => /usr/lib64/libicui18n.so.suse65.1 (0x00007f06e96cc000)
libicuuc.so.suse65.1 => /usr/lib64/libicuuc.so.suse65.1 (0x00007f06e92ed000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f06e90e9000)
libpcre2-16.so.0 => /usr/lib64/libpcre2-16.so.0 (0x00007f06e8e72000)
libdouble-conversion.so.3 => /usr/lib64/libdouble-conversion.so.3 (0x00007f06e8c64000)
/lib64/ld-linux-x86-64.so.2 (0x00007f06f0343000)
libexpat.so.1 => /usr/lib64/libexpat.so.1 (0x00007f06e8a32000)
libbz2.so.1 => /usr/lib64/libbz2.so.1 (0x00007f06e8815000)
libdbus-1.so.3 => /usr/lib64/libdbus-1.so.3 (0x00007f06e85c3000)
libxcb-util.so.1 => /usr/lib64/libxcb-util.so.1 (0x00007f06e83bd000)
libXau.so.6 => /usr/lib64/libXau.so.6 (0x00007f06e81b9000)
libuuid.so.1 => /usr/lib64/libuuid.so.1 (0x00007f06e7fb1000)
libpcre.so.1 => /usr/lib64/libpcre.so.1 (0x00007f06e7d26000)
libGLX.so.0 => /usr/lib64/libGLX.so.0 (0x00007f06e7af4000)
libGLdispatch.so.0 => /usr/lib64/libGLdispatch.so.0 (0x00007f06e7838000)
libgraphite2.so.3 => /usr/lib64/libgraphite2.so.3 (0x00007f06e7612000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f06e73e9000)
libcap.so.2 => /usr/lib64/libcap.so.2 (0x00007f06e71e4000)
librt.so.1 => /lib64/librt.so.1 (0x00007f06e6fdc000)
liblzma.so.5 => /usr/lib64/liblzma.so.5 (0x00007f06e6da2000)
liblz4.so.1 => /usr/lib64/liblz4.so.1 (0x00007f06e6b8d000)
libgcrypt.so.20 => /usr/lib64/libgcrypt.so.20 (0x00007f06e686f000)
libicudata.so.suse65.1 => /usr/lib64/libicudata.so.suse65.1 (0x00007f06e666e000)
libgpg-error.so.0 => /usr/lib64/libgpg-error.so.0 (0x00007f06e644e000)
user@rechner:~>
