Das ist das Lenovo fcc_unlock_setup Script, könnte man das nicht für Leap unmodeln?
Script:
#! /bin/bash
### Insure the working directory is the same as the script
pushd "$(dirname "$0")" &> /dev/null
exit 1
trap "popd &> /dev/null" EXIT
echo "Copying files and libraries..."
if [ ! -d "/opt/fcc_lenovo" ]
then
sudo mkdir /opt/fcc_lenovo
fi
if [ ! -d "/opt/fcc_lenovo/lib" ]
then
sudo mkdir /opt/fcc_lenovo/lib
fi
if [ ! -d "/opt/fcc_lenovo/DEV_OTA_PACKAGE" ]
then
sudo mkdir /opt/fcc_lenovo/DEV_OTA_PACKAGE
fi
### Identify current OS
OS_UBUNTU="Ubuntu"
OS_FEDORA="Fedora"
source /etc/os-release
echo $NAME
if [[ "$NAME" == *"$OS_UBUNTU"* ]]
then
### Copy fcc unlock script for MM
sudo tar -zxf fcc-unlock.d.tar.gz -C /usr/lib/x86_64-linux-gnu/ModemManager/
sudo chmod ugo+x /usr/lib/x86_64-linux-gnu/ModemManager/fcc-unlock.d/*
sudo tar -zxf DEV_OTA_PACKAGE.tar.gz -C /opt/fcc_lenovo/
### Copy SAR config files
sudo tar -zxf sar_config_files.tar.gz -C /opt/fcc_lenovo/
### Copy libraries
sudo cp -rvf libmodemauth.so /opt/fcc_lenovo/lib/
sudo cp -rvf libmodemauth.so.1.1 /opt/fcc_lenovo/lib/
sudo cp -rvf libconfigserviceR+.so /opt/fcc_lenovo/lib/
sudo cp -rvf libconfigservice350.so /opt/fcc_lenovo/lib/
sudo cp -rvf libconfigservice350.so.1.2 /opt/fcc_lenovo/lib/
sudo cp -rvf libconfigservice101.so.1.2 /opt/fcc_lenovo/lib/
sudo cp -rvf libmbimtools.so /opt/fcc_lenovo/lib/
sudo cp -rvf libfiisdk.so.2.2.2 /opt/fcc_lenovo/lib/
sudo cp -rvf libmodemauthRW101.so.1.1 /opt/fcc_lenovo/lib/
elif [[ "$NAME" == *"$OS_FEDORA"* ]]
then
sudo tar -zxf fcc-unlock.d.tar.gz -C /usr/lib64/ModemManager/
sudo chmod ugo+x /usr/lib64/ModemManager/fcc-unlock.d/*
ln -s /usr/sbin/lspci /usr/bin/lspci
### Copy libraries
### Copy files for selinux for fedora
sudo cp -rvf mm_FccUnlock.cil /opt/fcc_lenovo
sudo cp -rvf mm_dmidecode.cil /opt/fcc_lenovo
sudo cp -rvf mm_sh.cil /opt/fcc_lenovo
sudo semodule -i /opt/fcc_lenovo/*.cil
else
echo "No need to copy files"
exit 0
fi
### Copy binary
sudo cp -rvf DPR_Fcc_unlock_service /opt/fcc_lenovo/
sudo cp -rvf configservice_lenovo /opt/fcc_lenovo/
## copy and enable service
sudo cp -rvf lenovo-cfgservice.service /etc/systemd/system/.
sudo systemctl daemon-reload
systemctl enable lenovo-cfgservice
### Grant permissions to all binaries and script
sudo chmod ugo+x /opt/fcc_lenovo/*
### fastboot installation is required for RW101R Modem
ID_PATTERN="33f8:0301|33f8:0302"
if lsusb | grep -E -q "$ID_PATTERN"; then
sudo apt install fastboot
fi
### Below mentioned script is executed to fix issues related to WWAN.
### Issue List:
### 1) System sometimes wake up during suspend mode, while using Fibocom
### L860-GL-16/FM350 ,Quectel EM160R-GL/RM520N-GL and Foxconn SDX61 WWAN module.
sudo chmod ugo+x suspend-fix/wwan_issue_fix.sh
## Please reboot machine (this will be needed only one for time)##
### Exit script
exit 0
