Hi V-Treiber,
hier ist der komplette Log Output des ModemManager nach den github install:
journalctl | grep Modem
Nov 16 15:40:17 hal systemd[1]: Started Modem Manager.
Nov 16 15:40:17 hal NetworkManager[1702]: <info> [1794840017.5864] modem-manager: ModemManager now available
Nov 16 15:40:19 hal ModemManager[7633]: <wrn> couldn't setup proxy specific process group
Nov 16 15:40:19 hal ModemManager[7622]: <msg> [wwan0mbim0/mbim] MBIM device is not QMI capable
Nov 16 15:40:21 hal ModemManager[7622]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
Nov 16 15:40:21 hal ModemManager[7622]: <msg> [device /sys/devices/pci0000:00/0000:00:1c.0/0000:08:00.0] creating modem with plugin 'Intel' and '4' ports
Nov 16 15:40:21 hal ModemManager[7622]: <msg> [base-manager] modem for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:08:00.0' successfully created
Nov 16 15:40:21 hal ModemManager[7622]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1f.6': not supported by any plugin
Nov 16 15:40:21 hal ModemManager[7622]: <msg> [modem0/wwan0mbim0/mbim] MBIM device is not QMI capable
Nov 16 15:40:22 hal ModemManager[7622]: <wrn> [modem0] couldn't load SUPL server: Operation not supported
Nov 16 15:40:22 hal ModemManager[7622]: <msg> [modem0] state changed (unknown -> disabled)
Nov 16 15:40:22 hal ModemManager[7622]: <msg> [modem0] state changed (disabled -> enabling)
Nov 16 15:40:22 hal ModemManager[7622]: <wrn> [modem0] Busy
Nov 16 15:40:24 hal ModemManager[7622]: <msg> caught signal, shutting down...
Nov 16 15:40:24 hal ModemManager[7622]: <msg> [modem0] port 'wwan0mbim0' no longer controllable, reprobing
Nov 16 15:40:24 hal NetworkManager[1702]: <info> [1794840024.5449] modem-manager: ModemManager no longer available
Nov 16 15:40:24 hal systemd[1]: ModemManager.service: Deactivated successfully.
