Wie lange dürfte denn "make" brauchen, um fertig zu werden?
Sorry, Du hattest ja noch weitere Vorschläge (hab ich übersehen), hier uname:
linux-l1zx:~ # uname -a
Linux linux-l1zx.site 3.7.10-1.16-desktop #1 SMP PREEMPT Fri May 31 20:21:23 UTC 2013 (97c14ba) i686 i686 i386 GNU/Linux
Und hier jetzt der komplette rpmbuild:
linux-l1zx:/home/ingrid # rpmbuild --rebuild acerhk-0.5.35-20.1.src.rpm
Installing acerhk-0.5.35-20.1.src.rpm
Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.8UIE28
+ umask 022
+ cd /usr/src/packages/BUILD
+ rm -rf acerhk-0.5.35
+ /bin/tar -xvvf -
+ /usr/bin/bzip2 -dc /usr/src/packages/SOURCES/acerhk-0.5.35.tar.bz2
drwxr-xr-x ole/ole 0 2007-02-10 16:46 acerhk-0.5.35/
drwxr-xr-x ole/ole 0 2007-02-10 16:46 acerhk-0.5.35/doc/
-rw-r--r-- ole/ole 7239 2005-11-10 18:45 acerhk-0.5.35/doc/FAQ
-rw-r--r-- ole/ole 1350 2004-01-31 21:38 acerhk-0.5.35/doc/IOCTL
-rw-r--r-- ole/ole 1233 2003-08-24 18:46 acerhk-0.5.35/doc/acertm.def
-rw-r--r-- ole/ole 703 2005-03-01 21:46 acerhk-0.5.35/doc/md95400.def
-rw-r--r-- ole/ole 619 2004-04-18 19:42 acerhk-0.5.35/doc/keycodes
-rw-r--r-- ole/ole 415 2003-02-28 01:47 acerhk-0.5.35/NEWS
-rw-r--r-- ole/ole 2090 2006-08-16 18:11 acerhk-0.5.35/Makefile
-rw-r--r-- ole/ole 8300 2006-11-09 23:01 acerhk-0.5.35/README
-rw-r--r-- ole/ole 88636 2007-02-10 16:46 acerhk-0.5.35/acerhk.c
-rw-r--r-- ole/ole 3154 2005-06-16 23:10 acerhk-0.5.35/acerhk.h
-rw-r--r-- ole/ole 28 2006-11-09 23:02 acerhk-0.5.35/AUTHORS
-rw-r--r-- ole/ole 4111 2005-12-07 13:27 acerhk-0.5.35/INSTALL
-rw-r--r-- ole/ole 18007 2002-05-08 21:01 acerhk-0.5.35/COPYING
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd acerhk-0.5.35
+ /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ echo 'Patch #0 (acerhk-0.5.35.diff):'
+ /usr/bin/patch -p0 --fuzz=0
+ /usr/bin/cat /usr/src/packages/SOURCES/acerhk-0.5.35.diff
patching file Makefile
+ echo 'Patch #1 (acerhk-remove-incompatible-build-flag.patch):'
+ /usr/bin/cat /usr/src/packages/SOURCES/acerhk-remove-incompatible-build-flag.patch
+ echo 'Patch #2 (acerhk-2.6.27.diff):'
+ /usr/bin/cat /usr/src/packages/SOURCES/acerhk-2.6.27.diff
patching file acerhk.c
+ echo 'Patch #3 (64bits_support_for_aspire5100.patch):'
+ /usr/bin/cat /usr/src/packages/SOURCES/64bits_support_for_aspire5100.patch
+ echo 'Patch #4 (acerhk-2.6.30.diff):'
+ /usr/bin/cat /usr/src/packages/SOURCES/acerhk-2.6.30.diff
Hunk #1 succeeded at 2637 (offset 11 lines).
Hunk #2 succeeded at 2648 (offset 11 lines).
Hunk #3 succeeded at 2660 (offset 11 lines).
Hunk #4 succeeded at 2674 (offset 11 lines).
Hunk #5 succeeded at 2689 (offset 11 lines).
Hunk #6 succeeded at 2704 (offset 11 lines).
Hunk #7 succeeded at 2723 (offset 11 lines).
+ echo 'Patch #5 (acerhk-add_medion_MD97600.diff):'
+ /usr/bin/cat /usr/src/packages/SOURCES/acerhk-add_medion_MD97600.diff
Hunk #1 succeeded at 1237 (offset 6 lines).
Hunk #2 succeeded at 1330 (offset 6 lines).
Hunk #3 succeeded at 1890 (offset 9 lines).
+ echo 'Patch #6 (acerhk-2.6.36.diff):'
+ /usr/bin/cat /usr/src/packages/SOURCES/acerhk-2.6.36.diff
Hunk #1 succeeded at 2785 (offset 48 lines).
Hunk #2 succeeded at 2881 (offset 48 lines).
+ echo 'Patch #7 (acerhk-2.6.38.diff):'
+ /usr/bin/cat /usr/src/packages/SOURCES/acerhk-2.6.38.diff
+ exit 0
Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.pud4Un
+ umask 022
+ /usr/bin/rm -rf /usr/src/packages/BUILDROOT/acerhk-0.5.35-20.1.i386
++ dirname /usr/src/packages/BUILDROOT/acerhk-0.5.35-20.1.i386
+ /usr/bin/mkdir -p /usr/src/packages/BUILDROOT
+ /usr/bin/mkdir /usr/src/packages/BUILDROOT/acerhk-0.5.35-20.1.i386
+ cd acerhk-0.5.35
++ find -type d -name RCS
+ cd ..
+ mkdir -p obj
+ for flavor in default desktop pae xen
+ rm -rf obj/default
+ cp -r acerhk-0.5.35 obj/default
+ CFLAGS='-O2 -g -m32 -march=i586 -mtune=i686 -fmessage-length=0 -D_FORTIFY_SOURCE=2 -fstack-protector -funwind-tables -fasynchronous-unwind-tables'
+ make -C /usr/src/linux-obj/i586/default modules M=/usr/src/packages/BUILD/obj/default
make: Entering directory `/usr/src/linux-3.7.10-1.16-obj/i386/default'
