Hinweis: In dem Thema miniDLNA startet nicht mehr!!! gibt es 12 Antworten auf 2 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
Ja das habe ich schon gemacht, zur Zeit läst sich nicht mal der Dienst starten, da einige Dateien fehlen, wie z.B die minidlnaconfig die es erst gab. Aber hier meine .conf
Alles anzeigen## Path: Network/minidlna ## Description: Define port for HTTP traffic ## Type: integer ## Default: "8200" ## Config: minidlna # Here you can change the default port for HTTP traffic (descriptions, SOAP, media transfer). # # Note: the default is 8200 port="8200" ## Path: Network/minidlna ## Description: Define network interfaces to serve ## Type: string ## Default: "eth0" ## Config: minidlna # Here you can define the network interfaces to serve, comma delimited. # # Note: the default is eth0 network_interface="enpls0" ## Path: Network/minidlna ## Description: Define user account name or uid ## Type: string ## Default: "root" ## Config: minidlna # Here you can specify the user account name or uid to run as. # # Note: the default is root user="root" ## Path: Network/minidlna ## Description: Define media directories to be scanned ## Type: string ## Default: "/mnt" ## Config: minidlna # Here you can define your media directories you want scanned # # Set this to the directories you want scanned. # # * if you want to restrict a media_dir to specific content types, you # can prepend the types, followed by a comma, to the directory: # # + "A" for audio (eg. A,/home/jmaggard/Music) # + "V" for video (eg. V,/home/jmaggard/Videos) # + "P" for images (eg. P,/home/jmaggard/Pictures) # + "PV" for pictures and video (eg. AV,/home/jmaggard/digital_camera) # # * if you want to scan multiple directories, you have to separate # the directories with a vertical bar: # # eq. A,/home/jmaggard/Music | V,/home/jmaggard/Videos | P,/home/jmaggard/Pictures # # Note: the default is /mnt media_dir=V,"/home/joerg/Torrent" | A,"/home/joerg/Musik" | P,"/home/joerg/Bilder" ## Path: Network/minidlna ## Description: Define MiniDLNA server name ## Type: string ## Default: "MiniDLNA" ## Config: minidlna # Here you can customize the MiniDLNA server name that shows up on your clients. # # Note: the default is MiniDLNA friendly_name="Joergs Server" ## Path: Network/minidlna ## Description: Define log level ## Type: string ## Default: "general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn" ## Config: minidlna # Here you can set the verbosity of the information that is logged. # # Each section can use a different level. # Possible levels are: off, fatal, error, warn, info or debug # # Note: the default is general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn log_level="general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn" ## Path: Network/minidlna ## Description: Define file names to check for when searching for album art ## Type: string ## Default: "Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg" ## Config: minidlna # Here you can set a list of file names to check for when searching for album art. # Note: names should be delimited with a forward slash ("/") # # Note: the default is Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/ # AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/ # Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg album_art_names="Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg" ## Path: Network/minidlna ## Description: Define inotify monitoring to automatically discover new files ## Type: yesno ## Default: "yes" ## Config: minidlna # Here you can enable/disable inotify monitoring to automatically discover new files. # # Note: the default is yes inotify="yes" ## Path: Network/minidlna ## Description: Define support for streaming .jpg and .mp3 files to a TiVo supporting HMO ## Type: yesno ## Default: "no" ## Config: minidlna # Here you can enable/disable support for streaming .jpg and .mp3 files to a TiVo supporting HMO. # # Note: the default is no enable_tivo="no" ## Path: Network/minidlna ## Description: Define strictly adhere to DLNA standards ## Type: yesno ## Default: "no" ## Config: minidlna # Here you can enable/disable strictly adhere to DLNA standards. # * This will allow server-side downscaling of very large JPEG images, # which may hurt JPEG serving performance on (at least) Sony DLNA products. # # Note: the default is no strict_dlna="no" ## Path: Network/minidlna ## Description: Define http address for default presentation url on port 80 ## Type: string ## Default: "" ## Config: minidlna # Here you can set the http address for default presentation url on port 80. # # Note: the default is none presentation_url="" ## Path: Network/minidlna ## Description: Define notify interval in seconds ## Type: integer ## Default: "900" ## Config: minidlna # Here you can change the notify interval in seconds. # # Note: the default is 900 notify_interval="900" ## Path: Network/minidlna ## Description: Define serial number the daemon will report to clients ## Type: integer ## Default: "12345678" ## Config: minidlna # Here you can change the serial number the daemon will report to clients in its XML description. # # Note: the default is 12345678 serial="12345678" ## Path: Network/minidlna ## Description: Define model number the daemon will report to clients ## Type: integer ## Default: "1" ## Config: minidlna # Here you can change the model number the daemon will report to clients in its XML description. # # Note: the default is 1 model_number="1" ## Path: Network/minidlna ## Description: Define the path to the MiniSSDPd socket ## Type: string ## Default: "" ## Config: minidlna # Here you can set the path to the MiniSSDPd socket. # # Example: /var/run/minissdpd.sock # # Note: the default is none minissdpdsocket="" ## Path: Network/minidlna ## Description: Define different container as root of the tree possible values ## Type: string ## Default: "." ## Config: minidlna # Here you can use different container as root of the tree possible values. # # "." - use standard container (this is the default) # "B" - "Browse Directory" # "M" - "Music" # "V" - "Video" # "P" - "Pictures" # # if you specify "B" and client device is audio-only then "Music/Folders" will be used as root # # Note: the default is "." root_container="." ## Path: Network/minidlna ## Description: Define rescan of all media directories on minidlna startup ## Type: yesno ## Default: "no" ## Config: minidlna # Here you can enable/disable a rescan of all media directories on minidlna startup. # # This can sometimes be useful as some new media files are not recognized # while minidlna is active (possibly an bug in minidlna). # # Note: the default is no rescan="no" -
Habe es gefunden, lach dich aber nicht schief
Ein Neustart wirkt manchmal wunder, nicht nur den Dienst neustarten sondern das System braucht es eben auch einmal und er rödelt und rödelt und... naja er hat ja die Nacht über Zeit die Dateien zu finden.
Der Tip mit der etc/sysconfig/minidlna war echt Gold wert, ich habe darin alles geändert und nicht mehr in der /var/lib/minidlna/minidlna.conf und es hat geklappt. Beim überprüfen der .conf unter var habe ich festgestellt das die Datei jetzt genau so aussieht wie die von mir geänderte in /etc/sysconfig/minidlna.
