rpm -qa kernel* *vidia*
nvidia-gfxG04-kmp-default-352.79_k4.1.12_1-19.1.x86_64
kernel-default-4.1.15-8.1.x86_64
x11-video-nvidiaG04-352.79-19.1.x86_64
nvidia-uvm-gfxG04-kmp-default-352.79_k4.1.12_1-19.1.x86_64
kernel-devel-4.1.15-8.1.noarch
kernel-macros-4.1.15-8.1.noarch
nvidia-glG04-352.79-19.1.x86_64
kernel-default-4.1.12-1.1.x86_64
kernel-default-devel-4.1.15-8.1.x86_64
nvidia-computeG04-352.79-19.1.x86_64
kernel-firmware-20150925git-1.1.noarch
/var/log/Xorg.0.log
Hier siehts mir so aus als wenn der Nvidia Treiber probleme macht, richtig (Zeile 89). Gibt es da beim zypper up genau so ein problem wie beim zypper dup?
[ 28.144]
X.Org X Server 1.17.2
Release Date: 2015-06-16
[ 28.144] X Protocol Version 11, Revision 0
[ 28.144] Build Operating System: openSUSE SUSE LINUX
[ 28.144] Current Operating System: Linux linux-i7d7 4.1.15-8-default #1 SMP PREEMPT Wed Jan 20 16:41:00 UTC 2016 (0e3b3ab) x86_64
[ 28.144] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.1.15-8-default root=UUID=ebfa3dbd-2518-44e4-9e3d-ffe462a295cd splash=silent quiet showopts
[ 28.144] Build Date: 08 February 2016 10:41:55AM
[ 28.144]
[ 28.144] Current version of pixman: 0.32.6
[ 28.144] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 28.144] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 28.145] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 6 17:47:30 2016
[ 28.145] (==) Using config file: "/etc/X11/xorg.conf"
[ 28.145] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 28.145] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 28.145] (==) ServerLayout "Layout0"
[ 28.145] (**) |-->Screen "Screen0" (0)
[ 28.145] (**) | |-->Monitor "Monitor0"
[ 28.145] (**) | |-->Device "Device0"
[ 28.145] (**) |-->Input Device "Keyboard0"
[ 28.145] (**) |-->Input Device "Mouse0"
[ 28.145] (==) Automatically adding devices
[ 28.145] (==) Automatically enabling devices
[ 28.145] (==) Automatically adding GPU devices
[ 28.146] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
[ 28.146] Entry deleted from font path.
[ 28.146] (==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/ghostscript/,
/usr/share/fonts/cyrillic:unscaled,
/usr/share/fonts/truetype/,
built-ins
[ 28.146] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 28.146] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 28.146] (WW) Disabling Keyboard0
[ 28.146] (WW) Disabling Mouse0
[ 28.146] (II) Loader magic: 0x80dd00
[ 28.146] (II) Module ABI versions:
[ 28.146] X.Org ANSI C Emulation: 0.4
[ 28.146] X.Org Video Driver: 19.0
[ 28.146] X.Org XInput driver : 21.0
[ 28.146] X.Org Server Extension : 9.0
[ 28.147] (++) using VT number 7
[ 28.147] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 28.147] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 28.149] (--) PCI:*(0:7:0:0) 10de:1287:10de:1287 rev 161, Mem @ 0xd8000000/16777216, 0xc0000000/134217728, 0xc8000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 28.149] (--) PCI: (0:15:2:0) 1002:515e:1025:515e rev 2, Mem @ 0xd0000000/134217728, 0xd9400000/65536, I/O @ 0x00005000/256, BIOS @ 0x????????/131072
[ 28.149] (II) LoadModule: "glx"
[ 28.150] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 28.170] (II) Module glx: vendor="NVIDIA Corporation"
[ 28.170] compiled for 4.0.2, module version = 1.0.0
[ 28.170] Module class: X.Org Server Extension
[ 28.170] (II) NVIDIA GLX Module 352.79 Wed Jan 13 15:54:44 PST 2016
[ 28.170] (II) LoadModule: "nvidia"
[ 28.170] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 28.171] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 28.171] compiled for 4.0.2, module version = 1.0.0
[ 28.171] Module class: X.Org Video Driver
[ 28.171] (II) NVIDIA dlloader X Driver 352.79 Wed Jan 13 15:31:15 PST 2016
[ 28.171] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 28.316] (II) Loading sub module "fb"
[ 28.316] (II) LoadModule: "fb"
[ 28.317] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 28.317] (II) Module fb: vendor="X.Org Foundation"
[ 28.317] compiled for 1.17.2, module version = 1.0.0
[ 28.317] ABI class: X.Org ANSI C Emulation, version 0.4
[ 28.317] (II) Loading sub module "wfb"
[ 28.317] (II) LoadModule: "wfb"
[ 28.317] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 28.317] (II) Module wfb: vendor="X.Org Foundation"
[ 28.317] (II) Loading sub module "ramdac"
[ 28.317] (II) LoadModule: "ramdac"
[ 28.317] (II) Module "ramdac" already built-in
[ 28.318] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 28.318] (==) NVIDIA(0): RGB weight 888
[ 28.318] (==) NVIDIA(0): Default visual is TrueColor
[ 28.318] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 28.318] (**) NVIDIA(0): Enabling 2D acceleration
[ 32.768] (EE) NVIDIA(GPU-0): The NVIDIA kernel module does not appear to be receiving
[ 32.768] (EE) NVIDIA(GPU-0): interrupts generated by the NVIDIA GPU at PCI:7:0:0.
[ 32.768] (EE) NVIDIA(GPU-0): Please see Chapter 8: Common Problems in the README for
[ 32.768] (EE) NVIDIA(GPU-0): additional information.
[ 32.768] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 32.768] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 32.768] (II) UnloadModule: "nvidia"
[ 32.768] (II) UnloadSubModule: "wfb"
[ 32.768] (II) UnloadSubModule: "fb"
[ 32.768] (EE) Screen(s) found, but none have a usable configuration.
[ 32.768] (EE)
Fatal server error:
[ 32.768] (EE) no screens found(EE)
[ 32.768] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 32.768] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 32.768] (EE)
[ 33.057] (EE) Server terminated with error (1). Closing log file.
Ausserdem bekomme ich nach dem startx befehl noch die fehlermeldung
in der Konsole Angezeigt.
