Habe fast das gleiche Problem wie Sorcerer11
Virtualbox no OS startet mit fehlermeldung : Kerneldriver not installed
Ein Blick in vboxdrv setup brachte allerdings diese Fehlermeldung, die ich nicht deuten kann:
Makefile:155: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
make KBUILD_VERBOSE=1 -C /usr/src/linux SUBDIRS=/tmp/vbox.0 SRCROOT=/tmp/vbox.0 modules
test -e include/linux/autoconf.h -a -e include/config/auto.conf || ( \
echo; \
echo " ERROR: Kernel configuration is invalid."; \
echo " include/linux/autoconf.h or include/config/auto.conf are missing."; \
echo " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo; \
/bin/false)
mkdir -p /tmp/vbox.0/.tmp_versions ; rm -f /tmp/vbox.0/.tmp_versions/*
WARNING: Symbol version dump /usr/src/linux-2.6.31.12-0.1/Module.symvers
is missing; modules will have no dependencies and modversions.
make -f scripts/Makefile.build obj=/tmp/vbox.0
/tmp/vbox.0/Makefile:155: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
gcc -Wp,-MD,/tmp/vbox.0/linux/.SUPDrv-linux.o.d -nostdinc -isystem /usr/lib/gcc/i586-suse-linux/4.4/include -Iinclude -I/usr/src/linux-2.6.31.12-0.1/arch/x86/include -include include/linux/autoconf.h -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mno-red-zone -mcmodel=kernel -maccumulate-outgoing-args -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fomit-frame-pointer -I/usr/src/linux/include -I/tmp/vbox.0/ -I/tmp/vbox.0/include -I/tmp/vbox.0/r0drv/linux -D__KERNEL__ -DMODULE -DRT_OS_LINUX -DIN_RING0 -DIN_RT_R0 -DIN_SUP_R0 -DVBOX -DRT_WITH_VBOX -DVBOX_WITH_HARDENING -DCONFIG_VBOXDRV_AS_MISC -DRT_ARCH_X86 -DVBOX_WITH_64_BITS_GUESTS -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(SUPDrv_linux)" -D"KBUILD_MODNAME=KBUILD_STR(vboxdrv)" -c -o /tmp/vbox.0/linux/SUPDrv-linux.o /tmp/vbox.0/linux/SUPDrv-linux.c
/tmp/vbox.0/linux/SUPDrv-linux.c:1: error: code model 'kernel' not supported in the 32 bit mode
/tmp/vbox.0/linux/SUPDrv-linux.c:1: sorry, unimplemented: 64-bit mode not compiled in
make[2]: *** [/tmp/vbox.0/linux/SUPDrv-linux.o] Error 1
make[1]: *** [_module_/tmp/vbox.0] Error 2
make: *** [vboxdrv] Error 2
Linux Kernel fehlt??
Diese Pakete sind instaliert:
- kernel-source
- kernel-syms
- Xalan-c
- Xerces-c
- gcc
- make
Ach ja: Opensuse 11.2, KDE
Virtualbox 3.1.4 r57640
Grüße Ingoo
