Hallo zusammen,
ich habe jetzt versucht, WLAN mit wicked in Betrieb zu setzen, Problem:
wicked ifup wlp1s0
wicked: device wlp1s0: call to org.opensuse.Network.Wireless.changeDevice() failed: General failure
wlp1s0 device-not-running
ifconfig
enp2s0 Link encap:Ethernet Hardware Adresse 20:25:64:3B:94:51
inet Adresse: <entfernt> Bcast:150.20.255.255 Maske:255.255.0.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:47328 errors:0 dropped:39586 overruns:0 frame:0
TX packets:2043 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 Sendewarteschlangenlänge:1000
RX bytes:4390201 (4.1 Mb) TX bytes:273137 (266.7 Kb)
Interrupt:18
lo Link encap:Lokale Schleife
inet Adresse:127.0.0.1 Maske:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 Sendewarteschlangenlänge:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
iwconfig
enp2s0 no wireless extensions.
wlp1s0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
lo no wireless extensions.
systemctl status network
wicked.service - wicked managed network interfaces
Loaded: loaded (/usr/lib/systemd/system/wicked.service; enabled)
Active: active (exited) since Di 2016-06-28 10:54:47 CEST; 13min ago
Process: 1217 ExecStart=/usr/sbin/wicked --systemd ifup all (code=exited, status=0/SUCCESS)
Main PID: 1217 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/wicked.service
Jun 28 10:54:46 max-lx-pc wicked[1217]: device wlp1s0: call to org.opensuse.Network.Wireless.changeDevice() failed: General failure
Jun 28 10:54:47 max-lx-pc wicked[1217]: lo up
Jun 28 10:54:47 max-lx-pc wicked[1217]: enp2s0 up
Jun 28 10:54:47 max-lx-pc wicked[1217]: wlp1s0 device-not-running
Jun 28 10:54:47 max-lx-pc systemd[1]: Started wicked managed network interfaces.
journalctl -b bringt gleichen Fehler, nicht mehr!
Was habe ich falsch gemacht? Firewall aus. Powermanagement Ein/Aus vergeblich versucht. Karte beim Systemstart aktivieren eingestellt. Wicked erkennt WLANs/SSID der Umgebung beim Einrichten mit YAST (vor Konfiguration der Passphrase, Auswahl SSID).
rfkill list
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
2: ideapad_3g: Wireless WAN
Soft blocked: no
Hard blocked: no
3: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
4: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
nano /etc/sysconfig/network/ifcfg-wlp1s0
BOOTPROTO='dhcp4'
BROADCAST=''
DHCLIENT_SET_DEFAULT_ROUTE='yes'
ETHTOOL_OPTIONS=''
IPADDR=''
MTU=''
NAME='AR9485 Wireless Network Adapter'
NETMASK=''
NETWORK=''
REMOTE_IPADDR=''
STARTMODE='auto'
WIRELESS_AP=''
WIRELESS_AP_SCANMODE='1'
WIRELESS_AUTH_MODE='psk'
WIRELESS_BITRATE='auto'
WIRELESS_CA_CERT=''
WIRELESS_CHANNEL=''
WIRELESS_CLIENT_CERT=''
WIRELESS_CLIENT_KEY=''
WIRELESS_CLIENT_KEY_PASSWORD=''
WIRELESS_DEFAULT_KEY='0'
WIRELESS_EAP_AUTH=''
WIRELESS_EAP_MODE=''
WIRELESS_ESSID='<entfernt>'
WIRELESS_FREQUENCY=''
WIRELESS_KEY=''
WIRELESS_KEY_0=''
WIRELESS_KEY_1=''
WIRELESS_KEY_2=''
WIRELESS_KEY_3=''
WIRELESS_KEY_LENGTH='128'
WIRELESS_MODE='Managed'
WIRELESS_NICK=''
WIRELESS_NWID=''
WIRELESS_PEAP_VERSION=''
WIRELESS_POWER='yes'
WIRELESS_WPA_ANONID=''
WIRELESS_WPA_IDENTITY=''
WIRELESS_KEY=''
WIRELESS_KEY_0=''
WIRELESS_KEY_1=''
WIRELESS_KEY_2=''
WIRELESS_KEY_3=''
WIRELESS_NICK=''
WIRELESS_NWID=''
WIRELESS_WPA_PASSWORD=''
WIRELESS_WPA_PSK='<entfernt>'
Benötigt ihr noch mehr Angaben? LG Jana
