Hi,
habe hier einen USB-Wlan-Stick (lsusb sagt "Ralink Technology, Corp. RT5572 Wireless Adapter") seit etwa 3einhalb Jahren am laufen. Seit ein paar Tagen startet er nicht mehr automatisch beim Systemstart
Eingerichtet ist er auf opsensuse leap 15.1 per yast --> wicked-Dienst --> starten "Bei Systemstart"
Wenn ich ihn nach dem Systemstart ab- und wieder anstecke läuft er, ich hätts aber gerne wieder automatisch
dmesg sagt dann:
[ 96.247614] usb 1-1.6: USB disconnect, device number 4
[ 98.262455] usb 1-1.6: new high-speed USB device number 5 using ehci-pci
[ 98.386475] usb 1-1.6: New USB device found, idVendor=148f, idProduct=5572
[ 98.386476] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 98.386477] usb 1-1.6: Product: 802.11 n WLAN
[ 98.386478] usb 1-1.6: Manufacturer: Ralink
[ 98.386479] usb 1-1.6: SerialNumber: 1.0
[ 98.474451] usb 1-1.6: reset high-speed USB device number 5 using ehci-pci
[ 98.592013] ieee80211 phy1: rt2x00_set_rt: Info - RT chipset 5592, rev 0222 detected
[ 98.620323] ieee80211 phy1: rt2x00_set_rf: Info - RF chipset 000f detected
[ 98.620867] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 98.629990] rt2800usb 1-1.6:1.0 wlan1: renamed from wlan0
[ 98.664701] ieee80211 phy1: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 98.666987] ieee80211 phy1: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[ 98.999026] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 99.009066] NET: Registered protocol family 17
[ 106.959377] wlan1: authenticate with 38:10:d5:6f:c5:b7
[ 107.046180] wlan1: send auth to 38:10:d5:6f:c5:b7 (try 1/3)
[ 107.049171] wlan1: authenticated
[ 107.050209] wlan1: associate with 38:10:d5:6f:c5:b7 (try 1/3)
[ 107.056217] wlan1: RX AssocResp from 38:10:d5:6f:c5:b7 (capab=0x1431 status=0 aid=3)
[ 107.066901] wlan1: associated
[ 107.066947] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 107.114979] wlan1: Limiting TX power to 20 (20 - 0) dBm as advertised by 38:10:d5:6f:c5:b7
Was kann ich da machen? in yast gelöscht und wieder eingerichtet hat nix gebracht. Achja, vor ein paar Tagen hab ich mal das Programm "wavemon" ausprobiert, ob der wohl dahinter steckt?
schonmal Danke für Eure Hilfe! ![]()
cu,
