@Sauerland
linux:~ # fdisk -l
Disk /dev/sda: 119.2 GiB, 128035676160 bytes, 250069680 sectors
Disk model: HFS128G39TND-N21
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 44A9B248-25DE-43B4-9BA4-0A17F71D15F2
Device Start End Sectors Size Type
/dev/sda1 2048 923647 921600 450M Windows recovery environment
/dev/sda2 923648 1128447 204800 100M EFI System
/dev/sda3 1128448 1161215 32768 16M Microsoft reserved
/dev/sda4 1161216 204723592 203562377 97.1G Microsoft basic data
/dev/sda5 248377344 250066943 1689600 825M Windows recovery environment
/dev/sda6 204724224 205748223 1024000 500M EFI System
/dev/sda7 205748224 244183039 38434816 18.3G Linux filesystem
/dev/sda8 244183040 248377343 4194304 2G Linux swap
Partition table entries are not in disk order.
Disk /dev/sdb: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WD10SPZX-21Z
Disklabel type: gpt
Disk identifier: A92FCBDE-EB04-4763-9736-14E18CA51A60
/dev/sdb1 34 1008857087 1008857054 481.1G Microsoft LDM data
/dev/sdb2 1008857088 1009905663 1048576 512M EFI System
/dev/sdb3 1953262991 1953265038 2048 1M Microsoft LDM metadata
/dev/sdb4 1953265039 1953525134 260096 127M Microsoft reserved
Partition 1 does not start on physical sector boundary.
Partition 3 does not start on physical sector boundary.
Partition 4 does not start on physical sector boundary.
Disk /dev/sdc: 7.5 GiB, 8053063680 bytes, 15728640 sectors
Disk model: UDisk
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x329dcb2f
Device Boot Start End Sectors Size Id Type
/dev/sdc1 2808 11123 8316 4.1M ef EFI (FAT-12/16/32)
/dev/sdc2 * 11124 8312831 8301708 4G 17 Hidden HPFS/NTFS
linux:~ # cat /etc/fstab
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b / btrfs defaults 0 0
UUID=04c30061-5e09-4617-8bfa-c70747bba20a swap swap defaults 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /var btrfs subvol=/@/var 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /usr/local btrfs subvol=/@/usr/local 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /tmp btrfs subvol=/@/tmp 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /srv btrfs subvol=/@/srv 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /root btrfs subvol=/@/root 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /opt btrfs subvol=/@/opt 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /home btrfs subvol=/@/home 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /boot/grub2/x86_64-efi btrfs subvol=/@/boot/grub2/x86_64-efi 0 0
UUID=07917554-b6cd-49b8-ad39-043ee0c0b70b /boot/grub2/i386-pc btrfs subvol=/@/boot/grub2/i386-pc 0 0
UUID=A855-9886 /boot/efi vfat defaults 0 2
