Beim Starten von Rechner und Lap erhalte ich nach einem der letzten Updates folgende Fehlermeldung:
Failed to start Apply Kernel Variables.
Eine Überprüfung ergibt:
systemctl status systemd-sysctl.service
● systemd-sysctl.service - Apply Kernel Variables
Loaded: loaded (/usr/lib/systemd/system/systemd-sysctl.service; static)
Drop-In: /usr/lib/systemd/system/systemd-sysctl.service.d
└─50-kernel-uname_r.conf
Active: failed (Result: exit-code) since Sat 2020-09-19 09:43:51 CEST; 16min ago
Docs: man:systemd-sysctl.service(8)
man:sysctl.d(5)
Process: 1015 ExecStartPre=/usr/lib/systemd/systemd-sysctl /boot/sysctl.conf-5.8.7-1-default (code=exited, status=0/SUCCESS)
Process: 1028 ExecStart=/usr/lib/systemd/systemd-sysctl (code=exited, status=1/FAILURE)
Main PID: 1028 (code=exited, status=1/FAILURE)
Sep 19 09:43:51 linux-xyzx systemd[1]: Starting Apply Kernel Variables...
Sep 19 09:43:51 linux-xyzx systemd-sysctl[1028]: Couldn't write '"0 2147483647"' to 'net/ipv4/ping_group_range': Invalid argument
Sep 19 09:43:51 linux-xyzx systemd[1]: systemd-sysctl.service: Main process exited, code=exited, status=1/FAILURE
Sep 19 09:43:51 linux-xyzx systemd[1]: systemd-sysctl.service: Failed with result 'exit-code'.
Sep 19 09:43:51 linux-xyzx systemd[1]: Failed to start Apply Kernel Variables.
Die sysctl.conf enthält folgende Meldung:
# /etc/sysctl.conf is meant for local sysctl settings
# sysctl reads settings from the following locations:
# /boot/sysctl.conf-<kernelversion>
# /lib/sysctl.d/*.conf
# /usr/lib/sysctl.d/*.conf
# /usr/local/lib/sysctl.d/*.conf
# /etc/sysctl.d/*.conf
# /run/sysctl.d/*.conf
# /etc/sysctl.conf
# To disable or override a distribution provided file just place a
# file with the same name in /etc/sysctl.d/
# See sysctl.conf(5), sysctl.d(5) and sysctl(8) for more information
# net.ipv6.conf.all.disable_ipv6 = 1
kernel.sysrq = 0
net.ipv4.ip_forward = 0
net.ipv4.tcp_syncookies = 1
net.ipv6.conf.all.forwarding = 0
Kann jemand etwas mit den Meldungen anfangen?
