Drucker via USB funktioniert; Netzwerk druckt nicht
- pcfreddy
- Unerledigt
Hinweis: In dem Thema Drucker via USB funktioniert; Netzwerk druckt nicht gibt es 21 Antworten auf 3 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
Nein, ich meine die Fehler in der Ausgabe von cups error_log
Alles anzeigenW[28/Apr/2022:20:32:34 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files E [30/Apr/2022:08:36:46 +0200] [cups-deviced] PID 8531 (cups-brf) stopped with status 1! E [30/Apr/2022:08:36:46 +0200] [cups-deviced] PID 8536 (gutenprint52+usb) stopped with status 1! --- E [30/Apr/2022:10:01:59 +0200] [CGI] cups-brf must be called as root E [30/Apr/2022:10:01:59 +0200] [cups-deviced] PID 9139 (cups-brf) stopped with status 1! E [30/Apr/2022:10:02:00 +0200] [cups-deviced] PID 9144 (gutenprint52+usb) stopped with status 1! --- W [30/Apr/2022:10:31:21 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files --- E [30/Apr/2022:10:31:21 +0200] Unable to open listen socket for address [v1.::1]:631 - Address already in use. E [30/Apr/2022:10:31:21 +0200] Unable to open listen socket for address 127.0.0.1:631 - Address already in use. --- E [30/Apr/2022:11:19:10 +0200] [CGI] cups-brf must be called as root E [30/Apr/2022:11:19:10 +0200] [cups-deviced] PID 10876 (cups-brf) stopped with status 1! E [30/Apr/2022:11:19:10 +0200] [cups-deviced] PID 10881 (gutenprint52+usb) stopped with status 1! W [30/Apr/2022:16:53:50 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files W [30/Apr/2022:16:53:50 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files W [30/Apr/2022:16:53:50 +0200] CreateDevice failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files E [30/Apr/2022:16:53:50 +0200] Unable to open listen socket for address [v1.::1]:631 - Address already in use. E [30/Apr/2022:16:53:50 +0200] Unable to open listen socket for address 127.0.0.1:631 - Address already in use. E [30/Apr/2022:16:53:56 +0200] [CGI] cups-brf must be called as root E [30/Apr/2022:16:53:56 +0200] [cups-deviced] PID 1241 (cups-brf) stopped with status 1! E [30/Apr/2022:16:53:56 +0200] [cups-deviced] PID 1245 (gutenprint52+usb) stopped with status 1! E [30/Apr/2022:16:56:46 +0200] [Client 19] Returning HTTP Verboten for Pause-Printer (ipp://papa@localhost:631/printers/epson) from localhost W [30/Apr/2022:16:59:57 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files W [30/Apr/2022:16:59:57 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files W [30/Apr/2022:16:59:57 +0200] CreateDevice failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files W [30/Apr/2022:17:00:03 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files W [30/Apr/2022:17:00:03 +0200] CreateProfile failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files W [30/Apr/2022:17:00:03 +0200] CreateDevice failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
CreateProfile failed und Unable to open listen socket for address, sind beides Fehler mit denen ich absolut nichts anfangen kann.
Dazu kommt dann noch [CGI] cups-brf must be called as root.
Alles Fehler, die vielleicht den Server daran hindern, dass der Druck funktioniert.
Zwei Dinge hätte ich noch anzumerken:
1. Auch der Client-Rechner benötigt vermutlich diverse USB-Bibliotheken zum Drucken, auch wenn er über LAN/WLAN angebunden ist. Ich weiß allerdings nicht, ob das bei Epson-Druckern ebenso ist, da es aber bei vielen Herstellern so ist, gehe ich stark davon aus.
2. Notfalls könnte man den Drucker auch an die Fritzbox anschließen, der dann als Druckserver für beide Rechner fungiert, sofern vorhanden.
Nur, wozu zusätzlich die 32 bit Variante?
Die Idee mit der Fritzbox ist ja gut gemeint - war auch meine Idee. Es lässt sich jedoch aus Platzmangel bei der Fritzbox nicht umsetzen.
Weil ich oft die Erfahrung gemacht habe, dass ausgerechnet die gefehlt hat und das der Grund für das Nichtfunktionieren war.
Nur mal als Hinweis: USB funktioniert bis 5 Meter Kabellänge ganz gut.
Für längere Strecken gibt es sogar Repeaterkabel...
Ich hab mal nachgesehen und die libusb-0_1-4-32bit und libusb-1_0-0-32bit nachinstalliert. Ohne Erfolg.
Wenn alles nichts hilft muss ich, wohl oder übel, die zu druckende Datei via FTP zum Server schicken und am Server direkt ausdrucken. Shit happens.
Nur als Info:
Bei Epson sind die 32 bit nicht nötig, nur bei Brother.
Poste mal als root auf dem Server ausgeführt:
netstat ist im Paket:
#>netstat -tulpen | grep 631 netstat -tulpen | grep 631 tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN 0 30456 546/cupsd tcp6 0 0 :::631 :::* LISTEN 0 30457 546/cupsd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 31471 916/cups-browsed
Liegt der Fehler, dass man nicht drucken kann, an 0.0.0.0:631, statt 192.168.178.5:631??
Code#>systemctl status firewalld.service firewalld.service - firewalld - dynamic firewall daemon Loaded: loaded (/usr/lib/systemd/system/firewalld.service; disabled; vendor preset: disabled) Active: inactive (dead) Docs: man:firewalld(1)
[code]
