markus@linux:~> su
Passwort:
linux:/home/markus # hp-setup -i 192.168.178.25
HP Linux Imaging and Printing System (ver. 3.21.10)
Printer/Fax Setup Utility ver. 9.0
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
(Note: Defaults for each question are maked with a '*'. Press <enter> to accept the default.)
Setting up device: hp:/net/HP_OfficeJet_Pro_8710?ip=192.168.178.25
| PRINT QUEUE SETUP |
Please enter a name for this print queue (m=use model name:'HP_OfficeJet_Pro_8710_3'*, q=quit) ?HP_OfficeJet_Pro_8710
error: A print queue with that name already exists. Please enter a different name.
Please enter a name for this print queue (m=use model name:'HP_OfficeJet_Pro_8710_3'*, q=quit) ?q
OK, done.
| PRINT QUEUE SETUP |
Please enter a name for this print queue (m=use model name:'HP_OfficeJet_Pro_8710_3'*, q=quit) ?m
Using queue name: HP_OfficeJet_Pro_8710_3
Locating PPD file... Please wait.
Found PPD file: /usr/share/cups/model/manufacturer-PPDs/hplip/hp-officejet_pro_8710.ppd.gz
Description:
Note: The model number may vary slightly from the actual model number on the device.
Does this PPD file appear to be the correct one (y=yes*, n=no, q=quit) ? y
Enter a location description for this printer (q=quit) ?near telefon
Enter additonal information or notes for this printer (q=quit) ?on the desk
Adding print queue to CUPS:
Device URI: hp:/net/HP_OfficeJet_Pro_8710?ip=192.168.178.25
Queue name: HP_OfficeJet_Pro_8710_3
Information: on the desk
| FAX QUEUE SETUP |
Please enter a name for this fax queue (m=use model name:'HP_OfficeJet_Pro_8710_fax_3'*, q=quit) ?m
Using queue name: HP_OfficeJet_Pro_8710_fax_3
Adding fax queue to CUPS:
Device URI: hpfax:/net/HP_OfficeJet_Pro_8710?ip=192.168.178.25
Queue name: HP_OfficeJet_Pro_8710_fax_3
PPD file: /usr/share/cups/model/manufacturer-PPDs/hplip/HP-Fax4-hpcups.ppd.gz
| FAX HEADER SETUP |
Would you like to perform fax header setup (y=yes*, n=no, q=quit) ?y
Enter the fax phone number for this device (c=use current:'25823069250'*, q=quit) ?025823069250
Enter the name and/or company for this device (c=use current:'Markus Neuhaus'*, q=quit) ?c
Parameters sent to device.
| PRINTER TEST PAGE |
Would you like to print a test page (y=yes*, n=no, q=quit) ? y
warning: hp-testpage should not be run as root/superuser.
Testpage Print Utility ver. 6.0
Printing test page to printer HP_OfficeJet_Pro_8710_3...
Test page has been sent to printer.
note: If an error occured, or the test page failed to print, refer to the HPLIP website
note: at: http://hplip.sourceforge.net for troubleshooting and support.
Done.
Done.
