USCI_ACPI Fehler
Hinweis: In dem Thema USCI_ACPI Fehler gibt es 23 Antworten auf 3 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
    ov 23 11:46:43 opensuse-tw kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20240322/nsarguments-61)
    Nov 23 11:46:43 opensuse-tw kernel: ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20240322/nsarguments-61)
    Nov 23 11:47:15 opensuse-tw kernel: Modules linked in: ccm snd_seq_dummy rfcomm snd_hrtimer snd_seq snd_seq_device af_packet qrtr cmac algif_hash algif_skcipher af_alg bnep nf_tables iptable_filter nls_iso8859_1 nls_cp437 vfat fat nvidia_drm(POE) nvidia_modeset(POE) snd_ctl_led snd_soc_dmic snd_ps_pdm_dma snd_soc_ps_mach nvidia_uvm(POE) snd_sof_amd_acp63 snd_sof_amd_vangogh rtw89_8852be snd_sof_amd_rembrandt rtw89_8852b snd_sof_amd_renoir snd_sof_amd_acp rtw89_8852b_common snd_sof_pci rtw89_pci snd_sof_xtensa_dsp snd_sof rtw89_core snd_sof_utils snd_pci_ps snd_amd_sdw_acpi snd_hda_codec_realtek soundwire_amd soundwire_generic_allocation snd_hda_codec_generic snd_hda_scodec_component soundwire_bus snd_hda_codec_hdmi mac80211 snd_soc_core btusb amd_atl intel_rapl_msr btrtl intel_rapl_common btintel snd_compress snd_hda_intel snd_pcm_dmaengine btbcm snd_intel_dspcfg edac_mce_amd uvcvideo snd_intel_sdw_acpi btmtk libarc4 snd_rpl_pci_acp6x spd5118 kvm_amd snd_hda_codec snd_acp_pci nvidia(POE) hp_wmi bluetooth videobuf2_vmalloc cfg80211
    Gregor
    Für den Inhalt des Beitrages 317184 haftet ausdrücklich der jeweilige Autor: JanGre
    ov 23 11:47:15 opensuse-tw kernel:  snd_hda_core snd_acp_legacy_common sparse_keymap uvc videobuf2_memops snd_hwdep snd_pci_acp6x videobuf2_v4l2 kvm r8169 snd_pcm videodev pcspkr snd_timer realtek snd_pci_acp5x mdio_devres snd_rn_pci_acp3x videobuf2_common snd amd_pmf snd_acp_config libphy amdtee i2c_piix4 mc snd_soc_acpi soundcore snd_pci_acp3x rfkill i2c_smbus k10temp thermal amd_sfh wmi_bmof platform_profile tee joydev amd_pmc wireless_hotkey acpi_tad ac tiny_power_button nvme_fabrics fuse dm_mod nvme_keyring loop efi_pstore configfs nfnetlink dmi_sysfs ip_tables x_tables hid_logitech_hidpp hid_logitech_dj usbhid amdgpu crct10dif_pclmul crc32_pclmul polyval_clmulni polyval_generic ghash_clmulni_intel sha512_ssse3 amdxcp i2c_algo_bit drm_ttm_helper sha256_ssse3 sha1_ssse3 ttm drm_exec gpu_sched drm_suballoc_helper drm_buddy xhci_pci xhci_pci_renesas nvme drm_display_helper hid_multitouch ucsi_acpi aesni_intel xhci_hcd nvme_core gf128mul cec hid_generic typec_ucsi video crypto_simd cryptd usbcore roles ccp rc_core sp5100_tco nvme_auth
    Gregor
    Für den Inhalt des Beitrages 317185 haftet ausdrücklich der jeweilige Autor: JanGre
  • Steht noch viel mehr drin aber eigentlich immer das gleiche.
    Gregor
    Für den Inhalt des Beitrages 317186 haftet ausdrücklich der jeweilige Autor: JanGre
    Nov 23 11:46:14 localhost kernel: ucsi_acpi USBC000:00: failed to reset PPM!
    Nov 23 11:46:14 localhost kernel: ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
    Zu solchen Fehlermeldungen sagt das Internet viel, aber alles verschiedene Ursachen.
    Für den Inhalt des Beitrages 317187 haftet ausdrücklich der jeweilige Autor: Sauerland
  • Ja schon, das System und einige Programme öffnen sich sehr langsam, sonst ist aber alles okay.
    Werde morgen TW nochmal installieren aber mit KDE.
    Mal sehen ob ich es schaffe die Nividia-Karte erst garnicht zu installieren, leider wird sie beim Update automatisch installiert.
    Gregor
    Für den Inhalt des Beitrages 317189 haftet ausdrücklich der jeweilige Autor: JanGre
  • Mal sehen ob ich es schaffe die Nividia-Karte erst garnicht zu installieren, leider wird sie beim Update automatisch installiert.
    Einfach das entsprechende rpm nicht installieren und auf tabu setzen.......
    So etwas in der Art:
    openSUSE-repos-Leap-NVIDIA
    Für den Inhalt des Beitrages 317190 haftet ausdrücklich der jeweilige Autor: Sauerland
  • Okay, werd ich machen.
    Danke euch für eure Hilfe.
    Gregor
    Für den Inhalt des Beitrages 317191 haftet ausdrücklich der jeweilige Autor: JanGre
  • Moin,
    der acpi-Fehler existiert auch bei anderen Linux-Derivaten also Hardware bedingt denke ich.
    Somit kein Problem mit Tumbleweed, es läuft ja auch sonst problemlos.
    Danke nochmal für eure Unterstützung.
    Gregor
    Für den Inhalt des Beitrages 317192 haftet ausdrücklich der jeweilige Autor: JanGre
  • Ich denke schon, das es mit deinen 2 Grafikkarten zu tun hat. OK, ist wohl nicht so einfach zu erklären. Dann bitte noch als erledigt markieren.
    Übrigens:
    ACPI wird dafür kritisiert, besonders kompliziert zu sein. Für andere Betriebssysteme als Windows sei es schwer, in ordentlicher Weise zu implementieren. Intel arbeitet deshalb für den Einsatz in Mobilgeräten an einer Alternative namens Simple Firmware Interface (SFI), empfiehlt jedoch, wenn eine Hardware beides zur Verfügung stellt, stets ACPI zu verwenden.
    Wegen Fehlern in der ACPI-Implementierung vieler Hardwarekomponenten muss das Betriebssystem dieses undokumentierte Verhalten mit verschiedenen Methoden korrigieren. Das Betriebssystem Linux gibt sich dem BIOS gegenüber als Windows aus, um den besser getesteten Windows-Modus zu erhalten.
    (aus dem Wiki)
