ich habe den PC neu gestartet und als gast eingeloggt, es bleibt unverändert.
User "gast" kann immer noch nicht "epsonscan2" benutzen.
Sauerland Habe das von SUSEopti beschriebene epsonscan2 -Problem nachstellen können.
Beim Start von epsonscan2 des zweiten users erfolgt in der journalctl ein
fritz.box kernel: es2netif[18592]: segfault at c0 ip 00007f9173e79d6e s
p 00007ffc573c9d70 error 4 in libc.so.6[7f9173e00000+1fb000]
Im Ubuntu-Forum wird ein workaround beschrieben:
Deswegen auch meine Fragen im letzten Beitrag.
localhost:~ # journalctl -f
Sep 11 15:57:49 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Cache transaction finished successfully
Sep 11 15:57:49 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Updates changed, getting updates!
Sep 11 15:57:49 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Is net online: true
Sep 11 15:57:49 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Transaction status changed: "wait" "(101%)"
Sep 11 15:57:49 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Transaction status changed: "setup" "(101%)"
Sep 11 15:57:49 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Transaction status changed: "query" "(101%)"
Sep 11 15:57:50 localhost.localdomain kded5[3323]: kf.bluezqt: PendingCall Error: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Sep 11 15:57:50 localhost.localdomain dbus-daemon[978]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Sep 11 15:57:51 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Transaction status changed: "refresh-cache" "(0%)"
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Got update package: "openSUSE-SLE-15.6-2025-3164;1;noarch;repo-sle-update" , summary: "Security update for ImageMagick" , type: "security"
Sep 11 15:57:57 localhost.localdomain PackageKit[3576]: get-updates transaction /2_aabdeebe from uid 0 finished with success after 8324ms
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Got update package: "openSUSE-SLE-15.6-2025-3162;1;noarch;repo-sle-update" , summary: "Security update for ffmpeg-4" , type: "security"
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Transaction "/2_aabdeebe" finished with status "success" in 8 seconds
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Check updates transaction finished successfully
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Total number of updates: 2
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Is net online: true
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: qml: Populating model
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: qml: Updating state of selection
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: plasma-pk-updates: Transaction status changed: "finished" "(100%)"
Sep 11 15:57:57 localhost.localdomain plasmashell[3359]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5638b33b28e0) QQmlContext(0x5638b071aec0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 11 15:58:16 localhost.localdomain PackageKit[3576]: daemon quit
Sep 11 15:58:16 localhost.localdomain systemd[1]: packagekit.service: Deactivated successfully.
Sep 11 15:58:16 localhost.localdomain systemd[1]: packagekit.service: Consumed 25.841s CPU time.
Sep 11 15:58:22 localhost.localdomain kded5[3323]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Sep 11 15:59:06 localhost.localdomain systemd[1]: Started Daily Cleanup of Snapper Snapshots.
Sep 11 15:59:06 localhost.localdomain dbus-daemon[978]: [system] Activating via systemd: service name='org.opensuse.Snapper' unit='snapperd.service' requested by ':1.115' (uid=0 pid=3859 comm="/usr/lib/snapper/systemd-helper --cleanup ")
Sep 11 15:59:06 localhost.localdomain systemd[1]: Starting DBus interface for snapper...
Sep 11 15:59:06 localhost.localdomain dbus-daemon[978]: [system] Successfully activated service 'org.opensuse.Snapper'
Sep 11 15:59:06 localhost.localdomain systemd[1]: Started DBus interface for snapper.
Sep 11 15:59:06 localhost.localdomain systemd-helper[3859]: running cleanup for 'root'.
Sep 11 15:59:06 localhost.localdomain systemd-helper[3859]: running number cleanup for 'root'.
Sep 11 15:59:12 localhost.localdomain kernel: BTRFS info (device sda2): qgroup scan completed (inconsistency flag cleared)
Sep 11 15:59:12 localhost.localdomain systemd-helper[3859]: running timeline cleanup for 'root'.
Sep 11 15:59:12 localhost.localdomain systemd-helper[3859]: running empty-pre-post cleanup for 'root'.
Sep 11 15:59:12 localhost.localdomain systemd[1]: snapper-cleanup.service: Deactivated successfully.
Sep 11 16:00:12 localhost.localdomain systemd[1]: snapperd.service: Deactivated successfully.
Sep 11 16:00:12 localhost.localdomain systemd[1]: Started Timeline of Snapper Snapshots.
Sep 11 16:00:12 localhost.localdomain dbus-daemon[978]: [system] Activating via systemd: service name='org.opensuse.Snapper' unit='snapperd.service' requested by ':1.117' (uid=0 pid=3897 comm="/usr/lib/snapper/systemd-helper --timeline ")
Sep 11 16:00:12 localhost.localdomain systemd[1]: Starting DBus interface for snapper...
Sep 11 16:00:12 localhost.localdomain dbus-daemon[978]: [system] Successfully activated service 'org.opensuse.Snapper'
Sep 11 16:00:12 localhost.localdomain systemd[1]: Started DBus interface for snapper.
Sep 11 16:00:12 localhost.localdomain systemd[1]: snapper-timeline.service: Deactivated successfully.
Sep 11 16:00:23 localhost.localdomain systemd[3199]: Started Firefox - Web Browser.
Sep 11 16:00:24 localhost.localdomain dbus-daemon[978]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.119' (uid=0 pid=3901 comm="/usr/lib64/firefox/firefox ")
Sep 11 16:00:24 localhost.localdomain systemd[1]: Starting Time & Date Service...
Sep 11 16:00:24 localhost.localdomain dbus-daemon[978]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 11 16:00:24 localhost.localdomain systemd[1]: Started Time & Date Service.
Sep 11 16:00:25 localhost.localdomain rtkit-daemon[2002]: Successfully made thread 4043 of process 3901 owned by 'root' RT at priority 10.
Sep 11 16:00:36 localhost.localdomain kded5[3323]: Registering ":1.42/StatusNotifierItem" to system tray
Sep 11 16:00:54 localhost.localdomain systemd[1]: systemd-timedated.service: Deactivated successfully.
Sep 11 16:01:12 localhost.localdomain systemd[1]: snapperd.service: Deactivated successfully.
Sep 11 16:01:44 localhost.localdomain rtkit-daemon[2002]: Successfully made thread 4384 of process 3901 owned by 'root' RT at priority 10.
Sep 11 16:03:06 localhost.localdomain systemd[3199]: Starting Cleanup of User's Temporary Files and Directories...
Sep 11 16:03:06 localhost.localdomain systemd[3199]: Finished Cleanup of User's Temporary Files and Directories.
(als User root eingeloggt)
gast@localhost:~> sudo su
[sudo] Passwort für root:
localhost:/home/gast # journalctl -f
Sep 11 16:08:42 localhost.localdomain sudo[5463]: pam_kwallet5(sudo:auth): pam_kwallet5: Refusing to do anything for the root user
Sep 11 16:08:49 localhost.localdomain sudo[5463]: gast : TTY=pts/1 ; PWD=/home/gast ; USER=root ; COMMAND=/usr/bin/su
Sep 11 16:08:49 localhost.localdomain sudo[5463]: pam_kwallet5(sudo:setcred): pam_kwallet5: pam_sm_setcred
Sep 11 16:08:49 localhost.localdomain sudo[5463]: pam_unix(sudo:session): session opened for user root by gast(uid=1003)
Sep 11 16:08:49 localhost.localdomain sudo[5463]: pam_kwallet5(sudo:session): pam_kwallet5: pam_sm_open_session
Sep 11 16:08:49 localhost.localdomain sudo[5463]: pam_kwallet5(sudo:session): pam_kwallet5: we were already executed
Sep 11 16:08:49 localhost.localdomain su[5511]: (to root) root on pts/2
Sep 11 16:08:49 localhost.localdomain su[5511]: pam_unix(su:session): session opened for user root by gast(uid=0)
Sep 11 16:08:49 localhost.localdomain su[5511]: pam_kwallet5(su:session): pam_kwallet5: pam_sm_open_session
Sep 11 16:08:49 localhost.localdomain su[5511]: pam_kwallet5(su:session): pam_kwallet5: not a graphical session, skipping. Use force_run parameter to ignore this.
als User "gast" mit Rootrechten
Grafisch als nicht funktionierender User in Plasma anmelden.
Dann ein Terminal starten, root werden und eingeben:
Jetzt ein neues Unterfenster in diesem Terminal starten oder ein neues Terminal starten und dort als nicht funktionierender User eingeben:
Warten und alle neu hinzugekommenen Meldungen im root Terminal hier posten.
Passwort:
Sep 11 16:18:50 localhost.localdomain smartd[990]: Device: /dev/sdd [SAT], starting scheduled Short Self-Test.
Sep 11 16:21:50 localhost.localdomain kwin_x11[4732]: kwin_core: XCB error: 152 (BadDamage), sequence: 62416, resource id: 10491314, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 11 16:22:04 localhost.localdomain systemd[4617]: Started Konsole - Terminal.
Sep 11 16:22:10 localhost.localdomain su[5795]: pam_kwallet5(su:auth): pam_kwallet5: pam_sm_authenticate
Sep 11 16:22:10 localhost.localdomain su[5795]: pam_kwallet5(su:auth): pam_kwallet5: we were already executed
Sep 11 16:22:17 localhost.localdomain su[5795]: (to root) gast on pts/1
Sep 11 16:22:17 localhost.localdomain su[5795]: pam_kwallet5(su:setcred): pam_kwallet5: pam_sm_setcred
Sep 11 16:22:17 localhost.localdomain su[5795]: pam_unix(su:session): session opened for user root by gast(uid=1003)
Sep 11 16:22:17 localhost.localdomain su[5795]: pam_kwallet5(su:session): pam_kwallet5: pam_sm_open_session
Sep 11 16:22:17 localhost.localdomain su[5795]: pam_kwallet5(su:session): pam_kwallet5: we were already executed
Sep 11 16:23:06 localhost.localdomain systemd[1]: Starting Backup /etc/sysconfig directory...
Sep 11 16:23:06 localhost.localdomain systemd[1]: backup-sysconfig.service: Deactivated successfully.
Sep 11 16:23:06 localhost.localdomain systemd[1]: Finished Backup /etc/sysconfig directory.
Sep 11 16:23:15 localhost.localdomain kwin_x11[4732]: kwin_core: XCB error: 3 (BadWindow), sequence: 5156, resource id: 36700210, major code: 129 (SHAPE), minor code: 6 (Input)
Sep 11 16:23:18 localhost.localdomain kernel: es2netif[5882]: segfault at c0 ip 00007fd300079d6e sp 00007fff687bdb70 error 4 in libc.so.6[7fd300000000+1fb000] likely on CPU 1 (core 1, socket 0)
Sep 11 16:23:18 localhost.localdomain kernel: Code: 41 55 41 89 cd 41 54 49 89 d4 55 48 89 f5 53 48 89 fb 48 81 ec f8 00 00 00 64 48 8b 04 25 28 00 00 00 48 89 84 24 e8 00 00 00 <8b> 87 c0 00 00 00 85 c0 0f 85 a4 00 00 00 c7 87 c0 00 00 00 ff ff
gast@localhost:~> epsonscan2
libpng warning: iCCP: known incorrect sRGB profile
which: no avahi-browse in (/home/gast/bin:/usr/local/bin:/usr/bin:/bin)
Das epsonscan2-Icon hat sich nach dem Klicken des "Weiter"-Bottons geschlossen.
In dem Zustand bleibt das Terinal-Fenster bis ich den PC herunterfahre.
Ich habe den Systemmonitor auf. Das Programm steht noch in der Liste der Programme und in der Liste der Prozesse. Es belgt, wie es ausieht, nur Speicher.
