Amarok startet bei mir nicht mehr. Wenn ich es öffne, dann erscheint nur ein Absturzfenster.
Folgende Daten spuckt der aus:
Application: Amarok (amarok), signal: Segmentation fault
Using host libthread_db library "/lib64/libthread_db.so.1".
[KCrash Handler]
#5 0x00007efcbae4306c in __strcmp_ssse3 () from /lib64/libc.so.6
#6 0x00007efc9982cfee in QMetaType::registerNormalizedType(QByteArray const&, void (*)(void*), void* (*)(void const*), void (*)(void*), void* (*)(void*, void const*), int, QFlags<QMetaType::TypeFlag>, QMetaObject const*) () from /usr/lib64/libQt5Core.so.5
#7 0x00007efc99d30f57 in ?? () from /usr/lib64/libQt5Gui.so.5
#8 0x00007efcbdf4d92a in call_init.part () from /lib64/ld-linux-x86-64.so.2
#9 0x00007efcbdf4da13 in _dl_init_internal () from /lib64/ld-linux-x86-64.so.2
#10 0x00007efcbdf51b48 in dl_open_worker () from /lib64/ld-linux-x86-64.so.2
#11 0x00007efcbdf4d7e4 in _dl_catch_error () from /lib64/ld-linux-x86-64.so.2
#12 0x00007efcbdf5133b in _dl_open () from /lib64/ld-linux-x86-64.so.2
#13 0x00007efcb5d2002b in dlopen_doit () from /lib64/libdl.so.2
#14 0x00007efcbdf4d7e4 in _dl_catch_error () from /lib64/ld-linux-x86-64.so.2
#15 0x00007efcb5d205dd in _dlerror_run () from /lib64/libdl.so.2
#16 0x00007efcb5d200c1 in dlopen@@GLIBC_2.2.5 () from /lib64/libdl.so.2
#17 0x00007efc9ff0359f in ?? () from /usr/lib64/libvlccore.so.7
#18 0x00007efc9feecd5d in ?? () from /usr/lib64/libvlccore.so.7
#19 0x00007efc9feed057 in ?? () from /usr/lib64/libvlccore.so.7
#20 0x00007efc9feed2c9 in ?? () from /usr/lib64/libvlccore.so.7
#21 0x00007efc9feed534 in ?? () from /usr/lib64/libvlccore.so.7
#22 0x00007efc9feeda87 in ?? () from /usr/lib64/libvlccore.so.7
#23 0x00007efc9fe8549d in libvlc_InternalInit () from /usr/lib64/libvlccore.so.7
#24 0x00007efc9fc4f623 in libvlc_new () from /usr/lib64/libvlc.so.5
#25 0x00007efca01afec9 in ?? () from /usr/lib64/kde4/plugins/phonon_backend/phonon_vlc.so
#26 0x00007efca0195728 in ?? () from /usr/lib64/kde4/plugins/phonon_backend/phonon_vlc.so
#27 0x00007efca01961eb in qt_plugin_instance () from /usr/lib64/kde4/plugins/phonon_backend/phonon_vlc.so
#28 0x00007efcbb536641 in QPluginLoader::instance() () from /usr/lib64/libQtCore.so.4
#29 0x00007efca0a46f8b in ?? () from /usr/lib64/kde4/plugins/phonon_platform/kde.so
#30 0x00007efca0a47773 in ?? () from /usr/lib64/kde4/plugins/phonon_platform/kde.so
#31 0x00007efcb789ac76 in ?? () from /usr/lib64/libphonon.so.4
#32 0x00007efcb789b317 in Phonon::Factory::backend(bool) () from /usr/lib64/libphonon.so.4
#33 0x00007efcb789b8e3 in ?? () from /usr/lib64/libphonon.so.4
#34 0x00007efcb78939b9 in ?? () from /usr/lib64/libphonon.so.4
#35 0x00007efcb7891896 in ?? () from /usr/lib64/libphonon.so.4
#36 0x00007efcbd1eaa6c in EngineController::initializePhonon() () from /usr/lib64/libamaroklib.so.1
#37 0x00007efcbd1f1265 in ?? () from /usr/lib64/libamaroklib.so.1
#38 0x00007efcbb55a348 in QMetaMethod::invoke(QObject*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) const () from /usr/lib64/libQtCore.so.4
#39 0x00007efcbb55c802 in QMetaObject::invokeMethod(QObject*, char const*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) () from /usr/lib64/libQtCore.so.4
#40 0x00007efcbd2b0d5d in ?? () from /usr/lib64/libamaroklib.so.1
#41 0x00007efcbd2b0dc1 in ?? () from /usr/lib64/libamaroklib.so.1
#42 0x00007efcbd1e3b5d in App::continueInit() () from /usr/lib64/libamaroklib.so.1
#43 0x00007efcbd1e4cb6 in App::App() () from /usr/lib64/libamaroklib.so.1
#44 0x0000000000407fa7 in ?? ()
#45 0x00007efcbad40b05 in __libc_start_main () from /lib64/libc.so.6
#46 0x00000000004080d2 in _start ()
Ich hatte vor ein paar Tagen einen Codec installiert, damit ich WMA-Dateien abspielen kann. Das funktionierte auch, aber jetzt eben nicht mehr. Deshalb habe ich mir heute gstreamer-0_10-plugins-ffmpeg installiert. Besteht da ein Zusammenhang?
