Nach Installation von OpenSuse Leap 15.0 kann nur noch im Wiederherstellungsmodus gebootet werden
- ChristianB
Hinweis: In dem Thema Nach Installation von OpenSuse Leap 15.0 kann nur noch im Wiederherstellungsmodus gebootet werden gibt es 33 Antworten auf 4 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
Ich seh' da keine Driver Zeile...
Und hast du mal Sauerlands Rat mit LXDE probiert?
Alles anzeigenOpenChrome DDX Version 0.6 Release Note (March 7th, 2017) --------------------------------------------------------- OpenChrome DDX is an open source implementation of X.Org Server DDX (Device Dependent X) graphics device driver for VIA Technologies UniChrome and Chrome9 IGPs. (Integrated Graphics Processor) OpenChrome DDX handles only 2D and video acceleration. Please note that OpenChrome does not support VIA Technologies IGPs that are related to Trident Microsystems (i.e., Apollo MVP4, PLE133, and KLE133) or S3 Graphics (i.e., KM266). Here is the project home page for OpenChrome. http://www.freedesktop.org/wiki/Openchrome/ Please note that VIA Technologies does not support OpenChrome in any way. Supported Chipsets ------------------ - CLE266 - KM400(A) / KN400(A) / P4M800 - K8M800 / K8N800 - PM800 / PN800 / PM880 / CN333 / CN400 - P4M800 Pro / VN800 / CN700 - CX700 / VX700 - P4M890 / VN890 / CN800 - K8M890 / K8N890 - P4M900 / VN896 / CN896 - VX800 / VX820 - VX855 / VX875 - VX900 Supported Features ------------------ - VGA - DVI from an integrated TMDS transmitter (CX700, VX700, and VX800 chipsets) - DVI from Silicon Image SiI 164 and VIA Technologies VT1632(A) TMDS transmitters - Flat Panel - EXA acceleration (RENDER acceleration) - Xv and XvMC - Dual monitor support Unproven Features ----------------- - Standby resume - TV out - KMS support (Kernel Mode Setting; requires the use of still in development KMS supporting OpenChrome DRM. See "Where to Obtain OpenChrome Source Code" section for more details.) Unimplemented Features ---------------------- - Hardware cursor support for CLE266, KM400(A) / KN400(A), and P4M800 chipsets - DVI via Chrontel TMDS transmitter - LVDS via VT1631 / VT1636 LVDS transmitter - External HDMI transmitter (i.e., Jetway J7F5M-VHE-LF motherboard, VIA Embedded EPIA-P720 motherboard, etc.) - HDMI support for VX900 chipset (HDMI is supported via still in development KMS supporting OpenChrome DRM. See "Where to Obtain OpenChrome Source Code" section for more details.) - DisplayPort support for VX900 chipset OS Support ---------- - X.Org Server Version 1.7 or later (It might not work correctly if it is compiled against an older X.Org Server.) - Linux Version 2.6.32 or later (Note: For Linux Version 4.5 or later, you may have to blacklist vesafb. This is a bug that has not been fixed so far.) What's New for OpenChrome DDX Version 0.6 ----------------------------------------- OpenChrome DDX Version 0.6 is an improved version of OpenChrome DDX Version 0.5 with a number of improvements made to the code. OpenChrome DDX Version 0.6 is written in a way to completely replace Version 0.2.904 through 0.5. OpenChrome DDX Version 0.6 has added the following new features. - First official support for CX700, VX700, and VX800 chipsets integrated TMDS transmitter (i.e., DVI support) - Initial support for Silicon Image SiI 164 TMDS transmitter OpenChrome DDX Version 0.6 has the following improvements. - Improved FP reinitialization when resuming from standby (HP 2133 Mini-Note, FIC CE260 / CE261 based netbooks like Everex CloudBook and Sylvania g netbook) - Improved automatic detection of display resources - Improved X Server stability in dual monitor mode - Automatic active steering of the display controller channel to the correct display output device OpenChrome DDX Version 0.6 fixes the following bugs. - Fix for the disruption of the VT (Virtual Terminal) screen bug introduced in Version 0.5 - Fix for HP 2133 Mini-Note's PCIe WLAN getting turned off inadvertently bug introduced in Version 0.5Quelle: /usr/share/doc/packages/xf86-video-openchrome/README
Daher wären auch die Ergebnisse von:
oder statt letzteren auch
eventuell nicht uninteressant. -
hier erst einmal die Antworten:
linux-81d6:~ #grep -Ei -B2 -A2 vesafb /etc/modprobe.d/50-blacklist.conf
# list all framebuffer drivers, some of them tend to crash during boot
# they are either compiled into the kernel, or vesafbis active
# X works fine without them, rcfbset can load them if really required
# sed -e '/\/drivers\/video\/.*\.\(o\|ko\)$/{s@^.*/@@;s@\..*$@@;p};d'
linux-81d6:~ #dmesg | grep -Ei "vesa|chrome|open|via|s3"
[ 0.000000] ACPI: RSDP 0x00000000000F78C0 000014 (v00VIAK8M)
[ 0.000000] ACPI: RSDT 0x000000007BEF3040 00002C (v01 VIAK8M AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 0x000000007BEF30C0 000074 (v01 VIAK8M AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 0x000000007BEF3180 005396 (v01 VIAK8M AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: APIC 0x000000007BEF8580 000068 (v01 VIAK8M AWRDACPI 42302E31 AWRD 00000000)
[ 0.117195] pci 0000:00:01.0: disabling DAC on VIAPCI bridge
[ 0.120388] pci 0000:00:10.4: VIAVLink IRQ fixup, from 5 to 11
[ 1.748645]vesafb: mode is 1366x768x32, linelength=5504, pages=0
[ 1.748655] vesafb: scrolling: redraw
[ 1.748663]vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 1.748689] vesafb: framebuffer at 0xf0000000, mapped to 0xffffc90000800000, using 4160k, total 4160k
[ 1.971513] fb0:VESAVGA frame buffer device
[ 6.289273] sata_via0000:00:0f.0: version 2.6
[ 6.289550] sata_via0000:00:0f.0: routed to hard irq line 11
[ 6.329717] scsi host0: sata_via
[ 6.366943] scsi host1: sata_via
[ 8.126336] pata_via0000:00:0f.1: version 0.3.4
[ 8.126556] pata_via0000:00:0f.1: VIAVLink IRQ fixup, from 255 to 10
[ 8.162377] scsi host2: pata_via
[ 8.194936] scsi host3: pata_via
[ 22.294236] audit: type=1400 audit(1534689934.369:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lessopen.sh" pid=481 comm="apparmor_parser"
[ 23.984534] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[ 24.046739] via-rhine 0000:00:12.0 eth0: VIARhine II at 0xffffc900004d5000, 00:19:db:bc:e4:90, IRQ 10
[ 24.109746] via-rhine 0000:00:12.0 eth0: MII PHY found at address 1, status 0x786d advertising 01e1 Link 4de1
[ 25.457723] snd_via82xx 0000:00:11.5: VIAVLink IRQ fixup, from 5 to 11
linux-81d6:~ #grep -Ei "vesa|chrome|open|via|s3" /var/log/Xorg.0.log
[ 75.907] Build Operating System: openSUSE SUSE LINUX
[ 76.045] (**) |-->Screen "vesa" (4)
[ 76.046] (**) | |-->Device "vesa"
[ 76.046] (==) No monitor specified for screen "vesa".
[ 76.201] (WW) Warning, couldn't openmodule vboxvideo
[ 76.893] (II) LoadModule: "vesa"
[ 76.893] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 76.902] (II) Module vesa: vendor="X.Org Foundation"
[ 76.902] (II) VESA: driver for VESAchipsets: vesa
[ 77.013] (EE) open/dev/dri/card0: No such file or directory
[ 77.024] (II) FBDEV(0): hardware: VESAVGA (video memory: 4160kB)
[ 77.113] (II) UnloadModule: "vesa"
[ 77.113] (II) Unloading vesa
[ 78.808] (II) config/udev: Adding input device (unnamed) (/dev/ttyS3)
[ 78.809] (II) config/udev: Adding input device (unnamed) (/dev/ttyS30)
[ 78.809] (II) config/udev: Adding input device (unnamed) (/dev/ttyS31)
linux-81d6:~ #grep -E "EE|WW" /var/log/Xorg.0.log
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 76.083] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
[ 76.201] (WW) Warning, couldn't open module vboxvideo
[ 76.201] (EE) Failed to load module "vboxvideo" (module does not exist, 0)
[ 77.013] (EE) open /dev/dri/card0: No such file or directory
[ 77.013] (WW) Falling back to old probe method for modesetting
[ 77.024] (EE) Screen 0 deleted because of no matching config section.
[ 77.134] (EE) AIGLX: reverting to software rendering
linux-81d6:~ #Ich habe mir zwar lxde installiert, ich weiß aber nicht, was das bringen soll. Wenn ich im Bootmenue den Defaultparameter wähle, stürzt der Rechner ab, ich komme gar nicht zu dem Anmeldemenue, bei dem ich lxde auswählen könnte. Es ist übrigens definitiv der Wiederherstellungsmodus, wo es dann auch funktioniert (auch Plasma) hier der entsprechende Eintrag in grub.cfg:
menuentry 'openSUSE Leap 15.0, mit Linux 4.12.14-lp150.12.16-default (Wiederherstellungsmodus)' --hotkey=3 --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.12.14-lp150.12.16-default-recovery-8817d20a-f2bc-4d7f-9079-bfc59b0e555d' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
set root='hd0,msdos2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2 --hint='hd0,msdos2' 8817d20a-f2bc-4d7f-9079-bfc59b0e555d
else
search --no-floppy --fs-uuid --set=root 8817d20a-f2bc-4d7f-9079-bfc59b0e555d
fi
echo 'Linux 4.12.14-lp150.12.16-default wird geladen …'
linux /boot/vmlinuz-4.12.14-lp150.12.16-default root=UUID=8817d20a-f2bc-4d7f-9079-bfc59b0e555d showopts apm=off noresume nosmp maxcpus=0 edd=off powersaved=off nohz=off highres=off processor.max_cstate=1 nomodeset x11failsafe
echo 'Initiale Ramdisk wird geladen …'
initrd /boot/initrd-4.12.14-lp150.12.16-default
}und das ist der Eintrag, bei dem es nicht funktioniert
menuentry 'openSUSE Leap 15.0' --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-8817d20a-f2bc-4d7f-9079-bfc59b0e555d' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.12.14-lp150.12.16-default root=UUID=8817d20a-f2bc-4d7f-9079-bfc59b0e555d resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts resume=/dev/disk/by-id/ata-SAMSUNG_HD322HJ_S17AJ90SA68029-part1 splash=silent quiet showopts
}Ich könnte jetzt zwar mit der Brechstange rangehen und den funktionierenden Eintrag über den Defaulteintrag kopieren, aber zum einen Mal weiß ich nicht, ob es da nicht noch andere Seiteneffekte gibt und zum anderen wüsste ich auch ganz gerne, warum es nicht funktioniert.
Boote mal mit nomodeset:
Grub2 zusätzliche Bootparameter einfügenUnd benutze für Konsolenausgaben bitte separate Code-Tags, siehe unter diesem Text.
Hat er schon:
Die Einführung der zus. Bootparameters nomodeset führt zum gleichen Ergebnis.
Kann es sein, dass es garnichts mit der Grafik zu tun hat?
Es muss doch ein aussagekräftiges Protokoll geben.
Du hast geschrieben, dass der Rechner unter Leap 42.3 lief und seit Leap 15 nicht.
Hast du ein Upgrade gemacht oder neu installiert? -
die zwei weiter unten funktionieren auch nicht, allerdings mit einem anderen Fehlerbild.
Boote mal mit nem alten Kernel.......
Und poste......… -
Noch ein Versuch und schnell getestet:
Grub - auf den aktuellen (nicht funktionierenden) Eintrag
"e" zum Editieren
und mach aus: splash=silent quiet showopts
ein: splash=verbose
Speichern und startenPS:
Aber Sauerland geht vor -
Versuch es mal hiermit tsc=unstable statt nomodeset
Und was ist mit:
Alles anzeigenOS Support ---------- - X.Org Server Version 1.7 or later (It might not work correctly if it is compiled against an older X.Org Server.) - Linux Version 2.6.32 or later (Note: For Linux Version 4.5 or later, you may have to blacklist vesafb. This is a bug that has not been fixed so far.)Quelle: /usr/share/doc/packages/xf86-video-openchrome/README
# sed -e '/\/drivers\/video\/.*\.\(o\|ko\)$/{s@^.*/@@;s@\..*$@@;p};d'Da dem nicht so ist, könntest du das mal ausprobieren.
Auf http://www.freedesktop.org/wiki/Openchrome/ ist auch was zu deaktivierten Module wegen Abstürze zu finden.Mich würden ja auch die Ausgaben ausgeführt unter openSUSE Leap 42.3 interessieren.
