Lexmark MX410 de und scannen
- guenter57
Hinweis: In dem Thema Lexmark MX410 de und scannen gibt es 43 Antworten auf 5 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
localhost:~ # sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x0403 [FTDI], product=0x6001 [USB Serial Converter]) at libusb:003:002
found USB scanner (vendor=0x043d [Lexmark], product=0x0230 [Lexmark MX410de]) at libusb:001:003
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
Als user:
guenter@localhost:~> sane-find-scanner
could not open USB device 0x8087/0x0024 at 002:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 004:001: Access denied (insufficient permissions)
could not open USB device 0x0403/0x6001 at 003:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 003:001: Access denied (insufficient permissions)
could not open USB device 0x0458/0x0056 at 001:005: Access denied (insufficient permissions)
could not open USB device 0x046d/0xc312 at 001:004: Access denied (insufficient permissions)
could not open USB device 0x043d/0x0230 at 001:003: Access denied (insufficient permissions)
could not open USB device 0x8087/0x0024 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
# No USB scanners found. If you expected something different, make sure that
# you have loaded a kernel driver for your USB host controller and have setup
# the USB system correctly. See man sane-usb for details.
# You may want to run this program as root to find all devices. Once you
# found the scanner devices, be sure to adjust access permissions as
# necessary.
Im Klartext: Mit an Sicherheit grenzender Wahrscheinlichkeit wurde ein USB Scanner gefunden. Es handelt sich evtl. um einen Lexmark MX410de.
Probiere doch einfach in einer Konsole den Befehl
scanimage -L
Ein normal dahergelogter User darf per se nicht an den Geräten rumfummeln. Das darf nur root.
Wenn root das Gerät sauber einrichtet, dürfen die Otto- Normal- Loser auch das Ding verwenden, wenn der root nicht allzu gemein zu seinen Losern ist.
und jetzt?
Yast----Sicherheit----Security Center-----verschiedene Einstellungen----Dateiberechtigungen sagt was?
Dateiberechtigungen:
Easy
Benutzer der updatedb starten soll:
nobody
Magic SysRq Keys:
184
ich hatte mal ähnlich Probleme mit einem Epson. Bei mir hat es geholfen in Yast "Scannen über Netzwerk" zu wählen, und dort die IP-Adresse des Scanner ein zu tragen (hatte dem Scanner eine feste IP zugewiesen). Und dann dort nach dem Scanner suchen zu lassen. Dort wurde der Scanner dann gefunden. Danach hatte ich in der Übersicht 2 Treiber eingetragen. Einmal Net, wo dann merkwürdigerweise "kein Scanner gefunden" stand. Und einmal den Scanner mit seinem eigene Treiber. Das Scannen über Sane hat danach problemlos funktioniert. War zwar kein Lexmark, aber vielleicht hilft das ja auch bei Dir.
Hallo Schaer!
Ich habe das Problem, dass im Yast einmal der
Lexmark-Treiber :libnet
und
libusb
schon existieren.
Ich kann in Yast jedoch nicht dauerhaft den USB-Treiber auswählen.
Wenn ich als root xsane starte root ist alles ok.
Unter user wird immer der net-treiber gewählt.
Füge mal deinen User zur Gruppe lp hinzu und starte neu.
