Hallo zusammen,
da ich openOffice gewohnt bin anstatt LibreOffice wollte ich mir dieses auf meinem 12.2 installieren.
Folgende steps verliefen erfolgreich :
- Unpack the downloaded image to prepare for installation.
The following command should work: tar -xvzf "linux package name".tar.gz
where "linux package name" is the beginning part of the archive you just downloaded.
This will create an installation directory.
The name of the installation directory will likely be the language abbreviation for the install set, e.g., en-US.
- su to root, if necessary, and navigate to Apache OpenOffice installation directory (the unpacked
archive).You will likely need to be root to run the rpm command to install the software.
- cd into the RPMS subdirectory of the installation directory.
You should see a lot of rpms here and one sub-directory called "desktop-integration".
- Install this new version by typing rpm -Uvih *rpm.
By default, this will install/update Apache OpenOffice in your /opt directory.
Alternatively, you can use a GUI package installer, reference the installation directory, and install all rpms at the top
level. This may also aid you in determing any dependency problems if they exist. - Install the desktop integration features for your setup.
cd to desktop-integration in the installation directory,
and, depending on your package manager/system, install the appropriate desktop interface using RPM.
Beim letzten Punkt gabs dann ein Problem :
linux-v3e0:/home/thomas/Downloads/de/RPMS/desktop-integration # rpm -ivh openoffice.org3.4-suse-menus-3.4-9593.noarch.rpm
Preparing... ########################################### [100%]
file /usr/bin/soffice from install of openoffice.org3.4-suse-menus-3.4-9593.noarch conflicts with file from package libreoffice-3.5.4.13-1.4.5.i586
linux-v3e0:/home/thomas/Downloads/de/RPMS/desktop-integration # ![]()
Danke schon mal für weitere Hilfe... ![]()
