Ich denke ich habe das Video gefunden, um das es hier geht.
Das läuft hier problemlos mit Kaffeine, Smplayer usw.
Phonon backend ist bei mir
cat /etc/os-r*
NAME=openSUSE
VERSION="13.1 (Bottle)"
VERSION_ID="13.1"
PRETTY_NAME="openSUSE 13.1 (Bottle) (x86_64)"
zypper se -si gstreamer vlc kaffeine ffmpeg faa
Installierte Pakete lesen ...
i | chromium-ffmpegsumo | Paket | 31.0.1650.57-8.2 | x86_64 | openSUSE-13.1-Update
i | faac | Paket | 1.28-9.2 | x86_64 | Packman Repository
i | faad2 | Paket | 2.7-13.2 | x86_64 | Packman Repository
i | ffmpeg | Paket | 2.1.1-3.2 | x86_64 | Packman Repository
i | ffmpeg-tools | Paket | 2.1.1-3.2 | x86_64 | Packman Repository
i | ffmpeg2theora | Paket | 0.29-2.6 | x86_64 | Packman Repository
i | ffmpegthumbnailer | Paket | 2.0.8-3.3 | x86_64 | Packman Repository
i | gstreamer | Paket | 1.2.1-3.6 | x86_64 | Packman Repository
i | gstreamer-0_10 | Paket | 0.10.36-14.17 | x86_64 | Packman Repository
i | gstreamer-0_10-lang | Paket | 0.10.36-14.17 | noarch | Packman Repository
i | gstreamer-0_10-plugin-esd | Paket | 0.10.31-16.5 | x86_64 | Packman Repository
i | gstreamer-0_10-plugin-gnomevfs | Paket | 0.10.36-12.30 | x86_64 | Packman Repository
i | gstreamer-0_10-plugin-gnonlin | Paket | 0.10.17-17.1.3 | x86_64 | openSUSE-13.1-1.10
i | gstreamer-0_10-plugins-bad | Paket | 0.10.23-24.17 | x86_64 | Packman Repository
i | gstreamer-0_10-plugins-bad-lang | Paket | 0.10.23-24.17 | noarch | Packman Repository
i | gstreamer-0_10-plugins-bad-orig-addon | Paket | 0.10.23-24.17 | x86_64 | Packman Repository
i | gstreamer-0_10-plugins-base | Paket | 0.10.36-12.30 | x86_64 | Packman Repository
i | gstreamer-0_10-plugins-base-lang | Paket | 0.10.36-12.30 | noarch | Packman Repository
i | gstreamer-0_10-plugins-buzztard | Paket | 0.6.0-9.27 | x86_64 | Packman Repository
i | gstreamer-0_10-plugins-ffmpeg | Paket | 0.10.13-2000.2 | x86_64 | Packman Repository
i | gstreamer-0_10-plugins-good | Paket | 0.10.31-16.5 | x86_64 | Packman Repository
i | gstreamer-0_10-plugins-good-extra | Paket | 0.10.31-16.5 | x86_64 | Packman Repository
i | gstreamer-0_10-plugins-good-lang | Paket | 0.10.31-16.5 | noarch | Packman Repository
i | gstreamer-0_10-plugins-qt | Paket | 0.10.3-1.1 | x86_64 | openSUSE-13.1-1.10
i | gstreamer-0_10-plugins-ugly | Paket | 0.10.19-12.2 | x86_64 | Packman Repository
i | gstreamer-0_10-plugins-ugly-lang | Paket | 0.10.19-12.2 | noarch | Packman Repository
i | gstreamer-0_10-plugins-ugly-orig-addon | Paket | 0.10.19-12.2 | x86_64 | Packman Repository
i | gstreamer-0_10-utils | Paket | 0.10.36-14.17 | x86_64 | Packman Repository
i | gstreamer-0_10-utils-unversioned | Paket | 0.10.36-14.17 | x86_64 | Packman Repository
i | gstreamer-lang | Paket | 1.2.1-3.6 | noarch | Packman Repository
i | gstreamer-plugin-gstclutter | Paket | 2.0.8-3.1 | x86_64 | openSUSE-13.1-Update
i | gstreamer-plugins-bad | Paket | 1.2.1-5.26 | x86_64 | Packman Repository
i | gstreamer-plugins-base | Paket | 1.2.1-2.12 | x86_64 | Packman Repository
i | gstreamer-plugins-good | Paket | 1.2.1-2.5 | x86_64 | Packman Repository
i | kaffeine | Paket | 1.2.2-27.3 | x86_64 | KDE_412_extra
i | kffmpegthumbnailer | Paket | 1.1.0-2.1 | x86_64 | Packman Repository
i | libQtGStreamer-0_10-0 | Paket | 0.10.3-1.1 | x86_64 | openSUSE-13.1-1.10
i | libfaac0 | Paket | 1.28-9.2 | x86_64 | Packman Repository
i | libfaad2 | Paket | 2.7-13.2 | x86_64 | Packman Repository
i | libffmpegthumbnailer4 | Paket | 2.0.8-3.3 | x86_64 | Packman Repository
i | libgstreamer-0_10-0 | Paket | 0.10.36-14.17 | x86_64 | Packman Repository
i | libgstreamer-0_10-0-32bit | Paket | 0.10.36-14.17 | x86_64 | Packman Repository
i | libgstreamer-1_0-0 | Paket | 1.2.1-3.6 | x86_64 | Packman Repository
i | libvlc5 | Paket | 2.1.2-186.13 | x86_64 | Packman Repository
i | libvlccore7 | Paket | 2.1.2-186.13 | x86_64 | Packman Repository
i | phonon-backend-vlc | Paket | 0.7.0-9.1 | x86_64 | openSUSE-13.1-Update
i | python-gstreamer-0_10 | Paket | 0.10.22-10.2 | x86_64 | Packman Repository
i | vlc | Paket | 2.1.2-186.13 | x86_64 | Packman Repository
i | vlc-codecs | Paket | 2.1.2-186.13 | x86_64 | Packman Repository
i | vlc-noX | Paket | 2.1.2-186.13 | x86_64 | Packman Repository
i | vlc-noX-lang | Paket | 2.1.2-186.13 | noarch | Packman Repository
i | vlc-qt | Paket | 2.1.2-186.13 | x86_64 | Packman Repository
Technische Spezifikationen mit medianfo-gui ermittelt :
General
Complete name : Fantasy - Flaschenpost (Offizielles Video)(720p_H.264-AAC).mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 81.9 MiB
Duration : 3mn 42s
Overall bit rate mode : Variable
Overall bit rate : 3 082 Kbps
Encoded date : UTC 2013-11-17 11:57:05
Tagged date : UTC 2013-11-17 11:57:05
gsst : 0
gstd : 222933
gssd : B400F7005HH1388142095763051
gshh : r2---sn-xjpm-q0nl.googlevideo.com
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 42s
Bit rate : 2 888 Kbps
Maximum bit rate : 6 492 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.125
Stream size : 76.7 MiB (94%)
Tagged date : UTC 2013-11-17 11:57:17
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 3mn 42s
Bit rate mode : Variable
Bit rate : 192 Kbps
Maximum bit rate : 201 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 5.10 MiB (6%)
Title : IsoMedia File Produced by Google, 5-11-2011
Encoded date : UTC 2013-11-17 11:57:13
