Hallo Forum,
ich brauche mal wieder Hilfe und Nachsicht von Euch.
Ich habe auf meinem System (13.1) versucht, einen USB-Scanner (CanoScan 9000F Mark II) zu installieren.
Ich hatte o.a. Scanner gewählt, weil er hier (http://www.sane-project.org/sane-mfgs.html) als unterstützt angegeben wird.
Dann habe ich gemäß Anleitung (http://mp610.blogspot.fr/2008/…ner-new-freshly-sane.html)
die weiteren Schritte ausgeführt.
Nach ./configure bekomme ich den Hinweis:
*** Warning: sane-backends will be built without libusb support. There may
*** be valid reasons to do so, e.g. if you don't use USB scanners or on
*** platforms without libusb support but generally this means that you
*** can't use USB devices with SANE. The most probable cause is that
*** the libusb header file usb.h is not installed. If you use Linux
*** you may need a package called 'libusb-dev', 'libusb-devel' or similar.
Nach make und make-install bekomme ich auf:
Und auf:
scanimage -L:
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
Nach sane-find-scanner erhalte ich:
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No USB scanners found. If you expected something different, make sure that
# you have loaded a kernel driver for your USB host controller and have setup
# the USB system correctly. See man sane-usb for details.
# SANE has been built without libusb support. This may be a reason
# for not detecting USB scanners. Read README for more details
Was mache ich falsch?
Danke für Hilfe
Ge128
Ausgaben bitte in Code-Tags
