[GELÖST]USB Wechselfestplatte mounten
- gianni2014
Hinweis: In dem Thema [GELÖST]USB Wechselfestplatte mounten gibt es 26 Antworten auf 3 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
blkid -o list -w /dev/null device fs_type label mount point UUID --------------------------------------------------------------------------------------------------------------------- /dev/sda1 swap <swap> 2e9ef5ea-b3be-4dc7-96a9-ad686ea25368 /dev/sda2 btrfs (in use) bd2cc032-2914-4ad3-bfde-b66879ec7d91 /dev/sda3 xfs /home 639e13b9-07a5-4527-b18c-0d76bafb7e0d /dev/sdb1 ntfs (not mounted) 5C38D57338D54CA0
Alles anzeigenmount -l sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime) proc on /proc type proc (rw,nosuid,nodev,noexec,relatime) devtmpfs on /dev type devtmpfs (rw,nosuid,size=508148k,nr_inodes=127037,mode=755) securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime) tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev) devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000) tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755) tmpfs on /sys/fs/cgroup type tmpfs (rw,nosuid,nodev,noexec,mode=755) cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd) pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime) cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset) cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct) cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory) cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices) cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer) cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio) cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio) cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event) cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb) /dev/sda2 on / type btrfs (rw,relatime,space_cache) systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=28,pgrp=1,timeout=300,minproto=5,maxproto=5,direct) mqueue on /dev/mqueue type mqueue (rw,relatime) debugfs on /sys/kernel/debug type debugfs (rw,relatime) hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime) /dev/sda2 on /.snapshots type btrfs (rw,relatime,space_cache) /dev/sda2 on /var/tmp type btrfs (rw,relatime,space_cache) /dev/sda2 on /var/spool type btrfs (rw,relatime,space_cache) /dev/sda2 on /var/opt type btrfs (rw,relatime,space_cache) /dev/sda2 on /var/log type btrfs (rw,relatime,space_cache) /dev/sda2 on /var/lib/pgsql type btrfs (rw,relatime,space_cache) /dev/sda2 on /var/lib/named type btrfs (rw,relatime,space_cache) /dev/sda2 on /var/lib/mailman type btrfs (rw,relatime,space_cache) /dev/sda2 on /usr/local type btrfs (rw,relatime,space_cache) /dev/sda2 on /var/crash type btrfs (rw,relatime,space_cache) /dev/sda2 on /tmp type btrfs (rw,relatime,space_cache) /dev/sda2 on /srv type btrfs (rw,relatime,space_cache) /dev/sda2 on /opt type btrfs (rw,relatime,space_cache) /dev/sda2 on /boot/grub2/i386-pc type btrfs (rw,relatime,space_cache) /dev/sda3 on /home type xfs (rw,relatime,attr2,inode64,noquota) fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime) gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=100)
Vielen herzlichen Dank für den Tipp.
Ich habe die Ausführungen aufmerksam gelesen. Ich habe nur zwei reine Linux-PCs und muss erst mal zusehen, wie ich an einen Windows-PC komme, um die Platte zu reparieren, denn vermutlich werde ich in der Datei /etc/fstab erst dann den Hinweis auf Windows finden. Jetzt fehlt dieser Hinweis ja noch ganz.
Allerdings muss ich ehrlich gestehen, dass ich jetzt doch sehr deutlich an meine Grenzen stoße. Bin halt doch kein Informatiker. Sorry!!!
Da man auf dem Markt fast ausschließlich Wechselfestplatten findet, die auf Windows zugeschnitten sind, was muss Linux-Normal-User nun machen, wenn er sich eine solche zulegt bzw. zulegen muss? Oder als Umsteiger (wie ich) schlicht und einfach eine noch recht unverbrauchte, vielleicht sogar Top-WFP mitbringt? Gehe ich recht in der Annahme, dass ich die Platte anschließe, und, solange sie noch nicht beschädigt ist, mit Linux und für Linux partitioniere bzw. formatiere. Ist das der Weg, den man gehen muss? Und von da ab kann man sie (die WFP) an den verschiedensten Linux-PCs anschließen, sie wird erkannt, eingehängt, man kann mit ihr arbeiten, halt so wie man das bisher von Windows gewohnt war?!? Aber die Tür zu Windows ist dann definitiv zugestoßen??? Oder wie sehe ich das?
Mir würde eine knappe Antwort auf diese Frage genügen, danach möchte ich euch hier im Forum nicht länger bemühen und ich bitte den Moderator, diesen Thread zu schließen. Nochmals herzlichen Dank für alle Bemühungen! Dass Linux dann doch nicht ganz ohne Windows auskommt, das muss ich erst mal verkraften! Salü!
Ich wüßte jetzt nicht auf die schnelle, warum Wechselfestplatten nur auf Windows zugeschnitten sein sollten. Eher dürfte der gegenteilige Fall der Fall sein, meiner Meinung nach. Die meisten Serverfarmen laufen mit Linux.
Ich kaufe mir eine x-beliebige Platte, stöpsel die an und mach die mit gParted oder ähnlichem bereit für Linux. NTFS brauchst du nur bei Windows. Da du das komplett abgeschossen hast ... wozu NTFS?Nachtrag: Was verstehst du eigentlich unter einer Wechselfestplatte?
Ich meine, das ist ein Wechselrahmen mit stinknormalen Festplatten. Ich sehe also diesbezüglich keine Probleme. -
Meine USB-Festplatte (ist das der korrekte Begriff?) habe ich aus Windows-Zeiten "mitgebracht". Dorthin hatte ich die relevanten Daten abgelegt, Sicherungen, Backups. Nachdem ich dann auf einem alten XP-Rechner Opensuse 13.2 installiert hatte, spielte ich ohne jedes Problem die gesicherten Daten auf meinen ersten Linux-PC, der in der Zwischenzeit richtig schnell abfuhr. Ehrlich gesagt, war es mir zu diesem Zeitpunkt noch überhaupt nicht bewusst, dass auf dieser Festplatte NTFS als Dateisystem vorhanden war. Dann kam mein Laptop dran. Zunächst ein Dual-Boot-System. Als ich mich aber sehr schnell mit Linux zurechtfand, entfernte ich Windows definitiv. Und alles lief noch prächtig, bis ich über meinen Router ein kleines Netzwerk einrichtete. Danach gab es die schon beschriebenen Probleme mit der Festplatte. Gleichzeitig auf beiden Rechnern!!!! Soviel zur Erklärung.
Und ich wandte mich an das Forum, um zunächst einmal zu verstehen, was da schief gelaufen war, um so eventuell einen Weg zu finden, das Problem zu lösen. Tutto lì, sagen wir hier in Italien!
Dürfte ich dich aber dennoch etwas fragen, ob nun diese alte Festplatte, oder eine neue, welches Dateisystem würdest du spontan empfehlen. Die Festplatte dient ausschließlich Sicherungszwecken. Ich habe mich zu dieser Auseinandersetzung, welches Dateisystem, durch die Foren gelesen, und weiß, das ist für so manchem eine hochheilige Glaubensfrage. Aber ganz sachlich: Welches soll drauf? Gebraucht wird die Platte nur im Linux-Kontext!
Erkläre, was Du gemacht hast, poste die Ausgabe in Code-Tags von: -
Ohne jetzt an den Fragen von Sauerland vorbeireden zu wollen ... ich persönlich würde die Platte mit ext4 formatieren.
Aber mach erst mal mit Sauerlands Antworten weiter. Wir kriegen die Kuh schon vom Eis geschoben. -
@Sauerland
Was habe ich gemacht? Rechner A (Desktop), über Kabel mit Router verbunden, und Rechner B, kabellos, mit openssh miteinander verbunden ...
Alles anzeigenfdisk -l Festplatte /dev/sda: 186,3 GiB, 200049647616 Bytes, 390721968 Sektoren Einheiten: Sektoren von 1 * 512 = 512 Bytes Sektorgröße (logisch/physikalisch): 512 Bytes / 512 Bytes E/A-Größe (minimal/optimal): 512 Bytes / 512 Bytes Festplattenbezeichnungstyp: dos Festplattenbezeichner: 0x4b1a4b19 Device Boot Start End Sectors Size Id Type /dev/sda1 2048 4208639 4206592 2G 82 Linux swap / Solaris /dev/sda2 * 4208640 88100863 83892224 40G 83 Linux /dev/sda3 88100864 390721535 302620672 144,3G 83 Linux Festplatte /dev/sdb: 465,8 GiB, 500107862016 Bytes, 976773168 Sektoren Einheiten: Sektoren von 1 * 512 = 512 Bytes Sektorgröße (logisch/physikalisch): 512 Bytes / 512 Bytes E/A-Größe (minimal/optimal): 512 Bytes / 512 Bytes Festplattenbezeichnungstyp: dos Festplattenbezeichner: 0x4bfb49f8 Device Boot Start End Sectors Size Id Type /dev/sdb1 2048 976771071 976769024 465,8G 7 HPFS/NTFS/exFAT
Alles anzeigencat /etc/fstab UUID=2e9ef5ea-b3be-4dc7-96a9-ad686ea25368 swap swap defaults 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 / btrfs defaults 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /boot/grub2/i386-pc btrfs subvol=boot/grub2/i386-pc 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /opt btrfs subvol=opt 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /srv btrfs subvol=srv 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /tmp btrfs subvol=tmp 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /usr/local btrfs subvol=usr/local 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /var/crash btrfs subvol=var/crash 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /var/lib/mailman btrfs subvol=var/lib/mailman 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /var/lib/named btrfs subvol=var/lib/named 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /var/lib/pgsql btrfs subvol=var/lib/pgsql 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /var/log btrfs subvol=var/log 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /var/opt btrfs subvol=var/opt 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /var/spool btrfs subvol=var/spool 0 0 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /var/tmp btrfs subvol=var/tmp 0 0 UUID=639e13b9-07a5-4527-b18c-0d76bafb7e0d /home xfs defaults 1 2 UUID=bd2cc032-2914-4ad3-bfde-b66879ec7d91 /.snapshots btrfs subvol=.snapshots 0 0
Was hast du für einen Router und wo hängt die USB-Platte... am Desktop oder Laptop?
Ich habe eine ähnliche Konfiguration. Meine USB-Platte hängt am Router und die Rechner sind verbunden mit fish. Ich kann also auf die Rechner gegenseitig zugreifen und von jedem Rechner aus per Netzwerk über die fritzbox auf die USB-Platte.
