Meine Frage bezieht sich auf die Bluetooth-Verbindung
- endruschat1000
- Unerledigt
Hinweis: In dem Thema Meine Frage bezieht sich auf die Bluetooth-Verbindung gibt es 73 Antworten auf 8 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
Alles anzeigenlocalhost:~ # zypper in blueberry Problem retrieving files from 'openSUSE-20220322-0'. Empty destination in URI: hd:/?device=/dev/disk/by-id/dm-name-ventoy Please see the above error message for a hint. Warning: Skipping repository 'openSUSE-20220322-0' because of the above error. Some of the repositories have not been refreshed because of an error. Loading repository data... Reading installed packages... 'blueberry' not found in package names. Trying capabilities. No provider of 'blueberry' found. Resolving package dependencies... Nothing to do. localhost:~ #hatte leider offensichtlich nicht geklappt
Alles anzeigenlocalhost:~ # zypper in gnome-bluetooth Problem retrieving files from 'openSUSE-20220322-0'. Empty destination in URI: hd:/?device=/dev/disk/by-id/dm-name-ventoy Please see the above error message for a hint. Warning: Skipping repository 'openSUSE-20220322-0' because of the above error. Some of the repositories have not been refreshed because of an error. Loading repository data... Reading installed packages... Resolving package dependencies... The following recommended package was automatically selected: sbc The following 7 NEW packages are going to be installed: bluez gnome-bluetooth gnome-bluetooth-lang libell0 libgnome-bluetooth13 pulseaudio-module-bluetooth sbc 7 new packages to install. Overall download size: 1.9 MiB. Already cached: 0 B. After the operation, additional 5.5 MiB will be used. Continue? [y/n/v/...? shows all options] (y): y Retrieving package libell0-0.49-1.1.x86_64 (1/7), 215.6 KiB (490.4 KiB unpacked) Retrieving: libell0-0.49-1.1.x86_64.rpm ..................................[done] Retrieving package libgnome-bluetooth13-3.34.5-4.3.x86_64 (2/7), 128.6 KiB (260.3 KiB unpacked) Retrieving: libgnome-bluetooth13-3.34.5-4.3.x86_64.rpm .....[done (793.9 KiB/s)] Retrieving package sbc-1.5-2.8.x86_64 (3/7), 53.6 KiB (146.0 KiB unpacked) Retrieving: sbc-1.5-2.8.x86_64.rpm .......................................[done] Retrieving package bluez-5.63-1.1.x86_64 (4/7), 1.1 MiB ( 3.6 MiB unpacked) Retrieving: bluez-5.63-1.1.x86_64.rpm ........................[done (1.3 MiB/s)] Retrieving package pulseaudio-module-bluetooth-15.0-10.2.x86_64 (5/7), 153.1 KiB (282.1 KiB unpacked) Retrieving: pulseaudio-module-bluetooth-15.0-10.2.x86_64.rpm .............[done] Retrieving package gnome-bluetooth-3.34.5-4.3.x86_64 (6/7), 82.2 KiB (159.4 KiB unpacked) Retrieving: gnome-bluetooth-3.34.5-4.3.x86_64.rpm ........................[done] Retrieving package gnome-bluetooth-lang-3.34.5-4.3.noarch (7/7), 181.8 KiB (613.0 KiB unpacked) Retrieving: gnome-bluetooth-lang-3.34.5-4.3.noarch.rpm ...................[done] Checking for file conflicts: .............................................[done] (1/7) Installing: libell0-0.49-1.1.x86_64 ................................[done] (2/7) Installing: libgnome-bluetooth13-3.34.5-4.3.x86_64 .................[done] (3/7) Installing: sbc-1.5-2.8.x86_64 .....................................[done] Created symlink /etc/systemd/system/dbus-org.bluez.service -> /usr/lib/systemd/system/bluetooth.service. Created symlink /etc/systemd/system/bluetooth.target.wants/bluetooth.service -> /usr/lib/systemd/system/bluetooth.service. (4/7) Installing: bluez-5.63-1.1.x86_64 ..................................[done] (5/7) Installing: pulseaudio-module-bluetooth-15.0-10.2.x86_64 ...........[done] (6/7) Installing: gnome-bluetooth-3.34.5-4.3.x86_64 ......................[done] (7/7) Installing: gnome-bluetooth-lang-3.34.5-4.3.noarch .................[done] Executing %posttrans scripts .............................................[done] localhost:~ #ich mache mal neustart & schaue ob dann was da ist
leider sehe ich immer noch keine bluetooth-optionen
Na Gott sei Dank.
Wegen Blueberry bin ich immer noch verwundert. Scheint bei Tumbleweed anders zu sein. Egal.
Dann starte einmal den Rechner neu und Versuch dann mal eine Verbindung hinzu bekommen.
Auf das Bluetooth Symbol klicken, im neuen Fenster Bluetooth einschalten. In der Liste der Geräte dein Handy auswählen. Verbindung anfordern und auf beiden Geräten die Pin bestätigen.
Mehr ist das ja nicht.
openSUSE TumbleweedLearn about the openSUSE distributions and download them for freeget.opensuse.org-hier gibt es ein Online-Image das wäre vielleicht was?
würde ich übermorgen woanders versuchen
-durch einen neustart finde ich nach wie vor nichts neues
Das wäre das richtige Image für eine Installation.
Ich schlage auch eine Neuinstallation vor. Wie gesagt, da ist irgendwas schief gelaufen.
Wenn man dann Xfce als Desktop auswählt ist der auch vollständig inklusive Bluetooth.
Da braucht man nichts nachinstallieren.
Ist ja Wochenende. Mach mal alles neu.
Und online wie gesagt,
denn offline hatte ich schon versucht
dasselbe würde ich mit pcLinuxOS versuchen...
Neu installieren hilft meist nicht......
PS:
blueberry ist wohl bei Tumbleweed nicht dabei
