localhost:/home/yves # nvidia-settings
(nvidia-settings:10868): GLib-GObject-CRITICAL **: 09:36:42.286: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
XDG_RUNTIME_DIR (/run/user/1000) is not owned by us (uid 0), but by uid 1000! (This could e.g. happen if you try to connect to a non-root PulseAudio as a root user, over the native protocol. Don't do that.)
Package xorg-server was not found in the pkg-config search path.
Perhaps you should add the directory containing `xorg-server.pc'
to the PKG_CONFIG_PATH environment variable
No package 'xorg-server' found
