Hallo Susi;s ![]()
ich habe heute für meine Frau auf deren openSUSE 12.1 32Bit Rechner das Programm SweetHome3D aus dem Homerepository https://build.opensuse.org/pac…elbst&package=SweetHome3D installiert. Installation klappte auch ohne Probleme.
Das Problem ist: Das Programm startet nicht.
Folgende Fehlermeldung bekomme ich wenn ich SweetHome3D in der Konsole starte:
opensuse@linux-un4y:~> SweetHome3D.sh
java virtual machine used: /usr/lib/jvm/jre/bin/java
classpath used: /usr/share/java/SweetHome3D/jnlp.jar:/usr/share/java/SweetHome3D/Textures.jar:/usr/share/java/SweetHome3D/sunflow-0.07.3g.jar:/usr/share/java/SweetHome3D/SweetHome3D-3.7.jar:/usr/share/java/SweetHome3D/Furniture.jar:/usr/share/java/SweetHome3D/Help.jar:/usr/share/java/SweetHome3D/Loader3DS1_2u.jar:/usr/share/java/SweetHome3D/jmf.jar:/usr/share/java/SweetHome3D/freehep-vectorgraphics-svg-2.1.1.jar:/usr/share/java/SweetHome3D/iText-2.1.7.jar:/usr/share/java/SweetHome3D/vecmath-1.5.2.jar:/usr/share/java/SweetHome3D/batik-svgpathparser-1.7.jar:/usr/share/java/java3d/j3dutils-1.5.2.jar:/usr/share/java/java3d/j3dcore-1.5.2.jar:/usr/share/java/java3d/vecmath-1.5.2.jar
main class used: com.eteks.sweethome3d.SweetHome3D
flags used:
options used: -Djava.library.path=/usr/lib64:/usr/lib
arguments used:
3D [dev] 1.5.2-pre4-1301022353-experimental 02 Jan 2013 23:53:31 UTC
Java 3D: implicit antialiasing enabled
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x6ba16db1, pid=3993, tid=1764940656
# JRE version: 6.0_27-b27
# Java VM: OpenJDK Server VM (20.0-b12 mixed mode linux-x86 )
# Derivative: IcedTea6 1.12.2
# Distribution: Dummy Product (i586), package suse-24.1-i386
# Problematic frame:
# C [libj3dcore-ogl.so+0xedb1] Java_javax_media_j3d_X11NativeConfigTemplate3D_isStereoAvailable+0x4e
# An error report file with more information is saved as:
# /home/opensuse/hs_err_pid3993.log
# If you would like to submit a bug report, please include
# instructions how to reproduce the bug and visit:
# http://icedtea.classpath.org/bugzilla
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Abgebrochen
So wie ich das sehe ist es wohl ein Problem mit Java. Aber was genau? Die aktuellste Version ist es doch wohl. ![]()
Bei dem Rechner ist Java java-1_6_0-openjdk und java3d 1.5.2 installiert.
Für Tipps und Ratschläge bin ich sehr dankbar.
Maik ![]()
