Da mir die Sache unheimlich wird, ist das Neuaufsetzen mit Leap wahrscheinlich die sicherere Variante, um wieder ruhig zu schlafen...
Tumbleweed: Dateien veschwinden spontan
- altamira
Hinweis: In dem Thema Tumbleweed: Dateien veschwinden spontan gibt es 31 Antworten auf 4 Seiten. Der letzte Beitrag () befindet sich auf der letzten Seite.
Und hier noch fürs Protokoll die Ausgabe von smartctl. Scheint alles ok.
Alles anzeigensmartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.15.3-1-default] (SUSE RPM) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: Hitachi HDS721050CLA360 Serial Number: JP1592FR1AWA4C LU WWN Device Id: 5 000cca 39dd309cc Firmware Version: JP2OA50E User Capacity: 500.107.862.016 bytes [500 GB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Thu Feb 22 09:06:14 2018 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x85) Offline data collection activity was aborted by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 4798) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 80) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 65536 2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 93 3 Spin_Up_Time 0x0007 118 118 024 Pre-fail Always - 194 (Average 194) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 2291 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 138 138 020 Pre-fail Offline - 31 9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 4056 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2286 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2297 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2297 194 Temperature_Celsius 0x0002 187 187 000 Old_age Always - 32 (Min/Max 16/43) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 0 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 4056 - # 2 Extended offline Interrupted (host reset) 20% 3894 - # 3 Extended offline Interrupted (host reset) 30% 3722 - # 4 Extended offline Completed without error 00% 3561 - # 5 Extended offline Completed without error 00% 3510 - # 6 Extended offline Completed without error 00% 3357 - # 7 Extended offline Completed without error 00% 3210 - # 8 Extended offline Completed without error 00% 2660 - # 9 Extended offline Completed without error 00% 2478 - #10 Extended offline Completed without error 00% 2398 - #11 Extended offline Interrupted (host reset) 70% 2370 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. -
Du wirst keinen Schritt weiterkommen,
wenn du nicht substantielles zu deinem Fehler lieferst.
Weitere Prosa mag im geselligen Beisammensein bei Wein die Zeit vertreiben,
wir würden trotzdem lieber bei den Fakten bleiben.Was hat dein Check __genau__ ergeben?
Alle Partitionen gecheckt?
Systemlogs bei und während des Checks?
smartctl Checks?
Resultat? -
Hallo Berichtigung,
mehr Checks und Logs habe ich nicht. Ich habe die fstab, einen systemd-log in flagranti und den smartctl output in #22 gem. Beitrag #12 gepostet. Es tut mir Leid, wenn die Informationen nicht ausreichen, um das Problem weiter einzukreisen. Ich habe mir im Vorfeld lange überlegt, ob ich es ins Forum stelle, wollte aber Hinweise für Personen geben, die vielleicht von ähnlichen Dateiverlusten betroffen sind.
Der Rechner wird gerade mit Leap 43.3 neu aufgebaut, so dass keine weiteren Recherchen auf dem alten System mehr durchgeführt werden können.
Danke für Eure Unterstützung. Thread wird auf "gelöst" gesetzt.
Na denn viel Glück.
Sollte meine Vermutung zutreffen, nutzt dieses Vorgehen nichts.
Denn es ist ein Kurieren an Symptomen, nicht die Lösung des Problems.
Mal gucken.Du solltest auf jeden Fall gleich smartmonctl installieren und die Logs im Auge behalten.
Und smartctl mit richtigen Parametern aufrufen, da das Laufwerk nicht in der database ist.
Gesendet von meinem E6653 mit Tapatalk
Auf was wartet ihr ?
Im 20sten Eintrag steht aus meiner Sicht genug:Code21.02.18 21:01 smartd Device: /dev/sda [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 120 to 99 21.02.18 21:01 smartd Device: /dev/sda [SAT], SMART Usage Attribute: 189 Airflow_Temperature_Cel changed from 25 to 27 21.02.18 21:01 smartd Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 25 to 27 21.02.18 21:01 smartd Device: /dev/sda [SAT], SMART Usage Attribute: 195 ECC_Uncorr_Error_Count changed from 100 to 120 21.02.18 21:01 smartd Device: /dev/sda [SAT], SMART Usage Attribute: 201 Unc_Soft_Read_Err_Rate changed from 100 to 120 21.02.18 21:01 smartd Device: /dev/sda [SAT], SMART Usage Attribute: 204 Soft_ECC_Correct_Rate changed from 100 to 120 21.02.18 21:01 smartd Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 206 to 193 21.02.18 21:07 org.kde.ActivityManager "UPDATE ResourceEvent SET end = :end WHERE :usedActivity = usedActivity AND :initiatingAgent = initiatingAgent AND :targettedResource = targettedResource AND end IS NULL" 21.02.18 21:07 org.kde.ActivityManager QSqlError("11", "Der Datensatz konnte nicht abgeholt werden", "database disk image is malformed")Wer sichert ist feige?
Wenn es wichtig ist, versuch's mal mit irgend so einen modernen RAID (Level>0) Kram (Ich ziehe Software-Lösungen vor z.B. mit mdadm).
Übrigens ist bei den billigen Chip-Disks (USB, SSD) das Fehlerverhalten noch befremdlicher als bei denen mit Kreislauf. Spiegeln wäre dann echt sinnvoll. -
Da du neu installierst /installiert hast, sind die Karten neu gemischt.
Selbst wir können keine vergangenen Installationen fehlerbereinigen.Was sind Storagedevices "mit Kreislauf"?
Deine Mutmaßungen über "Fehlerverhalten" von Flash-Speicher ist falsch.
Linux behandelt alle Speicher (selbst Netzwerkmounts) mit demselben Subsystem.
Auf Geräteebene wirst du mit den jeweiligen Herstellern sprechen müssen.
Da hat Linux auch nichts verloren oder zu gewinnen.mdadm ist sowohl für Hardware- wie auch für Softwarelösungen zuständig.
Hardware hat halt den Nachteil, dass es nicht kompatibel ist. Solche Platten wird man nur bei exakt dem gleichen Kontroller in anderen Systemen zum Laufen bringen.
Das kann dir aber auch egal sein. -
Pre-Fail kommt vor dem Fail. smartctl --all /dev/sda
Vielleicht sind die Karten neu gemischt, aber das Blech ist wohl noch das selbe:
"Der Rechner wird gerade mit Leap 43.3 neu aufgebaut, so dass keine weiteren Recherchen auf dem alten System mehr durchgeführt werden können." -
43.3. Soso... selbst entwickelt?
