Teil2
| FAX QUEUE SETUP |
Please enter a name for this fax queue (m=use model name:'HP_Color_LaserJet_MFP_M277dw_fax'*, q=quit) ?m
Using queue name: HP_Color_LaserJet_MFP_M277dw_fax
Enter a location description for this printer (q=quit) ?
Enter additonal information or notes for this printer (q=quit) ?
Adding fax queue to CUPS:
Device URI: hpfax:/net/HP_Color_LaserJet_MFP_M277dw?ip=169.254.80.67
Queue name: HP_Color_LaserJet_MFP_M277dw_fax
PPD file: /usr/share/cups/model/manufacturer-PPDs/hplip/HP-Fax2-hpcups.ppd.gz
Information:
| FAX HEADER SETUP |
Would you like to perform fax header setup (y=yes*, n=no, q=quit) ?y
Created directory: /var/lib/net-snmp/cert_indexes
Created directory: /var/lib/net-snmp/mib_indexes
error: Unable to communicate with device (code=12): hpfax:/net/HP_Color_LaserJet_MFP_M277dw?ip=169.254.80.67
error: Unable to communicate with the device. Please check the device and try again.
| PRINTER TEST PAGE |
Would you like to print a test page (y=yes*, n=no, q=quit) ? y
warning: hp-testpage should not be run as root/superuser.
HP Linux Imaging and Printing System (ver. 3.19.12)
Testpage Print Utility ver. 6.0
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
error: Unable to communicate with device (code=12): hp:/net/HP_Color_LaserJet_MFP_M277dw?ip=169.254.80.67
error: Unable to print to printer. Please check device and try again.
note: If an error occured, or the test page failed to print, refer to the HPLIP website
note: at: http://hplip.sourceforge.net for troubleshooting and support.
Done.
