Hallo Sauerland,
kompletter Code geht nicht, Meldung:
vorn abgschnitten, bis es passte.
Nach zypper install hplip einmal hp-check,
zypper in dbus-1-python3,zypper in dbus-1-python3-devel,
und nochmals hp-check ausgeführt.
Wenn der vordere Code-Teil noch wichtig sein sollte, sende ich ihn nach.
Current contents of '/var/lib/hp/hplip.state' file:
Plugins are not installed. Could not access file: No such file or directory
Current contents of '~/.hplip/hplip.conf' file:
warning: Could not access file: No such file or directory
<Package-name> <Package-Desc> <Required/Optional> <Min-Version> <Installed-Version> <Status> <Comment>
| External Dependencies |
cups CUPS - Common Unix Printing System REQUIRED 1.1 2.2.7 OK 'CUPS Scheduler is running'
gs GhostScript - PostScript and PDF language interpreter and previewer REQUIRED 7.05 9.52 OK -
No protocol specified
xsane xsane - Graphical scanner frontend for SANE OPTIONAL 0.9 0.999 OK -
scanimage scanimage - Shell scanning program OPTIONAL 1.0 1.0.32 OK -
dbus DBus - Message bus system REQUIRED - 1.12.2 OK -
policykit PolicyKit - Administrative policy framework OPTIONAL - 0.116 OK -
network network -wget OPTIONAL - 1.20.3 OK -
avahi-utils avahi-utils OPTIONAL - 0.7 OK -
| General Dependencies |
error: libjpeg libjpeg - JPEG library REQUIRED - - MISSING 'libjpeg needs to be installed'
error: cups-devel CUPS devel- Common Unix Printing System development files REQUIRED - 2.2.7 MISSING 'cups-devel needs to be installed'
error: cups-image CUPS image - CUPS image development files REQUIRED - 2.2.7 MISSING 'cups-image needs to be installed'
libpthread libpthread - POSIX threads library REQUIRED - b'2.31' OK -
error: libusb libusb - USB library REQUIRED - 1.0 MISSING 'libusb needs to be installed'
sane SANE - Scanning library REQUIRED - - OK -
error: sane-devel SANE - Scanning library development files REQUIRED - - MISSING 'sane-devel needs to be installed'
error: libavahi-dev libavahi-dev REQUIRED - - MISSING 'libavahi-dev needs to be installed'
error: libnetsnmp-devel libnetsnmp-devel - SNMP networking library development files REQUIRED 5.0.9 5.7.3 MISSING 'libnetsnmp-devel needs to be installed'
error: libcrypto libcrypto - OpenSSL cryptographic library REQUIRED - 1.1.1 MISSING 'libcrypto needs to be installed'
python3X Python 2.2 or greater - Python programming language REQUIRED 2.2 3.6.13 OK -
python3-notify2 Python libnotify - Python bindings for the libnotify Desktop notifications OPTIONAL - - OK -
error: python3-pyqt4-dbus PyQt 4 DBus - DBus Support for PyQt4 OPTIONAL 4.0 - MISSING 'python3-pyqt4-dbus needs to be installed'
error: python3-pyqt4 PyQt 4- Qt interface for Python (for Qt version 4.x) REQUIRED 4.0 - INCOMPAT 'python3-pyqt4 needs to be installed'
python3-dbus Python DBus - Python bindings for DBus REQUIRED 0.80.0 1.2.16 OK -
python3-xml Python XML libraries REQUIRED - 2.2.5 OK -
python3-devel Python devel - Python development files REQUIRED 2.2 3.6.13 OK -
python3-pil PIL - Python Imaging Library (required for commandline scanning with hp-scan) OPTIONAL - 7.2.0 OK -
python3-reportlab Reportlab - PDF library for Python OPTIONAL 2.0 3.4.0 OK -
| COMPILEDEP |
error: libtool libtool - Library building support services REQUIRED - - MISSING 'libtool needs to be installed'
error: gcc gcc - GNU Project C and C++ Compiler REQUIRED - 7.5.0 MISSING 'gcc needs to be installed'
make make - GNU make utility to maintain groups of programs REQUIRED 3.0 4.2.1 OK -
| Python Extentions |
cupsext CUPS-Extension REQUIRED - 3.20.11 OK -
hpmudext IO-Extension REQUIRED - 3.20.11 OK -
| Scan Configuration |
hpaio HPLIP-SANE-Backend REQUIRED - 3.20.11 OK 'hpaio found in /etc/sane.d/dll.conf'
error: NOT FOUND OR FAILED TO LOAD! Please reinstall HPLIP and check for the proper installation of scanext.
error: scanext Scan-SANE-Extension REQUIRED - 3.20.11 MISSING 'scanext needs to be installed'
| DISCOVERED SCANNER DEVICES |
device `hpaio:/net/HP_LaserJet_MFP_M129-M134?ip=192.168.1.22' is a Hewlett-Packard HP_LaserJet_MFP_M129-M134 all-in-one
| DISCOVERED USB DEVICES |
No devices found.
| INSTALLED CUPS PRINTER QUEUES |
bunt_Brother_HL-L3230CDW
Type: Unknown
Device URI: http://192.168.1.25
PPD: /etc/cups/ppd/bunt_Brother_HL-L3230CDW.ppd
PPD Description: Brother HL-L3230CDW series, driverless, cups-filters 1.25.0
Printer status: Drucker bunt_Brother_HL-L3230CDW ist im Leerlauf. Aktiviert seit Sa 23 Okt 2021 15:02:05 CEST
warning: Printer is not HPLIP installed. Printers must use the hp: or hpfax: CUPS backend for HP-Devices.
Type: Printer
Device URI: hp:/net/HP_LaserJet_MFP_M129-M134?ip=192.168.1.22
PPD: /etc/cups/ppd/HP_LaserJet_MFP_M129-M134.ppd
PPD Description: HP LaserJet MFP m129-m134, hpcups 3.20.11
Printer status: Drucker HP_LaserJet_MFP_M129-M134 ist im Leerlauf. Aktiviert seit Do 11 Nov 2021 14:21:26 CET
Communication status: Good
HP_LaserJet_MFP_M129-M134_fax_2
Type: Fax
Device URI: hpfax:/net/HP_LaserJet_MFP_M129-M134?ip=192.168.1.22
PPD: /etc/cups/ppd/HP_LaserJet_MFP_M129-M134_fax_2.ppd
PPD Description: HP Fax2 hpcups
Printer status: Drucker HP_LaserJet_MFP_M129-M134_fax_2 ist im Leerlauf. Aktiviert seit Do 11 Nov 2021 13:46:54 CET
Keller_Brother
Type: Unknown
Device URI: socket://192.168.1.1:9100
PPD: /etc/cups/ppd/Keller_Brother.ppd
PPD Description: Brother DCP-7030, using brlaser v6
Printer status: Drucker Keller_Brother ist im Leerlauf. Aktiviert seit So 07 Nov 2021 16:39:03 CET
| PERMISSION |
| SUMMARY |
Missing Required Dependencies
error: 'libjpeg-devel' package is missing/incompatible
error: 'zlib-devel' package is missing/incompatible
error: 'cups-devel' package is missing/incompatible
error: 'cupsddk' package is missing/incompatible
error: 'libusb-1_0-devel' package is missing/incompatible
error: 'libusb-1_0-0' package is missing/incompatible
error: 'sane-backends-devel' package is missing/incompatible
error: 'libavahi-devel' package is missing/incompatible
error: 'net-snmp-devel' package is missing/incompatible
error: 'openssl' package is missing/incompatible
error: 'python3-qt4' package is missing/incompatible
error: 'python3-qt4-devel' package is missing/incompatible
error: 'libtool' package is missing/incompatible
error: 'libgphoto2-devel' package is missing/incompatible
error: 'rpm-build' package is missing/incompatible
error: 'gcc-c++' package is missing/incompatible
Missing Optional Dependencies
error: 'dbus-1-python3-devel' package is missing/incompatible
error: 'dbus-1-python3' package is missing/incompatible
Total Errors: 13
Total Warnings: 3
Done.
