Hallo Leute,
bei mir stürzt k3b beim Auslesen einer Audio-CD sofort nach dem Starten des Auslesevorgangs reproduzierbar ab. Fehler tritt sowohl beim Versuch mp3-Files zu erzeugen auf, als auch bei ogg-vorbis.
Opensuse 12.3 64bit
Kernel 3.7.10-1.16.-desktop
Desktop-PC, AMD Athlon(tm) II X2 260 Processor
k3b-Version: 2.0.80.git20131118-1.4-x86_64 vom Packman-Repository
Backtrace aus der Fehlerausgabe (Versuch ogg-Files zu erstellen):
ZitatAlles anzeigenApplication: K3b (k3b), signal: Segmentation fault
Using host libthread_db library "/lib64/libthread_db.so.1".
[Current thread is 1 (Thread 0x7f769e41f840 (LWP 2572))]
Thread 3 (Thread 0x7f7685521700 (LWP 2573)):
#0 0x00007f7698078e25 in pthread_mutex_lock () from /lib64/libpthread.so.0
#1 0x00007f7693410a71 in g_mutex_lock () from /usr/lib64/libglib-2.0.so.0
#2 0x00007f76933d340b in g_main_context_query () from /usr/lib64/libglib-2.0.so.0
#3 0x00007f76933d3a19 in ?? () from /usr/lib64/libglib-2.0.so.0
#4 0x00007f76933d3bc4 in g_main_context_iteration () from /usr/lib64/libglib-2.0.so.0
#5 0x00007f7699a1f2e6 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4
#6 0x00007f76999efadf in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4
#7 0x00007f76999efd68 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4
#8 0x00007f76998f20f0 in QThread::exec() () from /usr/lib64/libQtCore.so.4
#9 0x00007f76999d029f in ?? () from /usr/lib64/libQtCore.so.4
#10 0x00007f76998f50cc in ?? () from /usr/lib64/libQtCore.so.4
#11 0x00007f7698076e0f in start_thread () from /lib64/libpthread.so.0
#12 0x00007f769837444d in clone () from /lib64/libc.so.6
Thread 2 (Thread 0x7f76737fe700 (LWP 2701)):
[KCrash Handler]
#5 0x00007f769e02bc28 in K3b::Device::Track::length() const () from /usr/lib64/libk3bdevice.so.6
#6 0x00000000004cf915 in _start ()
Thread 1 (Thread 0x7f769e41f840 (LWP 2572)):
#0 0x00007f76983675ed in read () from /lib64/libc.so.6
#1 0x00007f769340fe0f in ?? () from /usr/lib64/libglib-2.0.so.0
#2 0x00007f76933d3634 in g_main_context_check () from /usr/lib64/libglib-2.0.so.0
#3 0x00007f76933d3a42 in ?? () from /usr/lib64/libglib-2.0.so.0
#5 0x00007f7699a1f2c6 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4
#6 0x00007f7698bbdc1e in ?? () from /usr/lib64/libQtGui.so.4
#7 0x00007f76999efadf in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4
#8 0x00007f76999efd68 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4
#9 0x00007f7698fd19c8 in QDialog::exec() () from /usr/lib64/libQtGui.so.4
#10 0x0000000000533108 in _start ()
Konsolenausgaben bei Start von k3b von der Konsole:
ZitatAlles anzeigen<NAME>@<RECHNER>:~Musik/mp3> k3b
Fontconfig warning: "/etc/fonts/conf.d/56-user.conf", line 9: reading configurations from ~/.fonts.conf is deprecated.
k3b(2572)/kdeui (kdelibs): Attempt to use QAction "location_bar" with KXMLGUIFactory!
<NAME>@<RECHNER>:~/Musik/mp3> "/org/freedesktop/UDisks2/drives/Hitachi_HDS721050CLA362_JPF540HE1XG9UT" : property "Drive" does not exist
"/org/freedesktop/UDisks2/drives/HL_DT_ST_DVDRAM_GH22NS50_K3ZA8GA0252" : property "Drive" does not exist
"/org/freedesktop/UDisks2/drives/Hitachi_HDS721050CLA362_JPF540HE1XG9UT" : property "DeviceNumber" does not exist
"/org/freedesktop/UDisks2/drives/Hitachi_HDS721050CLA362_JPF540HE1XG9UT" : property "Device" does not exist
"/org/freedesktop/UDisks2/block_devices/sr0" : property "Name" does not exist
"/org/freedesktop/UDisks2/drives/HL_DT_ST_DVDRAM_GH22NS50_K3ZA8GA0252" : property "DeviceNumber" does not exist
"/org/freedesktop/UDisks2/drives/HL_DT_ST_DVDRAM_GH22NS50_K3ZA8GA0252" : property "Device" does not exist
K3bQProcess::QProcess(0x0)
k3b(2572) KSambaSharePrivate::testparmParamValue: We got some errors while running testparm "Load smb config files from /etc/samba/smb.conf
Loaded services file OK.
ERROR: pid directory /var/run/samba does not exist
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 11
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 10
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 9
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 8
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 7
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 6
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 5
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 4
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 3
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 2
k3b(2572) KCDDB::CDInfo::track: Couldn't find track 0
QGridLayout: Multi-cell fromRow greater than toRow
QLayout: Attempting to add QLayout "" to QFrame "", which already has a layout
KCrash: Application 'k3b' crashing...
KCrash: Attempting to start /usr/lib64/kde4/libexec/drkonqi from kdeinit
sock_file=/home/<NAME>/.kde4/socket-linux-x2kv.dorperhof/kdeinit4__0
QSocketNotifier: Invalid socket 12 and type 'Read', disabling...
QSocketNotifier: Invalid socket 8 and type 'Read', disabling...
QSocketNotifier: Invalid socket 9 and type 'Read', disabling...
QSocketNotifier: Invalid socket 13 and type 'Exception', disabling...
QSocketNotifier: Invalid socket 16 and type 'Read', disabling...
QSocketNotifier: Invalid socket 24 and type 'Read', disabling...
QSocketNotifier: Invalid socket 25 and type 'Read', disabling...
QSocketNotifier: Invalid socket 11 and type 'Read', disabling...
QSocketNotifier: Invalid socket 17 and type 'Read', disabling...
k3b: Fatal IO error: client killed
A KUiServerJobTracker instance contains 1 stalled jobs
Brennen von CDs ist übrigens problemlos möglich.
Falls noch weitere Angaben oder Logfiles zur Fehlersuche hilfreich sind, bitte melden.
FD1007
