Hallo Sauerland,
danke für den Hinweis zu sudo vs. root. Das war mir nicht ganz klar.
Hier die Ausgabe - wobei ich nicht sicher bin, ob das "nach einem Abbruch" ist - aber ich habe das System neu gestartet und dann hat sich das WLAN "verbunden" und direkt danach wieder die eingeschränkte Verbindung ohne Internetzugriff gemeldet:
localhost:~ # journalctl -k | grep -Ei 'wlan|network|88'
Feb 11 21:15:14 localhost kernel: printk: log_buf_len: 524288 bytes
Feb 11 21:15:14 localhost kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Feb 11 21:15:14 localhost kernel: Memory: 3364296K/16776376K available (14344K kernel code, 3407K rwdata, 9184K rodata, 2836K init, 5988K bss, 516368K reserved, 0K cma-reserved)
Feb 11 21:15:14 localhost kernel: drop_monitor: Initializing network drop monitor service
Feb 11 21:15:16 localhost kernel: [drm] GART: num cpu pages 524288, num gpu pages 524288
Feb 11 21:15:17 localhost kernel: [drm] size 5242880
Feb 11 20:15:19 localhost kernel: e100: Intel(R) PRO/100 Network Driver
Feb 11 20:15:20 localhost kernel: r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
Feb 11 20:15:20 localhost kernel: Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
Feb 11 20:15:20 localhost kernel: usbcore: registered new interface driver r8188eu
Feb 11 20:15:20 localhost kernel: r8188eu 5-2:1.0 wlan2: renamed from wlan0
Feb 11 20:15:20 localhost kernel: loop1: detected capacity change from 0 to 113888
Feb 11 20:15:20 localhost kernel: loop7: detected capacity change from 0 to 113888
Feb 11 20:15:20 localhost kernel: audit: type=1400 audit(1676142920.288:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=723 comm="apparmor_parser"
Feb 11 20:16:25 localhost.localdomain kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan2: link becomes ready
Feb 11 20:16:44 localhost.localdomain kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan2: link becomes ready
localhost:~ #
