Alero . siehe deinem Post #11 - habe ich den Befehl genommen:
Ergebnis:
matrix@matrixcity:~> su -l
Passwort:
matrixcity:~ # zypper lr -uP
# | Alias | Name | Enabled | GPG Check | Refresh | Priority | URI
1 | Packman_Repository | Packman_Repository | Yes | (r ) Yes | Yes | 20 | http://packma
n.inode.at/suse/openSUSE_Tumbleweed
2 | download.nvidia.com-tumbleweed | nVidia Graphics Drivers | Yes | (r ) Yes | Yes | 99 | https://downl
oad.nvidia.com/opensuse/tumbleweed
3 | download.opensuse.org-non-oss | Haupt-Repository (NON-OSS) | Yes | (r ) Yes | Yes | 99 | http://downlo
ad.opensuse.org/tumbleweed/repo/non-oss/
4 | download.opensuse.org-oss | Haupt-Repository (OSS) | Yes | (r ) Yes | Yes | 99 | http://downlo
ad.opensuse.org/tumbleweed/repo/oss/
5 | download.opensuse.org-tumbleweed | Hauptaktualisierungs-Repository | Yes | (r ) Yes | Yes | 99 | http://downlo
ad.opensuse.org/update/tumbleweed/
6 | openSUSE-20210113-0 | openSUSE-20210113-0 | Yes | (r ) Yes | Yes | 99 | http://downlo
7 | repo-debug | openSUSE-Tumbleweed-Debug | No | ---- | ---- | 99 | http://downlo
ad.opensuse.org/debug/tumbleweed/repo/oss/
8 | repo-source | openSUSE-Tumbleweed-Source | No | ---- | ---- | 99 | http://downlo
ad.opensuse.org/source/tumbleweed/repo/oss/
matrixcity:~ # zypper dup --from 1
Loading repository data...
Reading installed packages...
Computing distribution upgrade...
Repository '1' not found by its alias, number, or URI.
Use 'zypper repos' to get the list of defined repositories.
nochmal versucht, diesmal....
19 Problems:
Problem: problem with installed package vlc-codec-gstreamer-3.0.11.1-4.1.x86_64
Problem: problem with installed package vlc-vdpau-3.0.11.1-4.1.x86_64
Problem: problem with installed package libvlccore9-3.0.11.1-4.1.x86_64
Problem: problem with installed package libpostproc55_7-4.3.1-6.2.x86_64
Problem: problem with installed package vlc-noX-3.0.11.1-4.1.x86_64
Problem: problem with installed package libavresample4_0-4.3.1-6.2.x86_64
Problem: problem with installed package libswresample3_7-4.3.1-6.2.x86_64
Problem: problem with installed package vlc-3.0.11.1-4.1.x86_64
Problem: problem with installed package libquicktime0-1.2.4+git20180804.fff99cd-2.4.x86_64
Problem: problem with installed package vlc-qt-3.0.11.1-4.1.x86_64
Problem: problem with installed package libavfilter7_85-4.3.1-6.2.x86_64
Problem: problem with installed package libvlc5-3.0.11.1-4.1.x86_64
Problem: problem with installed package libavutil56_51-4.3.1-6.2.x86_64
Problem: problem with installed package libswscale5_7-4.3.1-6.2.x86_64
Problem: problem with installed package libheif1-1.10.0-3.1.x86_64
Problem: problem with installed package libgstphotography-1_0-0-1.18.2-2.1.x86_64
Problem: problem with installed package libavcodec58_91-4.3.1-6.2.x86_64
Problem: problem with installed package libavformat58_45-4.3.1-6.2.x86_64
Problem: problem with installed package vlc-lang-3.0.11.1-4.1.noarch
Solution 1: install vlc-codec-gstreamer-3.0.11.1-7.4.x86_64 (with vendor change)
openSUSE --> http://packman.links2linux.de
Solution 2: keep obsolete vlc-codec-gstreamer-3.0.11.1-4.1.x86_64
Choose from above solutions by number or skip, retry or cancel [1/2/s/r/c/d/?] (c):
Ich wähle nun welchen Buchstaben?
zum Abschluss:
diesen Befehl ausführen, damit die Thematik Codecs erfolgreich final abgeschlossen ist ?
zypper install -f --allow-vendor-change libxine2-codecs ffmpeg-4 dvdauthor gstreamer-plugins-bad gstreamer-plugins-bad-orig-addon gstreamer-plugins-base gstreamer-plugins-good gstreamer-plugins-good-extra gstreamer-plugins-libav gstreamer-plugins-ugly gstreamer-plugins-ugly-orig-addon smplayer x264 x265 vlc-codecs ogmtool
Petert : "Repo # 7 + 8 kannst Du beruhigt Löschen. Die brauchst Du nicht ..."
okay, mit welchem Befehl?
